September 22, 2026, 11:28:46 am
A-1 Sidewinder
Topic: A-1 Sidewinder (Read 50572 times)
Re: A-1 Sidewinder
Reply #60 on:
July 18, 2010, 13:14:49 pm »
That looks good Ted !
Re: A-1 Sidewinder
Reply #61 on:
July 19, 2010, 00:14:54 am »
Quote from: Kaferdog on July 18, 2010, 07:53:56 am
Looks good buddy...
....How was the "Party"..?..Sorry I couldn't make it... I was wrapped up in truck repairs .....
Thanks Randy, No prob, you got e-mail. Below are pics of the install today. Could not fire it up cause I need to get a plug for O2 senser hole. One problem, #4 flange does not sit real flat and has a very so slight gap. Will talk to Tiger on Monday, the last pic you might see the gap. After I start it I'll know for sure. Anyway, below are some pics of the sidewinder installed.
Ted
Re: A-1 Sidewinder
Reply #62 on:
July 19, 2010, 21:58:09 pm »
Ted if you have an extra bypass relief valve cap for stock case, you can use that for a plug.
Re: A-1 Sidewinder
Reply #63 on:
July 19, 2010, 22:17:51 pm »
Hey Jim, that's exactly what I'm going to use. I have an old one I can put in to fire it up, will be going to Bill & Steves tomorrow to pick up the ones that you use an allen wrench on. I use those on my motors, works awesome, multi purpose.
Ted
Kaferdog
Re: A-1 Sidewinder
Reply #64 on:
July 19, 2010, 23:02:51 pm »
Ted ..Did ya resolve the problem with the #4 flange...? try to loosen the other flanges and then do #4 first.... then the rest ..?
Re: A-1 Sidewinder
Reply #65 on:
July 19, 2010, 23:05:43 pm »
Quote from: HotRod Ted on July 19, 2010, 22:17:51 pm
Ted
did you know you can use a front axle nut from linkpin bug as the bung?
I tried the stainless plug that came with my NGK AFR sensor... big mistake! Even with anti seize it took an Act of God (and lots of heat and swear words) to get it out of my header after 2 years.
Re: A-1 Sidewinder
Reply #66 on:
July 20, 2010, 02:04:57 am »
Spark plug might be the same, too? Yet another method to create confusion. Run a spare lead out of sight and BOOM, instant head scratching.
Re: A-1 Sidewinder
Reply #67 on:
July 20, 2010, 04:53:44 am »
Quote from: javabug on July 20, 2010, 02:04:57 am
Why not go the extra $100 if your going to screw a spark plug in the hole
AUTO-LOC FLAME FLAME THROWER KIT
FLAME THROWER KIT
Price: $94.95
Description of AUTO-LOC FLAME Thrower Kit
The exhaust flame thrower kit is a must have for all 1969 VW Cal Look Bugs with A-1 Sidewinder exhaust systems. The kit can make up to 20' flames shoot out your exhaust on command. The main control box will control 1 spark plug for optimal performance on single exhaust vehicles. Easy installation and detailed instruction insures compatibility with most exhaust systems. The kit includes control box, activation button, wire loom, and wire diagram. Please note the kit does not include the coil and spark plug needed for installation.
Last Edit: July 20, 2010, 04:56:26 am by Sarge
Re: A-1 Sidewinder
Reply #68 on:
July 20, 2010, 04:57:40 am »
Quote from: Sarge on July 20, 2010, 04:53:44 am
You slay me, Sarge.
John Rayburn
Re: A-1 Sidewinder
Reply #69 on:
July 20, 2010, 05:03:15 am »
FLAME THROWER KIT
Price: $94.95
And you can set your timing with the 20' flames.
I also park at Nick's.
Re: A-1 Sidewinder
Reply #70 on:
July 20, 2010, 05:04:52 am »
Quote from: John Rayburn on July 20, 2010, 05:03:15 am
How adolescent.
Re: A-1 Sidewinder
Reply #71 on:
July 20, 2010, 05:06:49 am »
FLAME THROWER KIT
Price: $94.95
Now there ya go, will have to have Tiger build some extra muffler's after I blow out the inside's of them. LOL Now wait now....have tiger build a short muffler like he does now and have it facing just out the finder.....Hey Sarge, may have something there....
Re: A-1 Sidewinder
Reply #72 on:
July 25, 2010, 03:37:55 am »
UPDATE! Talked to Tiger and came up with a solution, and problem fixed. Gotta say, Tiger is a standup guy. Will always buy his products. Thanks Tiger if ya out there!
Ted
