September 22, 2026, 04:37:13 am
| | |-+  Building a nice 1500cc?
Pages: 1 2 [3] Print
Author Topic: Building a nice 1500cc?  (Read 55918 times)
Wout
« Reply #60 on: November 19, 2012, 23:18:51 pm »
Heads are taken care of, just have to pick them up  Cheesy.
Split the engine this evening, now have to clean it and let it measured.
gr
Wout
Aircooled vw's for life!
Wout
« Reply #61 on: November 20, 2012, 21:11:07 pm »
Now the TDE inlet's will fit  Grin.
gr
Wout
« Reply #62 on: November 21, 2012, 12:43:09 pm »
ideal!
Wout
« Reply #63 on: November 22, 2012, 12:41:00 pm »
What exhaust should I look for that works fine on the 1500 and looks nice under my Ghia?
gr
Wout
cedric
« Reply #64 on: November 23, 2012, 11:20:53 am »
Ray speedwells.....
Wout
« Reply #65 on: November 23, 2012, 12:58:19 pm »
Hey Cedric some suggestions more easy (cheaper) to find  Cheesy?
gr
Wout
Wout
« Reply #66 on: November 30, 2012, 17:11:42 pm »
Are there other suggestions?  Roll Eyes
Thanks!
gr
Wout
« Reply #67 on: November 30, 2012, 20:15:35 pm »
Turbo Thomas/my Std plus 1 3/8"
Better (lower) sound level than the vintage equivallent.
Wout
« Reply #68 on: December 09, 2012, 00:05:39 am »
Thanks, any other suggestions?
Engine is measured, some parts can be saved others not  Grin so lets clean the good ones en get rid of the bad ones...
gr
Wout
« Reply #69 on: December 09, 2012, 00:18:31 am »
bugpack header with glasspack or quiet pack?
« Reply #70 on: December 09, 2012, 00:22:33 am »
http://www.flat4free.be/forum/viewtopic.php?t=95397&sub_category=08.%20Gebruikte%20Onderdelen
Wink
Wout
« Reply #71 on: December 09, 2012, 00:26:13 am »
Thanks, saw it but want something more special  Wink and hope to keep the heating  Tongue
gr
Wout
Wout
« Reply #72 on: December 11, 2012, 21:14:53 pm »
Made some progress...
One side done, one to go...
Thanks Christoph to let me use your machinery  Grin
gr
Wout
Wout
« Reply #73 on: December 14, 2012, 18:38:36 pm »
gr
Wout
Crazy Mc.Stairs
« Reply #74 on: December 14, 2012, 20:38:21 pm »
It's looking AWESOME! Grin
Cheers Christoph Wink
Wout
« Reply #75 on: December 28, 2012, 22:42:47 pm »
Trial fit the inlet's to the modified heads, but it's not OK yet  Roll Eyes.
The angle is IMO not good and the valvecovers doesn't fit  Huh.
Maybe someone know what I'm doing wrong or what has to be done to make it work?
Cutting the inlet's to a different angle could be a solution I think  Undecided.
Thanks!
gr
Wout
Wout
« Reply #76 on: December 31, 2012, 10:58:32 am »
No suggestions?  Roll Eyes
Thanks!
gr
Wout
« Reply #77 on: January 01, 2013, 11:32:53 am »
Thanks!
gr
Wout
I think as long as the manifolds are centred over the port, see how much metal you have left on the outside of the manifold (the rocker cover side), and perhaps clearance the manifolds for the rocker cover?
Sealing up the intake manifolds can be done with an O-ring sized to fit inside the rebate on the head, so no air leaks, even if the manifold face is now thin from the clearancing.
« Reply #78 on: January 01, 2013, 11:56:32 am »
That piece that was cut off your manifolds would space it away so it clears,maybe you need a spacer in there to match what it had originally?
Wout
« Reply #79 on: January 01, 2013, 13:04:17 pm »
Would be a solution but will the inlet stand stable enough then?
Thanks!
gr
Wout
« Reply #80 on: January 01, 2013, 14:51:29 pm »
I would bore a hole in either the manifold or head[or even both] then press a piece of alluminium tube the same size as the manifolds would have had new into the inlet and it will be good
Wout
« Reply #81 on: January 03, 2013, 00:12:04 am »
I would bore a hole in either the manifold or head[or even both] then press a piece of aluminium tube the same size as the manifolds would have had new into the inlet and it will be good
That's an option. But can't do a port-job then  Roll Eyes, or am I wrong?
Thanks!!!!!
gr
Wout
Wout
« Reply #82 on: February 08, 2013, 22:47:40 pm »
Problem solved  Wink
gr
Wout
« Reply #83 on: February 09, 2013, 14:20:11 pm »
Nice work Wout !
Wout
« Reply #84 on: February 09, 2013, 22:10:30 pm »
Thanks! My father in law made it  Grin.
Also had to cut a little bit of the valvecovers but most important improvement is the inlets are vertical now  Smiley, my father in law measured it and it's 0,2° out of perfect vertical so he is not 100% satisfied  Roll Eyes, but I am!!!!
Tomorrow I go with the Karmann to a friend to do some minor welding. I could do it myself but he's a real pro, so I let him do it  Grin
gr
Wout
fish
« Reply #85 on: February 11, 2013, 05:48:37 am »
Looking good mate, love the old school, what mods you doing to the heads?
