November 03, 2026, 00:34:39 am
| | |-+  angle flow heads
Pages: 1 2 [3] 4 5 Print
Author Topic: angle flow heads  (Read 124491 times)
vintagewagenwerks
« Reply #60 on: December 18, 2010, 17:40:51 pm »
oh yes this will be a real argument for this head .thanks for the info.
Itīs better to burn out than to fade away.
« Reply #61 on: December 18, 2010, 18:10:02 pm »
I'll look for the numbers ... I just found it amazing that the exhaust port never quite peaked on airflow (on this particular pair of heads! ... which were 'mildly' ported by Dave Kawell) and I tested it to .650". certainly more than your standard street motor.
Like I said, excellent choice for turbo or NITROUS applications. Wink
« Reply #62 on: December 21, 2010, 04:52:21 am »
Somebody say TURBO?Huh??
« Reply #63 on: December 21, 2010, 05:38:51 am »
Ho Ho Hum ...
vintagewagenwerks
« Reply #64 on: December 21, 2010, 13:14:45 pm »
I īve been really interested about these heads ,a friend here in germany have them too for his 2.9l type one drag engine ,so it is a really big bore the small thing that i drive is a 90.5 and on a other engine a 94 drill ,what is the smallest drill you can buy .
58vw
« Reply #65 on: December 21, 2010, 19:39:09 pm »
they come 94 bore.....and will work...that is the smallest you can (drill) bore have
www.4inbore.com
Angleflows...order them now
vintagewagenwerks
« Reply #66 on: December 21, 2010, 22:27:06 pm »
ok thanks thats good base for a 2332 cc engine
vintagewagenwerks
« Reply #67 on: December 24, 2010, 16:52:37 pm »
can someone tell me when i read the angel flows woulld have a 94 drill ,does it mean it fits to 1585cc pistons or a 94mm piston as a 1914 for example.thans or info about
« Reply #68 on: December 24, 2010, 18:00:52 pm »
94 piston Wink
vintagewagenwerks
« Reply #69 on: December 24, 2010, 18:30:48 pm »
ok thanks
ugly duckling
« Reply #70 on: December 27, 2010, 22:25:29 pm »
well back to it. roughfed out the EX this morning. UD .  [ Attachment: You are not allowed to view attachments ]
ugly duckling
« Reply #71 on: December 27, 2010, 22:30:06 pm »
next would be 36 grit 3/4 cartridge roll.tomorrow.   . UD .
« Last Edit: December 27, 2010, 22:52:21 pm by ugly duckling » Logged
« Reply #72 on: December 27, 2010, 23:05:29 pm »
UDJ,
I don't know how much enjoyment you get out of this work, but I hope it's A LOT.
I find the process, your patience, skill & talent, not to mention the generosity to show it all to us ... amazing.
We all owe you thanks.
Wish they were mine! Cheesy Grin
Cheers,
TxT
71CALRIPPER
« Reply #73 on: December 27, 2010, 23:08:22 pm »
UDJ,
Cheers,
TxT
Whos are they ....
« Reply #74 on: December 27, 2010, 23:30:08 pm »
They're Jeff's right now ...  Cheesy
I'm sure we'll know somehow when they're done. Wink
ugly duckling
« Reply #75 on: December 28, 2010, 23:12:01 pm »
finalized the ex ports this morn.   36grit c roll then 40 grit 1inch shop roll then install new guides. onto intakes.  .UD. [ Attachment: You are not allowed to view attachments ]
« Last Edit: December 28, 2010, 23:25:38 pm by ugly duckling » Logged
ugly duckling
« Reply #76 on: December 28, 2010, 23:15:15 pm »
..  UD.
ugly duckling
« Reply #77 on: December 28, 2010, 23:18:37 pm »
see ya tomorrow. UD.
« Last Edit: December 28, 2010, 23:20:12 pm by ugly duckling » Logged
« Reply #78 on: December 29, 2010, 00:06:02 am »
Jeff ----   What's the biggest valves u can stick in there with a 4" bore?Huh??
vintagewagenwerks
« Reply #79 on: December 29, 2010, 00:29:50 am »
yes that is a really good question ,my ever favorite heads for my new engine project. Tongue
vintagewagenwerks
« Reply #80 on: December 29, 2010, 00:31:57 am »
hey ud i read in the bugpack catalog angel flows are available for 94 bore is that right.
ugly duckling
« Reply #81 on: December 29, 2010, 05:09:17 am »
Harold. the biggest valves i have installed was 56x40. UD.
ugly duckling
« Reply #82 on: December 29, 2010, 05:16:12 am »
as far as i know there not available in 94 YET. I'm sure rick or Dom could answer that better than i could.
« Reply #83 on: December 29, 2010, 05:25:53 am »
Jeez you could fit a Buick through there!
ugly duckling
« Reply #84 on: December 29, 2010, 06:02:51 am »
intakes. valve job tomorrow.
« Reply #85 on: December 29, 2010, 18:14:42 pm »
Jeff -- how much of a flow improvement would that be over a 48x38 head
« Reply #86 on: December 29, 2010, 20:23:19 pm »
FD,
I hope Jeff doesn't mind ... but comparison numbers are available here: http://cal-look.no/lounge/index.php/topic,5367.0.html
Another excellent thread ...
The difference between his street port (50mm int) and the pro port (56mm int) were a flow improvement of 20-23% in the .500 to .600" range.
Take care,
TxT
« Last Edit: December 29, 2010, 20:25:26 pm by TexasTom » Logged
ugly duckling
« Reply #87 on: December 29, 2010, 23:35:40 pm »
yea still in the STONE AGE on this proceder. some body has to work hard for there bread and butter. at least the SUN don't shine through my angles.  Wink. .UD .
ugly duckling
« Reply #88 on: December 30, 2010, 06:52:06 am »
UD.
ugly duckling
« Reply #89 on: December 30, 2010, 07:01:47 am »
next blend chambers with blend valves. UD .
