October 12, 2026, 19:34:11 pm
| | |-+  My 65 race car
Pages: 1 ... 14 15 [16] 17 18 ... 32 Print
Author Topic: My 65 race car  (Read 709342 times)
Andy Sykes
« Reply #450 on: February 01, 2013, 19:57:19 pm »
Maybe I just make it flip up rather than over Smiley
« Reply #451 on: February 01, 2013, 23:43:15 pm »
Andy, you may want to fit a filler flap in the bonnet! It's a proper arse opening a flip front just to check the fuel level, and at some point you won't bother because you "know" there's plenty in. That'll be the pass you run out of fuel mid-track - ask me how I know... Embarrassed
Andy Sykes
« Reply #452 on: February 18, 2013, 21:03:17 pm »
lol i couldnt help it
ossh that should put out some boost maybe a bit big for a bug lol
cheers andy
71CALRIPPER
« Reply #453 on: February 19, 2013, 09:19:55 am »
Big enough for ya !!  Shocked
Andy Sykes
« Reply #454 on: February 23, 2013, 16:08:22 pm »
so i got my arse into gear this morning and finsihed tigging up the rear end as the new turbo stuff comes the end of the week and the engine should be here the week afetr so i can get going on some interesting stuff
so dropped of the rear end
welded it all back up and fitted it all back again
already for the engine to arrive now and get making the header and exhaust Smiley
cheers andy
fastbus
« Reply #455 on: February 23, 2013, 18:00:39 pm »
I'm looking forward to seeing the engine in the back with all your turbo system attached.
An epic build fella.
Top work!
13.66@102mph in my old T3 crew cab builders truck!
13.01@109mph in my bug so far!
Andy Sykes
« Reply #456 on: February 25, 2013, 11:30:57 am »
cheers mate thanks Smiley
small update picked up my oil cooler rads to test fit they have special core made at 45deg so i can put them in the rasied floor of the car Smiley
cheers andy
Martin
Cash Converter....
« Reply #457 on: February 25, 2013, 13:11:28 pm »
how long do you imagine the motor is going to run for in one go?
Will you have a thermostat on the oil coolers? As i think at the track getting Heat into the oil is going to be the hardest part.
Martin
Martin
www.taylormachine.co.uk
OFF/500
Andy Sykes
« Reply #458 on: February 25, 2013, 13:43:06 pm »
hi martin
i cant imagine the motor will run for long and yes i will be fitting a stat. I will be preheating the oil with a sump heater to bring it up to 90 degC before engine start up but i guess that will soon drop off if stood in the fire uplane for long, i did make some 12v heaters that worked well so i may fit those
cheers andy
Mike Lawless
« Reply #459 on: February 25, 2013, 15:45:52 pm »
I've been following along and everything looks great!
I do have an observation. I'd really like to see some additional gusseting on the forward suspension mounts on the chassis. You're going to be putting a lot of power through those, and the entire forward force of the driving wheels will be pushing forward at those points. They are under a lot of stress. Try to visualize the direction of force applied at those points and add some reinforcing accordingly.
Just a suggestion  Wink
2006 PRA Super Gas Champion
2002-2003 DRKC Champion
http://www.lawlessdesigns.com
Andy Sykes
« Reply #460 on: February 25, 2013, 18:08:42 pm »
hi Mike
thanks for your interest do you mean these ones?
cheers andy
Mike Lawless
« Reply #461 on: February 25, 2013, 18:19:53 pm »
Yes. Personally, I'd like to see some additional gusseting forward. If you imagine all that forward force pushing your car though those mounts, you could see that those little tabs could pull right off the tube. That wouldn't be a very pretty thing.
I just want you to be safe!
Andy Sykes
« Reply #462 on: February 25, 2013, 18:30:34 pm »
hi i see what you are saying but i do have one on each tube working in differnt directions if that makes sense, i will have to take another look at it maybe?
cheers andy
Andy Sykes
« Reply #463 on: February 27, 2013, 19:06:16 pm »
So the motor gets shipped tmw can't wait for it been waiting since August, the header size outcome it 2" I was hoping the turbo stuff would be here this week but tial have a back log on housings so looks like next week
Cheers Andy
dannyboy
« Reply #464 on: February 27, 2013, 19:20:24 pm »
good stuff  Smiley
8.77@156.8mph
O/FF 60
« Reply #465 on: March 01, 2013, 11:45:08 am »
excellent that its on its way Smiley
Hi Richie
I've just asked the question so lets see what comes back I don't want to waste my time building a header that's too small I do trust a 100% the person that told me to use this size but a second opinion can't hurt I guess
Cheers andy
Cheers Andy
That sounds more like what I would use,cool you got the correct info in the end,lesson here is only the engine builder can truely know what the best intake and exhaust solutions are Wink
Just for your info,I dont have any oil cooler on the new car,I heat the oil up in the pits,but generally it is cooler after a run than with the heater plugged in.I have driven it about 15mins on the road with no oil or engine cooling issues with alcohol based fuel
I have a cooler on the old car and it did need it after about 10miles or so in the heat of vegas or So cal in summer,but i really think you wont need them unless you try to go further than driving it to the track? Grin
Andy Sykes
« Reply #466 on: March 01, 2013, 21:08:53 pm »
Thanks Ritchie Smiley good info I'm over engineering as usual lol . tiny bit more as I'm waiting for the turbo stuff and motor  Roll Eyes
Only bit I can start on the header
Started on the last parts of the rear cage disconnection parts
Cheers andy
Andy Sykes
« Reply #467 on: March 04, 2013, 17:26:42 pm »
parts are arriving at last box of bends Smiley
billet alternator yes its over the top but i liked it lol,
and my engine gets to New York TMW ready to for the plane woo hoo cant wait to see pipes Smiley
cheers andy
Andy Sykes
« Reply #468 on: March 11, 2013, 12:33:41 pm »
so 7 months in the making and its arrived Smiley very pleased with it
RLR REV6 clutch
mechanical fuel pump
O-ring seals no gaskets
little inlet valve
so know we can get back on with the building woo hoo
cheers andy
71CALRIPPER
« Reply #469 on: March 11, 2013, 13:55:25 pm »
Andy you are one Lucky/Hard working chap !!
Martin
Cash Converter....
« Reply #470 on: March 11, 2013, 15:10:56 pm »
I bet that plain was over loaded, thats the second one to land withing a week!
Martin
OFF/500
Andy Sykes
« Reply #471 on: March 11, 2013, 18:17:13 pm »
i know the TNT driver wasnt impressed lol
started making plenum parts
and cut the first part of the headers
cheers andy
Martin
Cash Converter....
« Reply #472 on: March 11, 2013, 18:53:13 pm »
keep it so you can get into the top of the motor as fast as posible, and un-cap the rods.
You'll need to be checking the state of the bearings after each meeting.
I can be into my rod bearings within 45 mins. and I find that a pain. if i didnt have to unclip the turbo and chute bracket i'd be all done in 30 mins, ready to put it back together.
Martin
OFF/500
Basti
« Reply #473 on: March 13, 2013, 17:31:34 pm »
Andy,
it looks really nice!
But why a mechanical fuel pump??
RLR REV6 clutch
little inlet valve
cheers andy
- black 62 cal look beetle
- Pro Mod Race car
Andy Sykes
« Reply #474 on: March 13, 2013, 18:46:19 pm »
Hi it's going to be a meth engine and I will need a lot of it   Cry so a mech pump can flow a lot of fuel and the electric ones are £ compared
Cheers andy
« Last Edit: March 13, 2013, 19:05:43 pm by fast65 » Logged
Basti
« Reply #475 on: March 13, 2013, 19:04:19 pm »
but a mechanic Pump is also using a Lot of power!!
cheers,
basti
- Pro Mod Race car
Andy Sykes
« Reply #476 on: March 13, 2013, 19:07:41 pm »
Hi I'm not to bothered about the power it will use the oil pump will use enough lol it also has the advantage if the the engine stops so does the fuel
Cheers andy
« Last Edit: March 13, 2013, 19:36:58 pm by fast65 » Logged
Martin
Cash Converter....
« Reply #477 on: March 13, 2013, 19:28:52 pm »
cheers,
basti
they consume very little
Martin
OFF/500
Mike Lawless
« Reply #478 on: March 13, 2013, 19:32:23 pm »
Is that an Enderle pump Andy? Do you know the output?
A mechanical pump doesn't use that much power. The advantage is that output goes up with rpm. You can probably use smaller injectors that you would with an electric pump because the fuel pressure can be higher at higher rpm
When we went to mechanical injection a few years back, we didn't see a loss of performance because the pump was driven off the motor. We actually saw better performance because of the increase in bottom end torque that methanol makes.
Andy Sykes
« Reply #479 on: March 13, 2013, 19:38:23 pm »
I'm not sure I got it from Pauter mario knows the spec so I hope so lol
