October 12, 2026, 13:34:23 pm
| | |-+  My 65 race car
Pages: 1 ... 25 26 [27] 28 29 ... 32 Print
Author Topic: My 65 race car  (Read 708413 times)
cassa
« Reply #780 on: July 01, 2014, 09:08:13 am »
Whats was wrong with the Burns collectors? Looks like a lot of work.
Andy Sykes
« Reply #781 on: July 01, 2014, 20:07:51 pm »
Nothing wrong they are very nice just wanted to make my own but, I've put Lots of hours in it  but didn't like the outcome so I've binned it lol so I will start again
Andy Sykes
« Reply #782 on: July 05, 2014, 21:32:27 pm »
Bit more today on the rear hubs machining bits off that are not needed and pulling out the old bearings
So I've found out this is common on the 997 when trying to tack the hub out it splits the bearing
Removed the porsche hand brake shoe retainers and the disk back plate lugs
Re bored the holes paralel as the hubs will be sitting at a different to a 997 and I don't want the helm joints to bottom out
This is were the knuckles I made will be used
Removed the ABS sensor so I can fit a Hall effect sensor in place for traction control as they respond quicker than the magnetic sensor
Cheers Andy
« Last Edit: July 05, 2014, 22:36:46 pm by Andy Sykes » Logged
Black_65
« Reply #783 on: July 05, 2014, 21:49:30 pm »
This build gets better and better every time I see a new update  Grin
Top work Andy (of corse lol)
Andy Sykes
« Reply #784 on: July 07, 2014, 21:18:44 pm »
Thanks this may yet end up on the stupid idea shelf lol
Its a bit boring but I've machined the hubs on the bottom two to removed the angles and put the at 90deg to the car and also gain some travel as the hubs will sit a lot lower than they would on a 997 so I was worried about bind and I also wanted to get rid if the taper ball joints
I've used m14 x 1.15 same as porsche wheel studs this large nut I have made so I can attach the liner sensor to measure suspension travel
Bit of clearancing
Bottom stud and spacer
Cheers Andy
« Last Edit: July 07, 2014, 21:22:03 pm by Andy Sykes » Logged
Andy Sykes
« Reply #785 on: July 13, 2014, 19:30:44 pm »
So I've still been busy
Made these for a fellow racer
Tapped out the old hole for the ABS
Machined one of the front hubs and fitted magnet with South facing out to the sensor
And now for some weld porn
Turbo inlets
Pedals for the pedal,box
Cheers Andy
Andy Sykes
« Reply #786 on: July 15, 2014, 22:47:38 pm »
Trial fitted the pedal box
And this bit works
Cheers Andy
« Reply #787 on: July 16, 2014, 09:31:23 am »
Those pedals look very close together to me, or is it the pic angle?
Lee
Andy Sykes
« Reply #788 on: July 16, 2014, 23:31:18 pm »
Lee
They are close but I only need one
Thanks it's a task building this lol
Charge cooler pics
Bit more on the flip out glovebox cover
Andy Sykes
« Reply #789 on: July 27, 2014, 07:42:29 am »
Not much of an update but changing bearing on the front hubs was a pain as one of the retaining bolts snapped in the hub then a drill bit Sad
Didn't beat me new bearing in
Front abs sensor is different to the rear
And also found to that boxster spindles are different to the cayman
Stripped the top of a 12v denso alternator down
This is the regulator all small surface mount stuff with a custom voltage comparator it looks like so I will build another regulator to fit in the box to the alternator produces 19.5 volts open circuit so it charges at about 18 volts for the cars 16volt system
Cheers Andy
« Last Edit: July 27, 2014, 07:44:42 am by Andy Sykes » Logged
« Reply #790 on: July 27, 2014, 19:18:18 pm »
WOW Andy -- Great stuff
vwhelmot
« Reply #791 on: July 27, 2014, 22:21:07 pm »
That's some lovely alli welding there.
« Reply #792 on: July 28, 2014, 07:00:17 am »
X2  Wink
Andy Sykes
« Reply #793 on: July 28, 2014, 22:35:54 pm »
Thanks guys  Grin
Nothing much on the car today thought I better get on with race car transporter No II
As the weather is nice
Rear tub off  its on air and and 4 link did this a while back
Down
Up
Going to build a flat bed for the back 20" rims and twin stacks to let the V8 noise out
Cheers Andy
Andy Sykes
« Reply #794 on: July 29, 2014, 21:44:48 pm »
Bit more main frame is tacked in starting on the lockers tmw and tyre rack
Cheers Andy
Andy Sykes
« Reply #795 on: July 30, 2014, 21:52:06 pm »
Bit more going on mocked up the twin stacks going raw from headers back
Started on the shifter for the sequential   transmission this will be auto sniffed from the ecu when the car is working and dialled in
Cheers Andy
Andy Sykes
« Reply #796 on: July 31, 2014, 21:05:05 pm »
Little bit more on the shifter I've a fair  bit yet to do reverse lever etc
Cheers Andy
« Last Edit: July 31, 2014, 22:51:41 pm by Andy Sykes » Logged
Andy Sykes
« Reply #797 on: August 02, 2014, 07:37:54 am »
Bit more done
Just over 1kg or 2lbs 4oz
And at last got the coding to work properly for the switches (video)
Cheers  Andy
Andy Sykes
« Reply #798 on: August 05, 2014, 21:30:40 pm »
So a bit more I had already made the cylinder for something else so just a bracket to make and test for the chute release
Video
Still got material to machine off yet but the while thing comes in at 315g so far
Cheers Andy
Andy Sykes
« Reply #799 on: August 08, 2014, 22:53:28 pm »
So I've shown some of his before in the R&D days but it works no need for 110v stuff
Start at this
90 mins later
So it works lol 12vdc @ 20 amps to heat 6.8l or 1.5 gallons of oil
Temp sensor
Cheers Andy
« Reply #800 on: August 11, 2014, 12:06:23 pm »
Andy
any idea how hot do the glow plugs get in free air? just wondering if they will burn the oil by getting to hot as its impressive how quick they warm it up
Like the chute release set up Cool
Andy Sykes
« Reply #801 on: August 11, 2014, 12:23:25 pm »
hi
im not sure how hot they would get in free air but they would glow red and burn out if left too long.
I did test them straight in oil and it did look as it may burn it. Then I made the heater pockets that are welded into the tank and that stopped any bubbling around the heater. Ive been testing them for the last 3 days for 5 hours at a time keeping the oil at 70 Deg and they have been fine so far no burn out at all.
cheers andy
« Reply #802 on: August 11, 2014, 14:05:40 pm »
hi
cheers andy
sounds like good R&D there then Cool
Peter Shattock
« Reply #803 on: August 11, 2014, 18:58:47 pm »
Hi Andy,
Very pleased to hear you have been doing all this testing to check it works given I have stolen your idea having done no R&D at all........
Hopefully I'll be doing some of my own to back up your results in just over a month though
Thanks Peter
Andy Sykes
« Reply #804 on: August 11, 2014, 21:32:34 pm »
Steal away mate it's flattering lol It works 100% and I don't think they will burn out quickly as the heat is taken away quickly even it they do no need to drain oil just swap one out 2 mins work.
Andy Sykes
« Reply #805 on: August 20, 2014, 22:13:13 pm »
First plug failure today after 35 hours of use so I'm happy with that 2 minute job to change a £3 part
Wheelie bar wheel in production
More stupid ideas to come
Cheers Andy
Andy Sykes
« Reply #806 on: August 21, 2014, 20:44:35 pm »
so this but is a bit of and experiment but I think it will work its going to be a sensor that will measure the force on the wheelie bar to record how hard and fast  the bar is being used to the bar can be adjusted up or down
this is the MK1
it will fit to the top tube and then to the car and be solid so wont move as it will he hydraulic and measure the force on the bar
cheers andy
Andy Sykes
« Reply #807 on: August 22, 2014, 21:58:52 pm »
Nothing major but made the acetal tyre today much harder to machine than I thought is was like trying to make it from pasta lol and I still need to remove the burs and sharpen that drill bit lol
Andy Sykes
« Reply #808 on: August 23, 2014, 19:52:42 pm »
Made the air shifter cylinder today happy how it turned out
Bit of weight to come out yet but happy so far
Cheers Andy
Rocket Ron
It's old school for a reason
« Reply #809 on: August 24, 2014, 07:46:00 am »
weldathon today 8 hours of cutting and welding and its 80% welded up just got to find some air bags so i can start on the axles Smiley
cheers andy
Andy
Been looking back at this build and the amount of work / hours you have done is amazing.
loving the trailer but I think any trailer over 750 kg  has to be tested by vosa to be legal and be covered under your insurance. This was being phased in over by the eu from 2012 onward so it may be worth checking your construction / completion dates
Nice build by the way
« Last Edit: August 24, 2014, 07:54:46 am by Ron Elliot » Logged
13.12 @ 101.84
Grooving out on life
