July 23, 2026, 01:42:24 am
| | |-+  My 65 race car
Pages: 1 ... 6 7 [8] 9 10 ... 32 Print
Author Topic: My 65 race car  (Read 677814 times)
Andy Sykes
« Reply #210 on: June 20, 2012, 16:51:09 pm »
Bit more done bump stops from a series II landrover
Managed to get the rear brakes apart as sent off for re-drilling so fingers crossed I can have the trailer on it's feet by Friday If the air bags come tmw
Cheers andy
Andy Sykes
« Reply #211 on: June 22, 2012, 16:46:54 pm »
THE WHEELS ARE ON !!!!
hubs drilled out to to 5 x130
wheels on
air bags just arrived and just what i wanted Smiley
bag in just got to mount the bottom mount
on up one down
im happy so far as its turned out and havent changed my mind once so far lol
it worked out as i wanted its nose heavy so when i put the body on should be good
cheers andy
Fasterbrit
« Reply #212 on: June 22, 2012, 21:52:32 pm »
Jeez... Is your middle name Kingdom, by any chance? You could lay that chassis across the Tamar and charge tourists a couple of quid to get into Cornwall Smiley
www.air-kraft.com
www.marcomansiperformance.com
Andy Sykes
« Reply #213 on: June 23, 2012, 07:43:43 am »
Lol over engineering at its best  Tongue
Cheers andy
Andy Sykes
« Reply #214 on: June 23, 2012, 11:59:44 am »
Bit more done this morning got the air bags in fingers crossed I may be able to get some up and down action going on on Monday Smiley
Wheels I'm using so far
Cheers Andy
« Reply #215 on: June 23, 2012, 13:59:41 pm »
Andy,
I am not going to comment on the trailer build as I have no idea on legistlation etc,but one thing that does concern me is the use of the porsche wheels,although they are undoubtedly a strong wheel,trailers have trailer wheels for a reason,I would be really worried about them failing when using them in a way not intended,the weight and load you want to subject them to seems way beyond what they were designed for,is this something you have considered at all?
Andy Sykes
« Reply #216 on: June 23, 2012, 16:43:16 pm »
Hi Richie I have thought about it I haven't got to the bottom of it yet these wheels can take 550 kg each as far as I can find out, I'm defiantly going to look further into it before the car goes in
Cheers andy
dannyboy
« Reply #217 on: June 23, 2012, 19:05:30 pm »
its only going 3 miles just avoid potholes Grin
8.77@156.8mph
O/FF 60
Andy Sykes
« Reply #218 on: June 23, 2012, 20:07:42 pm »
5.5 actually to the pod lol, I think with the trailer on I should do that on a gallon :)C
« Last Edit: June 23, 2012, 20:11:59 pm by fast65 » Logged
Andy Sykes
« Reply #219 on: June 25, 2012, 17:45:56 pm »
the mother of all hitchs has arrived Smiley
and i had time to play with the air ride Smiley
up
http://youtu.be/nETysdYJVok
http://youtu.be/R9U2C1aPTP8
http://youtu.be/UpBCxfamWNI
unload
http://youtu.be/1d23nM6bZjk
seems to lift and work fine i have to add the elctrical control and pnematics yet to give it some finer control
cheers andy
Andy Sykes
« Reply #220 on: June 27, 2012, 16:30:53 pm »
Bit more done mounted the hitch I've got to put some larger through bolts in when they arrive
Started on mounting the master cylinders needs a bit more work on the linkage as I'm not happy with this part yet
Consulted my parts emporium and found 4 matching shocks
And fitted those so now it doesn't bounce anymore fingers crossed the brake tube etc will turn up tmw so I can get on with that
Cheers andy
Andy Sykes
« Reply #221 on: June 28, 2012, 18:22:03 pm »
Welded the receiver in place it's SWP was 300 bar so 150 psi should be no problem Smiley
Knocked up some brackets for he body to weld too
Now with the shocks on I can also get the rear set of wheels off the floor to help with turning the trailer Smiley
Brakes tmw then fingers crossed I can paint the chassis ready to fit the body next week Smiley
Cheers Andy
Richyrich
« Reply #222 on: June 28, 2012, 23:38:01 pm »
Great work Buddy, Cant wait to see what she runs on the 1/4.  Grin.
Andy Sykes
« Reply #223 on: June 30, 2012, 10:57:29 am »
Me too Smiley
Bit more done yesterday
Started on cleaning up the calipers ready for painting on Monday Smiley
No work for the rest of the weekend as my trailer has been used as lighting storage lol
Cheers andy
Andy Sykes
« Reply #224 on: July 02, 2012, 17:33:59 pm »
bit more done calipers blasted and painted and hung out to dry
fitted the legs
then started on some of the containment for the pnematics and electrical
the plug turned up for the lights it worked out well that i could tap it out to 20mm conduit size
while i was raiding the stores i found some 15mm conduit so ive used that for the fender supports
the pnematic valve also arrived so i can start plumbing that in as well soon be time for paint then put the body on then back on with the car
cheers andy
Andy Sykes
« Reply #225 on: July 03, 2012, 17:49:27 pm »
bit more done today brakes on Smiley
couldnt bleed them as sombody has my bleeding kit  Grin
fitted the jockey wheel so it moves about know Smiley
cheers andy
Fasterbrit
« Reply #226 on: July 04, 2012, 07:26:37 am »
It may be a perspective trick, but will your trailer actually fit through the workshop door?  Shocked
www.air-kraft.com
Andy Sykes
« Reply #227 on: July 04, 2012, 08:23:40 am »
lol it deffo its out its the perpective my dogs in the picture are realy great Danes Tongue
cheers andy
« Reply #228 on: July 04, 2012, 11:09:01 am »
Andy
So as this isnt The caravan& trailer forum Cheesy as amazing as your effort and skills in creating this trailer,whats happening with the car? and particularly the engine? I know you ordered some parts a few months ago now so what have you got,have you actually finalised the engine specs?
Andy Sykes
« Reply #229 on: July 04, 2012, 11:14:11 am »
crank is on its way, ordering this lot next week
MS230 4" complete pair with ti valves:
Five stud rockers complete pair:
7075 billet dual taper PR:
Raptor cam kit custom:
Piston kit 4" JPM/JE custom:
F1 throttle body kit:
marco has got do sort a case and then we can build the engine car goes for paint end of next week then we can have some shiney pictures:)
cheers andy
« Reply #230 on: July 04, 2012, 13:52:55 pm »
cheers andy
Wow thats some list,are you going N/A now? reason I ask is why the F1 throttle body kit on a turbo car? doesnt make sense to me to spend all that money on something that isnt needed,and will surely complicate the install and set up,a single throttle body runs 7s,and also will cruise all day long if needed?dont get me wrong if thats what you want to use go for it Smiley
Who are you having build it? yourself? or maybe someone with lots of real experience with those parts like Johannes?
At this point I am not sure what you are aiming for? drag race car? street & race car? circuit car? but with the constant evolution of this car you are doing for your wife Wink I am not sure you are now either Grin
Andy Sykes
« Reply #231 on: July 04, 2012, 14:34:29 pm »
hi riche
its a full out drag car, the reason for me using the F1 bodies is the whole intake system from the turbo onwards is set up that already i did think of going to a single but it would cost a few K to do that, Marco is going to build and tune the engine i dont mind making anything but im not messing with all that money on parts lol
cheers andy
« Reply #232 on: July 04, 2012, 18:51:02 pm »
hi riche
cheers andy
Cool,that must be some intake if its more than those f1 throttle bodies Shocked
Good luck with it,as you say its alot of money in parts for someone to ruin by not knowing what they are doing
Andy Sykes
« Reply #233 on: July 04, 2012, 19:52:09 pm »
Well nearly as much to change  Roll Eyes
Plenums are going to be cylindrical know
Cheers andy
« Reply #234 on: July 04, 2012, 20:57:49 pm »
Cheers andy
Single throttle body would fit perfectly in there between the  chargecooler and Y pipe
Andy Sykes
« Reply #235 on: July 04, 2012, 21:23:53 pm »
Good idea I'm not sure I would like it up there in the car surly I won't get any bennifit of the plenums ?
Cheers andy
cassa
« Reply #236 on: July 04, 2012, 22:49:22 pm »
I have never understood the design/shape of your plenums.
Is the a aerodynamic thinking- teory behind the design that I dont understand??
 I would rethink the inlet design, make it short and with a minimum use of bends. Sharp edges make for turbulence.
Is the turbo matched for your engine setup?
Reg C
« Reply #237 on: July 04, 2012, 22:59:00 pm »
Cheers andy
I am certainly not an expert on this but the way i see it the plenum is between the valve and the throttle plate,afterthat[or before that really]its just the intake manifold
Andy Sykes
« Reply #238 on: July 05, 2012, 09:35:45 am »
Reg C
hi the reson for them being that shape was i was using cooling and the turbo was going in a different place as usal i changed my mind so these will be cylindical now
cheers andy
Andy Sykes
« Reply #239 on: July 05, 2012, 18:58:35 pm »
Nearly there now so I can stop boring you all with the trailer build
Hand brake 80% done just got to make the handle and fit the gas spring
Nearly there with the air suspension I didn't use the valve I was going to use as I found this from a range rover I've managed to work out what does what so I can fit that tmw and get it working it also has a 12v compressor that work ok Smiley
Limit switches for height control
Cheers andy
