October 23, 2026, 20:29:39 pm
How much money to run 10s in a street car?now with part2, The evolution to turbo
24
25
26
27
36
Topic: How much money to run 10s in a street car?now with part2, The evolution to turbo (Read 1460839 times)
Re: How much money to run 10s in a street car?
Reply #720 on:
September 10, 2015, 19:36:46 pm »
Got some nitrous jets in the mail today so will be able to tune out the over richness now and see what difference that makes, also moved the seat so as to make it fit me better, will see if it helps at all in 2 weekends time
Paul Bahnstormerz
Reply #721 on:
September 11, 2015, 12:07:10 pm »
Are you taking much ignition timing out when on the gas? If so what are you using, the fuel injection computer?
Reply #722 on:
September 12, 2015, 10:56:04 am »
Quote from: Paul Bahnstormerz on September 11, 2015, 12:07:10 pm
Hi Paul
Yes I did take 3 degrees out to be safe, just did it on the map all the way through the last two columns, I can wire it and program the ECU to do it automatically but its another thing that can go wrong so taking it out already is better right now.
Paul Bahnstormerz
Reply #723 on:
September 12, 2015, 12:39:45 pm »
Quote from: richie on September 12, 2015, 10:56:04 am
Hi Paul
Oh the joys of ECU, how the hell is my old 010 going to do this lol
dannyboy
Reply #724 on:
September 12, 2015, 15:37:16 pm »
Quote from: Paul Bahnstormerz on September 12, 2015, 12:39:45 pm
Hi Paul
by removing it and other stuff and fitting efi
8.77@156.8mph
O/FF 60
Reply #725 on:
September 12, 2015, 17:03:37 pm »
Electronic module inside instead of points that then fires a MSD box would be my best guess
Steve D.
Reply #726 on:
September 12, 2015, 17:09:02 pm »
Quote from: richie on September 12, 2015, 17:03:37 pm
You don't even need to get that complicated, you can trigger the MSD with points (white MSD wire goes to points). As a bonus, your points will now last forever since there is no power going through them, the MSD only uses them as a ground signal.
Über Alles
10.77 avg. on pump fuel.
238I
Reply #727 on:
September 12, 2015, 18:35:31 pm »
Quote from: Steve D. on September 12, 2015, 17:09:02 pm
Perfect, didn't think of that, sounds right up your street Paul? old school looks still
Paul Bahnstormerz
Reply #728 on:
September 13, 2015, 15:43:15 pm »
That's pretty much the method I'd come up with, was going to double spring the points to stop them bouncing too.
Steve D.
Reply #729 on:
September 13, 2015, 16:50:48 pm »
Quote from: Paul Bahnstormerz on September 13, 2015, 15:43:15 pm
I did that too, it made the rubbing block snap off. Granted that was after about 10,000 miles, but it did leave me stranded for a while (the old used points set I had were robbed of their spring so I could double up the new set!)
Über Alles
238I
K-Roc
Reply #730 on:
September 14, 2015, 16:04:24 pm »
Zebra Stripe points have a stiffer spring. Still available if you search for em
cameron shorey
Reply #731 on:
September 14, 2015, 21:39:09 pm »
Quote from: K-Roc on September 14, 2015, 16:04:24 pm
They're old style Rabbit/Golf points.
I have the Bosch part number as 1 237 013 116.
Horsepower, reliability, cheap... pick two.
Paul Bahnstormerz
Reply #732 on:
September 15, 2015, 14:30:46 pm »
Thanks will look into these zebra stripe points
Reply #733 on:
September 17, 2015, 13:03:30 pm »
Both cars are loaded up ready for a weekend at Santa pod, its the national finals and will be final outing for either car this year so hope weather will be kind and we can get some good runs in both classes, I am running cabrio in Super comp as usual and Nitrous 67 in Super street[ 10.90 index] hoping to run well under index in both cars
It was this meeting in 2003 that I ran my 1st 10s, 10.88 was best so want to beat that at least
There will be a live feed for those who want to watch in, you can access it and all info from here
http://www.eurodragstereventcoverage.com/santapod/live/2015uknationalfinals/default.asp
Shane Noone
Reply #734 on:
September 17, 2015, 15:05:43 pm »
Good Luck Richie, weather looks very promising at the mo' for some fast times and pb's ! Hope you get to run the numbers, be a great way to see out the 2015 season !
Shane.
Reply #735 on:
September 18, 2015, 06:21:54 am »
Thanks shane, off out the door now
Reply #736 on:
September 18, 2015, 07:24:39 am »
Good luck and nice weather :-)
www.Udobeckertuning.de
Reply #737 on:
September 18, 2015, 09:18:18 am »
Quote from: richie on September 17, 2015, 13:03:30 pm
Good luck Richie and pedal to the metal! The live feed above + dragweek + a live feed from Kjula this weekend = plenty fun!
-K-
Reply #738 on:
September 18, 2015, 15:54:17 pm »
It is indeed interesting to watch the live feed. I have NEVER seen anyone polishing, cleaning and checking the track as much as the crew at Santa Pod. After every pair they go out on the track and spray it with cleaner and wipes it off. Impressive indeed!
-BB-
Jo Clifford
Re:
Reply #739 on:
September 19, 2015, 11:30:25 am »
First pass, crap 60ft, spun the tyres, 10.73 @ 122.5
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
Reply #740 on:
September 19, 2015, 13:23:03 pm »
Must be a challenge running 2 cars at 1 event?
See the other car ran an 8.13
Jo Clifford
Re:
Reply #741 on:
September 19, 2015, 15:20:43 pm »
Second pass bogged off the line, 10.98 @ 120mph, number 1 qualifier - whoops!!
Reply #742 on:
September 19, 2015, 17:47:34 pm »
Oh... what happened? High wheelie then hard left.
One interesting thing since I`m looking at both Kjula and Santa Pod. 10 pairs at Santa Pod equals 3-4 pairs at Kjula. We all know that the Swedes are a bit slow... but dam!
-BB-
Andy Sykes
Reply #743 on:
September 19, 2015, 18:26:43 pm »
Electrical fault we've fixed it ready for tmw
Jo Clifford
Re: Re: How much money to run 10s in a street car?
Reply #744 on:
September 19, 2015, 19:20:50 pm »
Quote from: BeetleBug on September 19, 2015, 17:47:34 pm
-BB-
Last pass shook a wire loose, which cut ignition, easy fix, both cars are ready for tomorrow
Jo Clifford
Reply #745 on:
September 19, 2015, 19:23:52 pm »
Quote from: leec on September 19, 2015, 13:23:03 pm
First run with each car was the only tight one, as Richie was going up the track in the cab they were calling the class for the '67 to the lanes so he drove the cab back & jumped straight into the '67 and actually was the first one in the lanes for that class
dannyboy
Reply #746 on:
September 19, 2015, 19:24:19 pm »
good stuff guys
8.77@156.8mph
O/FF 60
Reply #747 on:
September 19, 2015, 19:27:41 pm »
Quote from: Jo Clifford on September 19, 2015, 19:23:52 pm
Hahaha! Good one.
Reply #748 on:
September 19, 2015, 20:23:08 pm »
That's a great way of hot lapping
Reply #749 on:
September 20, 2015, 16:03:46 pm »
10.423 - 124.5 mph. Job well done Richie and Co!
-BB-
24
25
26
27
36
