July 15, 2026, 10:58:16 am
352232 Posts in 28932 Topics by 6923 Members
| | |-+  How much money to run 10s in a street car?now with part2, The evolution to turbo
Pages: 1 ... 15 16 [17] 18 19 ... 36 Print
Author Topic: How much money to run 10s in a street car?now with part2, The evolution to turbo  (Read 1323703 times)
spoolin70
« Reply #480 on: February 10, 2015, 20:05:18 pm »
Thanks for the info - much appreciated.
I got a puma shroud (I think) for cheap that I'm planning to use. No doghouse or outlets. It's pretty beat up though so I've got no problem massaging it with a hammer - it's even got filler round the outside  Huh
Keep up the good work
Darren
« Reply #481 on: February 11, 2015, 19:21:44 pm »
Got a couple of hours yesterday and today on it, lots of boring rust removal and finally some new metal going back in, I had to fit everything at the back to get the Hookys bumper mounts in the correct place.
Rear apron/valance is now removable as well, at least it looks like a car rather than a pile of rust now Grin
« Reply #482 on: February 11, 2015, 20:05:57 pm »
Sounds silly but it really looks like a car now, i'd be sat in it on a box making car noises  Grin
Pedalpusher
« Reply #483 on: February 12, 2015, 07:00:28 am »
Are those by any change the day moulding rear fenders as you sell them?
Man the fit is just spot on!
BR
-Mikko-
« Reply #484 on: February 12, 2015, 09:54:58 am »
BR
-Mikko-
Yes just bolted on, I have one hole that needs opening upwards slightly on the wing as it only lines up half way to the body nut but that is all I will have to do to them
« Reply #485 on: February 16, 2015, 14:03:33 pm »
Small update, all structural welding done on body so separated it from pan, finished the framehead repairs to pan and stripped all the old paint, underseal and seal sealer of it and prepped it for some paint, its now got a good coat of satin black on it and is currently drying, next I will build the pan up ready to go back under the body.
Its booked in to have the cage fitted in about 3 weeks so got to keep at it Shocked
henk
« Reply #486 on: February 16, 2015, 15:06:40 pm »
floorpan looks clean.
are you not going to use one of your fiberglass '67 declklids to, gain some weight?
henk!!!
« Reply #487 on: February 16, 2015, 15:54:15 pm »
henk!!!
Yes but I didn't have one with hinge panel with captive nuts in to hand so just used the metal one for mock up, helps me make sure I got it all aligned up right & straight as well
« Reply #488 on: February 16, 2015, 16:33:28 pm »
Bloody hell Richie, slow down! You're making me look bad for being so slow with my build!
« Reply #489 on: February 16, 2015, 18:50:03 pm »
I did I went to Cornwall then Scotland for a few days a week ago, now get you arse in gear and get it done Cheesy
dannyboy
« Reply #490 on: February 17, 2015, 08:52:52 am »
sayers and doers....  Cheesy
8.77@156.8mph
O/FF 60
« Reply #491 on: February 17, 2015, 19:22:47 pm »
today more doing and less saying just for you Danny Grin  Got the afternoon free so got some done
Rear torsions[27mm used] and spring plates set up, then jaycee retainers fitted[used]
2x fuel lines fitted in tunnel, new shift rod bush then shift rod in
Beam bolted on, arms and hubs fitted, steering all cleaned and stuff I hadn't already painted got a coat of black then fitted
also found this horror hidden under a generous layer of underseal and skim of silicon sealer, the plate wasn't even really welded on that covered the hole!!!!
dannyboy
« Reply #492 on: February 17, 2015, 19:52:05 pm »
where did you exit fuel lines at rear of tunnel? going to put mine in this weekend and was tinking about nice neat places to bring them out
8.77@156.8mph
O/FF 60
« Reply #493 on: February 17, 2015, 19:54:22 pm »
Next to where hockey stick out of trans goes into car, on drivers side of it opposite to clutch and throttle cable tubes
dannyboy
« Reply #494 on: February 17, 2015, 20:07:59 pm »
yeah i got a load of shift rods sticking out there lol i think i might bring them out the side of the tunnel using  bulkhead fittings as anything behind b post is boxed in so tecnicly outside cab area so should be ok for regs i think
8.77@156.8mph
O/FF 60
« Reply #495 on: February 17, 2015, 20:40:03 pm »
Yep after firewall its all free to do what you want
broen messiaen
« Reply #496 on: February 17, 2015, 21:09:55 pm »
looks good!
what size did you use for the fuel lines? will you use press couplings on themore just slide a rubber hose on then?
« Reply #497 on: February 17, 2015, 21:18:13 pm »
looks good!
They are 1/2inch, I am putting -8 tube nuts and sleeves on each end to convert it to the braided hose fittings I am using elsewhere
« Reply #498 on: February 17, 2015, 22:49:24 pm »
Those JayCee retainers.
I always wanted to know if you could use those on the street, aren t they prone to wear?
« Reply #499 on: February 17, 2015, 23:00:55 pm »
I have them on the old cab and haven't seen any issues but it doesn't do 1000s of miles a year so not sure how they will hold up yet, have heard of failures in very short time but never figured out why when mine are good after 6 years or so
« Reply #500 on: February 17, 2015, 23:40:54 pm »
OK thanks Richie for always sharing information.
« Last Edit: February 18, 2015, 08:12:29 am by Eddie » Logged
Chip
« Reply #501 on: February 18, 2015, 03:55:56 am »
What are you planning to run for fuel pump and regulator? A1000? 044?
« Reply #502 on: February 18, 2015, 09:01:42 am »
I have a magna fuel reg that couldn't keep up with the new cabs demands so using that, and pump is a generic 911turbo cheap[£40] repo that just comes in a brown box, used them before but will have to see if it can supply enough for everything
« Reply #503 on: February 18, 2015, 17:07:38 pm »
Hit a small problem, need a rear bearing retainer and spacer for IRS rear if anyone has got one of each and can post it to me asap? then the pan can roll on its wheels again Cool
« Reply #504 on: February 18, 2015, 20:39:40 pm »
Front end is on the ground!!!!
 Rear is nearly done, just those couple of things going to hold me up getting it on 4 wheels
« Reply #505 on: February 18, 2015, 21:26:39 pm »
Hi Richie,
I will see if Alex Taylor has the bits ou need. If he does I will post them to you tomorrow first class
« Reply #506 on: February 18, 2015, 21:32:29 pm »
Hi Richie,
Thanks Lee
Elnef
« Reply #507 on: February 19, 2015, 06:16:43 am »
"Its booked in to have the cage fitted in about 3 weeks so got to keep at it"
Why not weld the rlr cage in it your self you have up for sale ?
great speed on this project now  Smiley
« Reply #508 on: February 19, 2015, 08:18:03 am »
We sold it Cheesy  but to be honest I prefer the skills of someone like Jim when I put my safety in the trust of the cage, knowing those welds will hold is great peace of mind Cool
oilyT
« Reply #509 on: February 20, 2015, 00:43:13 am »
Great build  Cool.  where did you source the 1/2 in ali fuel pipe ? i'm going to be looking for some soon. Smiley
