October 13, 2026, 02:46:46 am
Show pictures of your very own Cal Lookers guys
31
32
33
34
92
Topic: Show pictures of your very own Cal Lookers guys (Read 3716064 times)
too old for this
Re: Show pictures of your very own Cal Lookers guys
Reply #930 on:
October 17, 2008, 21:38:45 pm »
Quote from: Tim C on October 15, 2008, 10:09:56 am
Quote from: streetvw on October 11, 2008, 08:21:27 am
Quote from: monkiboy on October 11, 2008, 00:27:37 am
is that blue 56 the one that now lives in the UK
(too old for this/greenhearts)
I think the car that too old has used to belong to pip out of the guana batz
It did yes.
This is Alex "Too Old's" car... 56 Oval.
now with new interior,new motor,new gearbox,new mounts,new breathing and cooling.......maybe next year after owning it two years I will finally get to drive the f**kin thing
JG54
67worshipper
Reply #931 on:
October 17, 2008, 22:32:23 pm »
i know what you feel like alex
id like to use mine but completed at the wrong time.would like to do more on it over the winter but would like to drive it before doin it otherwise i can see it all apart next year.just need to stop meddlein
vw hot rod heaven
Reply #932 on:
October 18, 2008, 00:13:45 am »
Quote from: too old for this on October 17, 2008, 21:38:45 pm
Just make sure there's no one new behind the wheeel, dude
Your car looks beautiful BTW
too old for this
Reply #933 on:
October 26, 2008, 20:46:23 pm »
It is getting veeeeery close Sarge,looking forward to it actually being all up and together for the first time in years
JG54
Reply #934 on:
October 26, 2008, 20:52:31 pm »
Quote from: too old for this on October 26, 2008, 20:46:23 pm
What's left to finish??
alfie the monster
Reply #935 on:
October 27, 2008, 00:30:56 am »
And being in my rear view mirror next year
JG54 Grunherz
Reply #936 on:
October 27, 2008, 12:27:22 pm »
Quote from: alfie the monster on October 27, 2008, 00:30:56 am
too old for this
Reply #937 on:
October 27, 2008, 13:38:10 pm »
Quote from: Sarge on October 26, 2008, 20:52:31 pm
Hey Sarge......last winter I pulled the interior,fitted Race trims new door cards and rear drop in panel,retrimmed in tuck'n'roll,red leather(makes a change from fat biscuit)and fabbed a show cage with cross bar with tabs to take the new Simpson Platinum harnesses.Pulled the holley pump and reg(kept overfuelling)and ran new hardline and cb rotary.She went to the volksworld show and picked up a top twenty.Still running like a bag of shit though,also picked up a new pro comp with saw axles and new kennedy clutch cheap,the mechanics on this car seem to have been swathed in mystery since it left Cali,some of it really wasn't so clever and to be honest the first attempt at the engine build over here ,still left room for improvement,so she was trailered down to Pete's(Funkenblitz)and for the first two weeks it did get blitzed,between Pete Randy and me doing the donkey work,the old box got ripped out,new later nose cone mount fabbed in ,Berg mid and modded Bug Pack rear cradle.Box now sits super level and probably 3/4" further forward,will make getting the engine in and out much easier.The new box was cleaned and painted,Pete had the saw axles polished re-assembled and the car is back on the ground....Then it all went wrong,picked the motor up to check a small leak from the Jaycee tubes,and it was like the Exxon Valdez,flywheel oil seal,various points on the case,rear pulley,time for a little look,first the heads off and next thing he has it in half,pitted lifters at 500 miles,new crank,showing minor signs of picking up.....the list is long,but fortunately caught in time....next comes a lay off to raise the money,I wasn't expecting this having just had the motor built elsewhere,it wasn,t a bad build,just sloppy and for the motor to last,worth rectifying the sloppiness.Heads now re-ported,case spot faced,compression raised ,crank polished and balanced,pistons match weighted,Tin wear(pretty paint,shitty fit)being replaced with welded strengthened new tin.Left to do?rebound stops,ditch the serp pulley(read too much bad on these on big motors)re-do the third progression hole(been drilled too low)and run in.Over the winter the new motor will come out to allow me to mig up all the unecessary holes in the firewall(looks like swiss cheese)and repaint the engine bay,engine back in and FINALLY,after being in England for 4-5 years,on the road getting ragged around.Oh and Alfie?
?he can be in front ......until he rear ends the old girl in the compact,or lights them up on a drain cover
,me? I'll just roll steady
JG54
Reply #938 on:
October 27, 2008, 15:16:36 pm »
...."Last winter I pulled the interior,fitted Race trims new door cards and rear drop in panel,retrimmed in tuck'n'roll,red leather(makes a change from fat biscuit)and fabbed a show cage with cross bar with tabs to take the new Simpson Platinum harnesses.Pulled the holley pump and reg(kept overfuelling)and ran new hardline and cb rotary.She went to the volksworld show and picked up a top twenty.Still running like a bag of shit though,also picked up a new pro comp with saw axles and new kennedy clutch cheap,the mechanics on this car seem to have been swathed in mystery since it left Cali,some of it really wasn't so clever and to be honest the first attempt at the engine build over here ,still left room for improvement,so she was trailered down to Pete's(Funkenblitz)and for the first two weeks it did get blitzed,between Pete Randy and me doing the donkey work,the old box got ripped out,new later nose cone mount fabbed in ,Berg mid and modded Bug Pack rear cradle.Box now sits super level and probably 3/4" further forward,will make getting the engine in and out much easier.The new box was cleaned and painted,Pete had the saw axles polished re-assembled and the car is back on the ground....Then it all went wrong,picked the motor up to check a small leak from the Jaycee tubes,and it was like the Exxon Valdez,flywheel oil seal,various points on the case,rear pulley,time for a little look,first the heads off and next thing he has it in half,pitted lifters at 500 miles,new crank,showing minor signs of picking up.....the list is long,but fortunately caught in time....next comes a lay off to raise the money,I wasn't expecting this having just had the motor built elsewhere,it wasn,t a bad build,just sloppy and for the motor to last,worth rectifying the sloppiness.Heads now re-ported,case spot faced,compression raised ,crank polished and balanced,pistons match weighted,Tin wear(pretty paint,shitty fit)being replaced with welded strengthened new tin.Left to do?rebound stops,ditch the serp pulley(read too much bad on these on big motors)re-do the third progression hole(been drilled too low)and run in.Over the winter the new motor will come out to allow me to mig up all the unecessary holes in the firewall(looks like swiss cheese)and repaint the engine bay,engine back in and FINALLY,after being in England for 4-5 years,on the road getting ragged around..."
I had to ask, didn't I??
Man, what an ass whipping. Take heart though, BIG FUN is just around the corner!
So, the only way Alfie strikes the tires is on a man-hole cover
... WTF??
Tim C
Reply #939 on:
October 27, 2008, 15:33:11 pm »
Hey too old,
Just make sure you don't do this again when it is running!
The muffler above was red hot and too old accidently brushed his leg past it - resulting in a burning of his leg (nice scar now!) and the smell of burning skin on Neal's 3" muffler! - yes that is skin
ouch
JG54 Greenhearts
Reply #940 on:
October 27, 2008, 15:37:25 pm »
That HAD to hurt!!!
Kinda like chichen skin on a BBQ, right?
empicolector
EMPI RULES
Reply #941 on:
October 27, 2008, 15:48:01 pm »
Quote from: Tim C on October 27, 2008, 15:33:11 pm
Hey too old,
ouch
karmann77
Reply #942 on:
October 27, 2008, 15:50:43 pm »
Not quite mine but my fathers, which means i get to drive it all the time!!! its a recent purchase and been a respected car my myself since the mid 90's.
Recently had a new 2276 motor fitted and still in the process of running in.
Reply #943 on:
October 27, 2008, 16:12:59 pm »
Nice!!
alfie the monster
Reply #944 on:
October 27, 2008, 16:33:36 pm »
Quote from: Sarge on October 27, 2008, 15:16:36 pm
... WTF??
Nope, but it's a good way to break things launching over wet drain covers
JG54 Grunherz
too old for this
Reply #945 on:
October 27, 2008, 19:26:25 pm »
Quote from: Sarge on October 27, 2008, 15:37:25 pm
That HAD to hurt!!!
Some people have the Das Drag Day plaque to remind them......I got the branding to remember it by
didn't hurt too much,but then Bitburg beer and Jagermeister is a cool pain suppressant
JG54
karmann77
Reply #946 on:
October 27, 2008, 23:22:38 pm »
Heres another shot that was taken on friday,
Reply #947 on:
October 27, 2008, 23:30:21 pm »
Nice car!!!
peach_
Reply #948 on:
October 29, 2008, 20:22:04 pm »
Didnt realise Gaz had sold this.
Hows that wallklet built engine?
Is the bug still local to stoke?
hope your enjoying it, always loved this car when it was in the club
SAS RENN-WAGENS
and proud
#CALLOOKDRAGS
karmann77
Reply #949 on:
October 29, 2008, 21:28:06 pm »
Hi peach, the engine is fine now that Jon has adjusted a few things for me, its now running alot better, just need to get some miles done then we can open up the taps
We live in Congleton so not far at all, also think your the guy that bought Pauls 66, he's a very good friend of mine and i helped a liitle with the 66.
Anyway mate nice to meet you
Jim M
Reply #950 on:
October 30, 2008, 06:41:16 am »
I built it for my girlfriend (now wife) in 1983 she bought it, but stolen and stripped in 1984
Porters Precision
Jim M
Reply #951 on:
October 30, 2008, 06:44:36 am »
I built this in '86-'87 and still drive it today.
Porters Precision
peach_
Reply #952 on:
October 30, 2008, 20:04:34 pm »
Quote from: karmann77 on October 29, 2008, 21:28:06 pm
Cool
Are you think of bring it to a Renn-wagen meet?
Yeh i did but the Java 66, got a few plans for it this winter
SAS RENN-WAGENS
and proud
#CALLOOKDRAGS
Reply #953 on:
October 30, 2008, 20:30:25 pm »
Quote from: Jim M on October 30, 2008, 06:44:36 am
the car was featured in hot vws in late 90's
karmann77
Reply #954 on:
October 30, 2008, 21:56:15 pm »
Quote from: peach_ on October 30, 2008, 20:04:34 pm
Cool
Yes i will bring it over to the meet
Jim M
Reply #955 on:
October 31, 2008, 01:30:17 am »
Quote from: speedwell on October 30, 2008, 20:30:25 pm
Never featured anywhere.
Porters Precision
jamiep_jamiep
Reply #956 on:
November 06, 2008, 13:27:34 pm »
Quote from: karmann77 on October 27, 2008, 15:50:43 pm
Hey Matt, hows it going? Bug looks cool! You'll find plenty of other pictures of it around here somewhere! look forward to giving you a run for your money up the strip next year if you fancy it...
Seeya soon bud
Jamie
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
karmann77
Reply #957 on:
November 08, 2008, 00:05:57 am »
Quote from: kaferboy on November 06, 2008, 13:27:34 pm
Seeya soon bud
Jamie
Hi Jamie, im fine mate, got tons of old pics from streetvw, a liitle strip action sounds good, also just debating what to do with the motor in the ghia, keep it auto or swop to big power
driving an auto is so nice and easy but a spin in the 67 puts a smile per mile
Chuck Fryer
Reply #958 on:
November 14, 2008, 00:26:03 am »
I took the ghia out for what I think was the last time this fall, since snow is coming in soon! I thought, what is a cornpanzer car without corn? So here ya go. The other shot is just a cool looking old brick building in here in town.
lawrence
Reply #959 on:
November 14, 2008, 00:46:20 am »
Car looks good, Chuck! My friend let me drive his 58 ghia to a burger meet once and the entire drive I was thinking to myself that I would not mind owning one.
"Happiness is a Hot VW!"
31
32
33
34
92
