August 24, 2026, 09:13:42 am
352280 Posts in 28948 Topics by 6923 Members
| | |-+  Show pictures of your very own Cal Lookers guys
Pages: 1 [2] 3 4 ... 92 Print
Author Topic: Show pictures of your very own Cal Lookers guys  (Read 3652676 times)
BABOON
SCC Official
« Reply #30 on: August 16, 2006, 23:41:58 pm »
This is a pic of my 1950 with Calparts and a set of Blue Streaks
BABOON
SCC Official
« Reply #31 on: August 16, 2006, 23:43:39 pm »
This is my sleeping racer. Hope it will be running for SCC. It is a 1953 Switter with a 2332cc engine
BABOON
SCC Official
« Reply #32 on: August 16, 2006, 23:49:14 pm »
And a teaser of my latest project
BABOON
SCC Official
« Reply #33 on: August 17, 2006, 00:15:16 am »
Here is my girlfriend Therese`s (aka TESSA) daily driver. It is a 1973 1303. This was our ride to DDD 3 and 4
« Last Edit: August 17, 2006, 13:30:20 pm by BABOON » Logged
BABOON
SCC Official
« Reply #34 on: August 17, 2006, 00:17:59 am »
She also has a 1958 ragtop that has Calparts and a hot IDA engine Grin Grin
« Reply #35 on: August 17, 2006, 08:07:53 am »
Shit Baboon... stop bragging please  Grin
Turtle001
« Reply #36 on: August 17, 2006, 08:29:56 am »
houba houba houba
nice collection baboon!!
respect!
http://turtle.skynetblogs.be
Jordy/DVK
« Reply #37 on: August 17, 2006, 10:24:55 am »
 Man I wish I had a girlfriend with such a car!!! I would spend all my time with her...        ( I mean the car ofcourse...  Grin )
  "The Full-Throttle Cruisers"
Christoph
« Reply #38 on: August 17, 2006, 12:59:03 pm »
@ baboon
nice collection, especially your calparts split!
hope you will show us more pics of your new project car  Grin
64 RCR
« Reply #39 on: August 17, 2006, 13:09:26 pm »
Engine Specification of 64RCR: (2332cc)
Auto Linea Pent Roof Aluminium clearanced case (by CB Performance),
8-Dowelled 84mm Scat Volksracer Forged Crankshaft,
94mm Mahle Stroker B&P, c/w Total Seal rings,
CB Performance H-Beam Super Race rods c/w 5/16”ARP2000 Bolts,
Scat Lightweight Cam Followers,
Webcam 86C clearanced Camshaft,
CB Performance Steel Straight Cut Cam Gears,
Manton Chromoly Pushrods, with high lift flared push rod tubes,
Scat 1.4:1 Pro Rocker kit assembly,
44x37.5mm CB Performance Wedgeport Cylinder Heads
(CNC ported, 3-Angle Valve Job, with 9.7:1cr / 59cc @ 1.25mm deck,
VW Speedshop Long valve Head conversion with Manley Valves, springs and Titanium retainers),
Gene Berg 30mm Oil pump & relief cover / Sump / Full Flow System,
Gene Berg Oil Breather box,
200mm 12lb Chromoly Lightened Flywheel,
Kennedy Stage II (2100lbs) pressure plate, c/w Daikin heavy duty clutch,
Dual Twin 48IDF Weber Carburettors c/w Ported CB Big Beef intake manifolds (165mains, 42mm venturi),
CSP Carburettor Linkage,
CSP Carbon Fibre Porsche 911 Fan Conversion kit c/w Induction Boxes,
MSD Ignition System (Billet Distributor, 6AL Unit, Blaster 2 Coil),
VW Speedshop 1-3/4” Stainless Merged Header (Large Flange),
VW Speedshop 2-1/2” Stainless Muffler (Large Flange),
Gene Berg Engine Traction Bar,
Gene Berg Gearbox front support mount c/w Funkenblitz Ali mounts,
Kafer Brace.
Engine output (flywheel) as obtained on Taylor Machine Services Dynometer:
186.3 bhp @ 6500 rpm   -   177.2 lb/ft torque @ 4500 rpm
Gear Box Specification:
Built by Rancho Transmission, Anaheim, California.
Solid Mounted ProDrag unit (close ratio 3rd/4th)
Fitted with Bugpack 4 spider super diff, Dual heavy duty aluminium side plates, welded 3rd and 4th gears, steel shift forks 3.78 1st, 2.21 2nd, 1.58 3rd, 1.19 4th and Klinkenberg 3.88 ring and pinion, Erco chromoly mainshaft, chromoly pinion retainer, Timken pinion bearing conversion, heavy duty steel caged bearings, Stock welded and Fully gusseted case.
Sway-A-Way race axles with short tubes.
Best ¼ mile time so far: 12.5 @ 103mph (with muffler, belt & slicks)
0-60mph: 3.7 seconds
« Reply #40 on: August 17, 2006, 21:35:54 pm »
Hello guys,
These are some pictures of my first VW Bug, it's also my very first car! Not a bad way to start do you think?  Grin
The car is from januari 1964.
It's now @ the local garage. They will put another 1200cc engine in it, and make the whole car 12v. They also put Flat4 BRM's on it. I want to make it Old school cal look. The front will be lowered with dropped spindels. Rear wil be stock, only bigger tyres, 195/65/15.
Sander/DVK
« Reply #41 on: August 17, 2006, 23:29:50 pm »
Hi Jesse, welkom to the Lounge.
Great to hear that your bug goes Callook! Wink
Only 195/65 tires are a little bit small, I would choose for 205/65 or 205/70 on a 5,5J rim.
If you still want the 195/65 tires, I have 2 tires if you intressed. There Firestone offcourse!
stuur maar een pbtje bij intresse Wink
Cheers,
Sander
JO TYPE 3
« Reply #42 on: August 21, 2006, 17:19:27 pm »
Hi there, my 1st post here.
Here's another austrian Cal Looker!
My granadared '67 modell A notchback
« Reply #43 on: August 21, 2006, 18:04:08 pm »
Holy motherfucker!  Shocked
That's one of the sexiest notches i've ever come accross  Cool
Please post some more pics will ya?
And what kind of bullet mirror is that? Aftermarket? ...
Cheers,
p.s. are those 205/70 tyres on a notch?  Roll Eyes wicked  Grin
Rocket-Racing
« Reply #44 on: August 21, 2006, 21:02:46 pm »
Nice notch! Some cars are just "right".. Killer stance!
« Reply #45 on: August 22, 2006, 00:14:15 am »
This thread is better than any book!! Great cars folks...!!!
Felix/DFL
« Reply #46 on: August 22, 2006, 11:03:39 am »
Hi folks,
hey very nice cars here!!! Even my first post...
Is it notch time Huh
I really like the notch from Walter 205/70 really work! Greetings to austria :-)
But even 195/65 look fine with matching "flat" front tires (145/65R15)
My 67 notch sits on early 5.5 and 6 fuchsys with 1776 in the back
Nose down that`s what its all about :-)
http://images.thesamba.com/vw/gallery/pix/158490.jpg
http://images.thesamba.com/vw/gallery/pix/156527.jpg
Best greetings to all ya mad heads,Felix
Tim C
« Reply #47 on: August 22, 2006, 12:05:43 pm »
My UK 63....
Loving those notches...  Cool
JG54 Greenhearts
JO TYPE 3
« Reply #48 on: August 22, 2006, 20:11:23 pm »
A few pics here: http://www.luftboxer.com/members_walter.htm
Mirror housing is aftermarket, the adjustable part comes from an original "Talbot" mirror.
Wheels are 145/80 on 5,5" front and 205/70 on 6" Fuchs rear
Engine is a 1776 cc
'Walter
« Reply #49 on: August 25, 2006, 01:27:48 am »
here's my little baby - not your typial looker  Wink Cheesy my mates 63 is a bit more traditional  Wink
Red 66
« Reply #50 on: August 25, 2006, 03:56:41 am »
Hi......
This is my red 66
Silversoar
« Reply #51 on: August 25, 2006, 21:20:46 pm »
My 1958 vert powered by a 2276cc IDA and a close ratio tranny.
Next Year iI'll be at SCC...
More on my website http://silversoar.twinpeakboxers.com/
/Thomas
Endre
-61 Ghia Coupe
« Reply #52 on: August 25, 2006, 21:44:51 pm »
Very nice.........I like it. My next car will be like this one.
Endre
erikaa
« Reply #53 on: August 26, 2006, 01:03:06 am »
First post.
My 56.
Frank LUX
Back...Soon...hopefully!!!
« Reply #54 on: August 26, 2006, 09:08:31 am »
Here is my 1960 Ragtop With 2276cc and 48IDA's...
Frank
Frank LUX
« Reply #55 on: August 26, 2006, 09:13:58 am »
Here's my Other CAR...
Frank
Turtle001
« Reply #56 on: August 26, 2006, 15:23:12 pm »
nice rides frank! i still luv that blackbomber!
Olaf A./DFL
« Reply #57 on: August 26, 2006, 19:26:59 pm »
First post.
My 56.
hi erikaa -welcome to the lounge -is this the old car of the guy that did bugstar.net? really nice one!
TomR
« Reply #58 on: August 27, 2006, 21:00:42 pm »
"The devil is in the details"
Olaf A./DFL
« Reply #59 on: August 27, 2006, 21:08:47 pm »
 Shocked Shocked Shocked Shocked
