September 02, 2026, 22:40:26 pm
352300 Posts in 28955 Topics by 6923 Members
| |-+  For sale!
| | |-+  4" Bore Aluminium case by Jeff Denham / Shawn Geers.
Author Topic: 4" Bore Aluminium case by Jeff Denham / Shawn Geers.  (Read 4466 times)
UltraOrange67-2443
« on: August 15, 2017, 09:38:16 am »
New aluminium case.
Flange seal cut and sand seal front.
Cleared for 90mm stroke.
BMW Bearing mod (bearings fitted) for use with all T4 main.
6 stud, 4 x 10mm 2 x 8mm per Cylinder (case savers fitted deep!)
Bronze thrust conversion (you will need shims to suit your crank)
all mains shuffle pinned.
To#¤ta thrust can be fitted to suit your crank for extra cost.
Lots spent.
£1000 or swap for Italian 48 IDA's.
Cheers, Nick
https://www.thesamba.com/vw/classifieds/detail.php?id=2085051&
Pics ^^^^
« Last Edit: August 15, 2017, 22:01:38 pm by UltraOrange67-2443 » Logged
1967 1200 2920cc EFI
« Reply #1 on: August 15, 2017, 22:42:16 pm »
What's the reason for selling? What barrels is it bored for?
dannyboy
« Reply #2 on: August 15, 2017, 22:52:23 pm »
4"?
8.77@156.8mph
O/FF 60
« Reply #3 on: August 15, 2017, 23:02:27 pm »
4"?
I know that, but different barrels measure outside different. Mahle and AA may be slightly different for example
UltraOrange67-2443
« Reply #4 on: August 15, 2017, 23:37:32 pm »
I have had both AA and Pauter machined to fit.
It is best to machine your Cylinders to fit the case.
I can get you Dia measurement on Thursday.
Change of plan  Wink
UltraOrange67-2443
« Reply #5 on: August 21, 2017, 21:21:46 pm »
Lots of interest in the 4" bore case and Strip dom Heads!
