September 23, 2026, 08:59:43 am
Technical stuff
Berg cam gear mod
Topic: Berg cam gear mod (Read 11395 times)
alex d
Berg cam gear mod
September 08, 2017, 08:44:37 am »
anyone tried it, did it make a difference? it makes sense in paper
Glauco
Re: Berg cam gear mod
September 08, 2017, 11:11:04 am »
I can believe it reduces oil slung, but doesn't it make the teeth a lot weaker as well?
There's less surface to take the power, or doesn't it matter that much?
glauco
Tufty65
September 08, 2017, 13:13:07 pm »
I'd like to know how much of an increase in horsepower that actually would make, plus if you're chasing minimal horsepower gains like that why not just use a straight cut cam gear which saves hp anyway and removes thrust loads on the cam bearing and you don't have to bother with machining.
Outlaw Flat Four 35
12.64 @ 106.25mph
dragvw2180
September 08, 2017, 14:04:45 pm »
We used a set of old Magnum straight cut gears that were narrowed by a Pro Stock team . I am not sure why they did it but it apparently did not effect the strength of the gear as we are using K800 valve springs on this turbo engine .
Last Edit: September 08, 2017, 14:11:15 pm by dragvw2180
September 10, 2017, 14:43:21 pm »
it is the same idea as the groves in your tires to clear the water. it works, but on a cam gear this may be in the 'marginal gains' corner. that said i would do it if my engine was still apart
RhoadsVW
September 10, 2017, 20:31:48 pm »
I did it back n the seventies and on the dyno saw no difference
Der Renwagen Fuhrers
September 15, 2017, 07:26:45 am »
It might free up a few milli-hp. Not measurable with any dyno, though.
70slooker
hello
September 18, 2017, 06:38:47 am »
I got one in the engine, so far the biggest gain has been another number to my forum post count
Zündfolge Car Club
