September 27, 2026, 05:36:40 am
Hot rod drag week 2019, 2 x aircooled turbo VWs at least
5
6
Topic: Hot rod drag week 2019, 2 x aircooled turbo VWs at least (Read 191965 times)
Re: Hot rod drag week 2019, 2 x aircooled turbo VWs at least
Reply #150 on:
March 30, 2020, 03:39:36 am »
I fixed it
samotorsport
Reply #151 on:
March 30, 2020, 07:32:44 am »
Looking great ! Nice to see it back on its wheels !
henk
Reply #152 on:
March 30, 2020, 09:06:43 am »
Nice,like nothing ever happend.
Henk!!!
Airspeed
Reply #153 on:
March 30, 2020, 11:23:58 am »
Wow, supernice again!
Read you also rebuild the motor? What did you find/alter?
Reply #154 on:
March 30, 2020, 13:38:30 pm »
Excellent news, glad to see it back. You going to do drag week again?
Reply #155 on:
March 30, 2020, 14:22:35 pm »
Glad to see you are back at it...
brewsy
Reply #156 on:
March 30, 2020, 15:40:33 pm »
Quote from: Eddie on March 30, 2020, 14:22:35 pm
DITTO... :-)
Reply #157 on:
March 30, 2020, 18:29:34 pm »
Amazing. Great job
Reply #158 on:
March 30, 2020, 21:32:00 pm »
looks like it never happened!
Tucson vw
Reply #159 on:
March 30, 2020, 21:47:34 pm »
Planning on doing Cory Mac race in October? Good to see it back together !!
Reply #160 on:
March 31, 2020, 20:27:10 pm »
What's next?
Reply #161 on:
March 31, 2020, 22:57:48 pm »
Quote from: Airspeed on March 30, 2020, 11:23:58 am
It was mainly good, slight sign of detonation from when fuel pressure dropped but everything was ok to use again, I have got the bearings coated this time as it works so well in other car so will be interesting to see how they work, and a different dry sump pump which gives more clearance to pulley so i was able to go up a bit in pulley size and get fan ratio better but nothing else changed.
Reply #162 on:
March 31, 2020, 23:00:37 pm »
Quote from: Neil Davies on March 30, 2020, 13:38:30 pm
Quote from: j-f on March 31, 2020, 20:27:10 pm
What's next?
Right now no idea as everything is so unpredictable so will most likely do nothing race wise this year now
Reply #163 on:
March 31, 2020, 23:06:44 pm »
Some pics of the work I did
Reply #164 on:
March 31, 2020, 23:26:41 pm »
And
gkeeton@zbzoom.net
Reply #165 on:
March 31, 2020, 23:34:24 pm »
Did you ever find a definitive answer of what caused the issue?
Reply #166 on:
April 01, 2020, 10:39:03 am »
thats next level!
Airspeed
Reply #167 on:
April 01, 2020, 11:20:42 am »
Its such a sleeper! Love it!
Reply #168 on:
April 01, 2020, 15:35:25 pm »
Quote from: gkeeton@zbzoom.net on March 31, 2020, 23:34:24 pm
No, can't be 100% sure, but most likely is a injector o ring failure as log showed a pressure drop but then it was stable at the lower pressure
brewsy
Reply #169 on:
April 01, 2020, 17:12:25 pm »
Quote from: richie on March 31, 2020, 22:57:48 pm
Nice.
Autometer(?) and 2 stage or is there a 3rd 'inside' the normal oil pump bit?
Ta
Reply #170 on:
April 01, 2020, 17:58:54 pm »
Quote from: brewsy on April 01, 2020, 17:12:25 pm
Nice.
Ta
Its a Dailey pump like i use on other car[ except that one is belt driven] and yes another stage inside case scavenges through stock pick up tube
5
6
