November 01, 2026, 16:56:37 pm
Latest Member: thunder_bac
| | |-+  Red Zeppelin 67
Pages: 1 2 [3] 4 5 ... 12 Print
Author Topic: Red Zeppelin 67  (Read 406579 times)
jay c
« Reply #60 on: June 07, 2019, 22:34:40 pm »
Didnt know how far the rust had travelled behind the body mount panels so thought the best thing was to remove them and check [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #61 on: June 07, 2019, 22:40:44 pm »
jay c
« Reply #62 on: June 07, 2019, 22:48:55 pm »
It wasnt too bad but there was some small repairs to be made and some repairs from before i owned it that had been done badly that would need re-doing properly [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #63 on: June 07, 2019, 23:11:21 pm »
To get the rear crossmembers out and to do a few other jobs we needed to seperate the body from the pan.Not that easy when you're this limited for space. Just enough room to get the body up and roll the pan out. And the garage door can still close. Result Grin [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #64 on: June 07, 2019, 23:15:19 pm »
Interesting view [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
H67bug
« Reply #65 on: June 08, 2019, 07:24:32 am »
Great pics to follow- thanks
jay c
« Reply #66 on: June 08, 2019, 14:22:21 pm »
Cheers Heydon Cool
vwhelmot
« Reply #67 on: June 08, 2019, 21:01:46 pm »
Shit area to fix, who’s repair panels did you use?
jay c
« Reply #68 on: June 08, 2019, 22:18:19 pm »
The rear crossmembers are the later genuine Vw ones that I got shipped over from the states. Couldn’t get decent early ones then. At least now you can get good ones from klassic fab.
karl h
« Reply #69 on: June 10, 2019, 11:17:23 am »
love your thread, thanx for taking the time to post
jay c
« Reply #70 on: June 10, 2019, 19:56:15 pm »
Thanks Karl. Lyndon, wasn’t sure if you was asking about the crossmembers or the body mount panels. As it’s a 67 ,it would be a one year only panel which no one makes(like everything else on a 67) so we used late bug (heritage) for the large backing panel and early body mounts from hooky. It looked right and Hooky’s mounts are much stronger than stock ones
vwhelmot
« Reply #71 on: June 10, 2019, 21:22:02 pm »
I was asking about the cross members , it took me a while to source a pair of genuine body cuts and those needed plenty of work to make them right. Top darts, I’m enjoying the thread, brilliant work especially considering the lack of room etc. Keep the updates coming
jay c
« Reply #72 on: June 15, 2019, 21:44:58 pm »
The car is not going to have heaters so while the shell is up we removed the heater pipes and painted the inside of the channels [ Attachment: You are not allowed to view attachments ]
« Last Edit: June 16, 2019, 19:05:49 pm by jay c » Logged
jay c
« Reply #73 on: June 15, 2019, 21:51:08 pm »
Crossmembers and offending rot removed [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #74 on: June 15, 2019, 21:59:33 pm »
New genuine vw crossmembers. Heater holes will be welded up [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #75 on: June 15, 2019, 22:04:07 pm »
Fitted [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #76 on: June 15, 2019, 22:14:29 pm »
the shrinker/stretcher we bought was really handy for making a piece to repair part of the lower arch [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
« Reply #77 on: June 17, 2019, 22:15:41 pm »
Really is inspirational work. I'm envious of your skills!  Cool
jay c
« Reply #78 on: June 18, 2019, 13:10:28 pm »
Thanks Keith ,that means a lot. I think we done alright considering mine and Mattys day jobs are not related in any way to cars or engineering or anything like that. Just a self taught hobby.
The Lounge build threads have been inspirational and the owners very helpful with advice (namely Lyndon and Danny Gabbard among others) and talking to people like Simon Emery from the Paintbox and watching Ron Covell DVD’s has taught us plenty. Still always asking questions though  Grin
jay c
« Reply #79 on: June 22, 2019, 21:58:24 pm »
turning to the pan for a while [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #80 on: June 22, 2019, 22:17:30 pm »
removed the heater cables and tubes and welded up the outlets and did the same to the rear section of fuel pipe as it wasn't going to be used. Also added a frame to hold the oil cooler. You can also see the sections of the roll cage that attach to the frame horns that allow for separation to remove the body [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #81 on: June 22, 2019, 22:25:57 pm »
spot welds drilled out and cuts made to gain access to inside of the tunnel [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #82 on: June 22, 2019, 22:36:46 pm »
Teflon fuel line fitted in the tunnel. Rear end exits under the shiftrod/transmission coupling [ Attachment: You are not allowed to view attachments ] and from underneath [ Attachment: You are not allowed to view attachments ]
Stevo_L
« Reply #83 on: June 25, 2019, 21:07:42 pm »
i'm curious why the exit is at the bottom of the pan..?
why not on top?  Huh
jay c
« Reply #84 on: June 27, 2019, 20:39:01 pm »
Just for ease of access to the fitting. The oil cooler is to one side plus oil thermostat , torque bar and roll cage mounts. The fitting is on the part that slopes up so it is still tucked up out of the way but easily reachable.
jay c
« Reply #85 on: June 30, 2019, 16:39:11 pm »
[ Attachment: You are not allowed to view attachments ] fitting the other end was quite tricky through the access hole in the end of the framehead. Small hands and long arms help Grin.  [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #86 on: June 30, 2019, 16:47:47 pm »
The teflon fuel line was cable tied to the clutch cable tube. The center section of the original fuel pipe was left in place for added rigidity to stop vibration [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #87 on: June 30, 2019, 16:52:45 pm »
At some point while working on the body, i had to chuck a tarpaulin over the pan as a sudden snow storm hit..Wish i had a bigger garage but work goes on... [ Attachment: You are not allowed to view attachments ]
« Reply #88 on: June 30, 2019, 17:15:27 pm »
True dedication right there jay Cool
jay c
« Reply #89 on: July 13, 2019, 21:32:01 pm »
More evidence of bad repairs by previous owner [ Attachment: You are not allowed to view attachments ] straight doner piece [ Attachment: You are not allowed to view attachments ]
