October 02, 2026, 12:00:12 pm
| | |-+  Red Zeppelin 67
Pages: 1 ... 4 5 [6] 7 8 ... 12 Print
Author Topic: Red Zeppelin 67  (Read 391116 times)
jay c
« Reply #150 on: August 31, 2019, 22:49:29 pm »
jay c
« Reply #151 on: August 31, 2019, 22:52:04 pm »
jay c
« Reply #152 on: August 31, 2019, 22:59:52 pm »
Also wanted to make a mounted tube for the speedo cable [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
Straight Time
« Reply #153 on: September 03, 2019, 12:48:29 pm »
What a great build.
Just read from the start and inspired.
Keep em coming !!! Grin
No retreat, No surrender !
jay c
« Reply #154 on: September 07, 2019, 23:02:20 pm »
Cheers dude.If it inspires even one person to crack on with their project then thats a good thing.
Moving on with tidying the wiring, I wanted to hide the bit of wiring visible inside the footwell. [ Attachment: You are not allowed to view attachments ]
I cut a piece of tube that would be welded between the two holes that the wires could pass through. [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #155 on: September 07, 2019, 23:14:34 pm »
When replacing the mechanical fuel gauge with an electrical one the original sender cover no longer fits the new electrical sender. I modified the cover making it deeper to fit and not interfere with the wire and also made a small tripod to mount it to.A narrow tube was bent up that would hide the tank wire and secured in place with a tab that was held by one of the tank bolts. Everything would be painted the same colour as the tank [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
« Reply #156 on: September 08, 2019, 18:29:57 pm »
So you like anal then....as in anal attention... I mean to detail.  Grin
jay c
« Reply #157 on: September 10, 2019, 13:40:23 pm »
Difficult to tell if that’s a compliment or a terrible chat up line😂😂
karl h
« Reply #158 on: September 10, 2019, 13:51:36 pm »
what kind of sender did you use, the tube-type or the arm-type?
jay c
« Reply #159 on: September 10, 2019, 15:22:18 pm »
It was the arm type. Just the standard sender for a late model bug
jay c
« Reply #160 on: October 04, 2019, 22:26:51 pm »
Next we decided to delete the heater vents. Not only because it will look cool, but also as i was going to run the wiring loom in the roof and down the windscreen A-posts. I had already tried to run the wires with the heater tubes in place and got the wires jammed between the heater tube and the screen post and destroyed the wires getting them back out. So if the heater tubes were going to go, it made sense to lose the vents at the same time and smooth out the dash top completely [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] This would have been so much easier if i had done it before the roll cage was fitted Cry [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #161 on: October 04, 2019, 22:33:33 pm »
a lot of head scratching trying to work out how to make up the plates [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #162 on: October 04, 2019, 22:42:33 pm »
jay c
« Reply #163 on: October 11, 2019, 21:33:13 pm »
The final dash mod was to delete the radio hole. We cut out a bit larger so we could lose any distortion from the original radio hole stamping. [ Attachment: You are not allowed to view attachments ] Wasnt the easiest panel to clamp into place [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #164 on: October 11, 2019, 21:37:51 pm »
Welds ground down and a small bit of lead to finish [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #165 on: October 12, 2019, 22:23:42 pm »
Time to take a break from the body and show the seat frames some love [ Attachment: You are not allowed to view attachments ] I cut the rear bar off and welded in two lengths of tube. [ Attachment: You are not allowed to view attachments ] Then added some more tubes on top and bent up some tubes for the rear.Plus some mounting plates for the seats [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #166 on: October 12, 2019, 22:28:46 pm »
« Reply #167 on: October 13, 2019, 07:42:19 am »
Very nice,
Can I ask you what kind of red primer you use?
Arnoud
« Reply #168 on: October 13, 2019, 09:04:51 am »
Hi!
Just saw these pictures and after admiring the beautifull work I wondered how you made this panel?Did you use a panelbrake and then a shrinker?I have to make the same repairs due to bad seals and was wondering how you made these.
Keep up the good work!
Cheers,Arnoud
jay c
« Reply #169 on: October 13, 2019, 10:04:35 am »
Very nice,
hi Eddie. It was just a rattle an primer from my local motor factors. I think the brand was Hycote which you can also get from euro car parts. It was just used to keep any rust away until it was painted properly,where most of the red was removed
jay c
« Reply #170 on: October 13, 2019, 10:11:39 am »
Hi!
Cheers,Arnoud
Hi Arnoud. Yes I used a metal folder that I made myself and a Shriner/stretcher. These two tools were so handy in most of the panels that we fabricated.
Arnoud
« Reply #171 on: October 13, 2019, 11:27:41 am »
Thanks for the reply!-I'll going to have to be getting one then Grin Grin
Cheers,Arnoud
jay c
« Reply #172 on: October 20, 2019, 20:08:00 pm »
Im happy with the frames so Matty was going to see what he could do with the side covers [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ]
pieces taped in place [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #173 on: October 20, 2019, 20:11:25 pm »
Pieces tacked [ Attachment: You are not allowed to view attachments ] Some more pieces shaped and tacked in place [ Attachment: You are not allowed to view attachments ]
jay c
« Reply #174 on: October 20, 2019, 20:21:51 pm »
jay c
« Reply #175 on: October 20, 2019, 20:30:12 pm »
Just need to clean up the welds [ Attachment: You are not allowed to view attachments ] And a bit of paint. They will eventually be painted gloss black [ Attachment: You are not allowed to view attachments ]
« Last Edit: October 21, 2019, 06:40:04 am by jay c » Logged
VWGlassee
« Reply #176 on: October 20, 2019, 23:03:23 pm »
Wauw!  Shocked  Cool
jay c
« Reply #177 on: October 21, 2019, 20:40:43 pm »
« Reply #178 on: October 22, 2019, 18:37:27 pm »
Another detail I'd not noticed!
I'm not going to share this build thread with the kids at school just yet. They're building a '71 1200 Cal Looker but I think I'll wait til it's solid before I go mad on details!
Wout
« Reply #179 on: October 22, 2019, 19:49:05 pm »
Awesome build!
The seat undersite covers are super cool  Shocked.
gr
Wout
Aircooled vw's for life!
