October 12, 2026, 12:42:48 pm
| | |-+  TIKIMADness getting ready to go fast in 2015
Pages: 1 ... 16 17 [18] 19 20 ... 23 Print
Author Topic: TIKIMADness getting ready to go fast in 2015  (Read 502845 times)
« Reply #510 on: November 16, 2010, 23:18:22 pm »
Go for it ! What a project....
tikimadness
« Reply #511 on: November 17, 2010, 16:33:59 pm »
Thanks Harry Wink
Michael
NIDGAFWYT
Jesse Wens
« Reply #512 on: November 19, 2010, 00:23:24 am »
Cu at scc then, we have plans to make a scc convoy from belgium, we'll pass holland anyway.
tikimadness
« Reply #513 on: February 13, 2011, 20:30:40 pm »
Finally had a little time to take the engine out.I thought it ran on3 cilinders the last time I started it so i wanted to take the engine out.
As soon as I took a valvecover of I saw theproblem,
Little damage on the rocker,
Here is the problem,
NOW I am having the head fixed and rebuild the engine.
We took the whole engine apart eand everything looks like new so I am happy with that
Michael
NIDGAFWYT
Ninho/DKM
« Reply #514 on: February 13, 2011, 22:18:41 pm »
S..T Happens Roll Eyes
1974 Superbeetle Porsche affected and influenced
1957 Gasser Project work in progress
1973 Thing type 181 Civil version (sold)
1959 Bug waiting attentions
1963 Surfin'Bird Street and Strip race Bug 1776cc Best E/T 14,769 at Hills Race#10
www.Surfinbirdbug.blogspot.it
www.Ninho-Reloaded.blogspot.it
« Reply #515 on: February 14, 2011, 22:56:33 pm »
Mike, (correct me if i'm wrong) are you using 103 cylinders ? If yes, who made the copper shims ?
tkcr,
Harry
mr horsepower
« Reply #516 on: February 14, 2011, 23:04:41 pm »
harry if you want a pair just call me and there not made of copper ,
copper is to soft and will srink and let the tension of the headstuds go lose.
gr henri
« Reply #517 on: February 14, 2011, 23:17:23 pm »
Henri, can you make them for 103's ? Also for 94's (T1) Lasercut? What material do you use ?
Thanks Duder  Cool
« Last Edit: February 14, 2011, 23:25:56 pm by Harry/FDK » Logged
tikimadness
« Reply #518 on: March 24, 2011, 20:41:39 pm »
I am still alive Cheesy
Made a throttle pedal so the cable hooks up on the passenger side of the car so I don't brake the cable with my heavy right food.
Also made a new bracket for the clutchslave which should be a lot stronger so it won't bent and replaced the plastic line with a steel one.
Michael
NIDGAFWYT
Paul da Graca
« Reply #519 on: March 25, 2011, 13:46:12 pm »
Hey Michael,
My 63 Ghia will be in Holland in June/July.  It will have my Turbo kit from AJ Sim on it.  So when the time comes I will call you and meet up to say hello and get some tips from you on a good setup here
Later
Paul
tikimadness
« Reply #520 on: March 26, 2011, 22:08:37 pm »
plumbed the slavecilinder today,
I think this willbe better thenthe plastic tube I used last year.
Michael
NIDGAFWYT
« Reply #521 on: May 23, 2011, 19:06:15 pm »
PM.
tikimadness
« Reply #522 on: July 17, 2011, 12:31:11 pm »
So it's been a long time since my last post but a lot has happend
I made it to Bug-in and had the chance to do some runs .
They weren't to bad but I expected a little more.
Found out that the car is to light in the front.In third gear it wants to go all directions but straight.
Also the front wasn't strong enough so by the time I was full in third gear the wind pushed the front down hitting the ground and bending it so the front fenders touched the wheels  Sad
So now I'm going to move the battery to the front and stiffen things up.
My best time was a 12.60 not the 11 I want for now but I think it will come in the future.
I also put the car in the dyno and managed to make one run.
299.9 bhp @6500 rpm and 367nm
This was a run where it leaned out in the secondary step of the holley.
The holley I'm using has a vacuum secondary so now I have to put a metering block in it to make the settings ajustable.
Michael
NIDGAFWYT
jamiep_jamiep
« Reply #523 on: July 17, 2011, 15:43:53 pm »
At least you're starting with something nice & light Michael, you can put the strength (and weight) back in only where its needed. I had a look at your car at EBI and it looked great. Sounds like it was a scary ride!
What was your terminal speed btw?
tikimadness
« Reply #524 on: July 17, 2011, 19:05:34 pm »
105mp/h
Michael
NIDGAFWYT
61ragtop
« Reply #525 on: August 24, 2011, 08:33:39 am »
Great to meet you and wolf at the weekend and hang out, car looks great Grin
Goona have a full read through today after yesterdays trip back to the uk (took 12 hrs due to delays)
Cheers james
mr horsepower
« Reply #526 on: September 21, 2011, 20:57:05 pm »
Tell the story Man!   Wink
tikimadness
« Reply #527 on: September 22, 2011, 20:49:43 pm »
Here goes, after 2 earlier tries on the dyno i finally got the carb to function like it should.
`Did a lot of runs and after turning up the boost to 1.3 bar the clutch started to slip with 385bhp and 425 nm Grin
going to try to keep it straight @ bitburg this weekend
Michael
NIDGAFWYT
tikimadness
« Reply #528 on: November 29, 2011, 22:34:52 pm »
It's been a long time since I updated this topic.
I only made one pass in Bitburg and it turn out to be on 3 cylinders .I had a valve seat gone loose Angry 20 + pulls on the dyne with no problem and on the last meeting of the year shit happens.
I took the engine apart and only one intake valve was slightly bent. I'm having all the seats renewed this winter to make sure it won't happen again.
I brought the car over to the Uk last week to have the cage redone and tagged so I should be able to race everywhere.
The car is at Jim Smith's shop right now for the cage and a bunch of other modifications and I'm very curious how it will turn out.
Michael
NIDGAFWYT
« Reply #529 on: December 07, 2011, 18:56:45 pm »
Michael, any news or pics ?
tikimadness
« Reply #530 on: December 09, 2011, 18:42:54 pm »
Hey Harry I've got some pics. Will try to post them.
Michael
NIDGAFWYT
tikimadness
« Reply #531 on: December 09, 2011, 20:14:38 pm »
 Sneak peak Grin
Michael
NIDGAFWYT
Andy Sykes
« Reply #532 on: December 09, 2011, 21:35:31 pm »
Looking good how's the cage coming on ?
Cheers andy
tikimadness
« Reply #533 on: December 09, 2011, 21:37:12 pm »
Cheers andy
You tell me Andy Grin Grin Grin
Haven't seen a picture of the cage yet. I think I'll get some pictures next week.
Michael
NIDGAFWYT
tikimadness
« Reply #534 on: December 15, 2011, 19:46:23 pm »
Got some pictures today of the progress of my car. My jaw dropped right to the floor when I saw those pictures Grin
Michael
NIDGAFWYT
« Reply #535 on: December 15, 2011, 20:11:31 pm »
Deaamn!
Andy Sykes
« Reply #536 on: December 15, 2011, 20:12:29 pm »
Looking good  Smiley top work
Cheers andy
« Reply #537 on: December 16, 2011, 00:41:57 am »
Micheal,looks really good,now all you need to do its throw away that boat anchor and get a nice type 1 with some EFI and you will be able to go as good as it looks Cheesy
cheers richie
tikimadness
« Reply #538 on: December 18, 2011, 14:36:15 pm »
Michael
NIDGAFWYT
fahrvergnugen
« Reply #539 on: December 18, 2011, 19:09:08 pm »
Dude, this is getting serious ,love the work on that cage. now the car is up to the job...are you? Grin
Paul.
