March 18, 2026, 05:47:29 am
352055 Posts in 28872 Topics by 6917 Members
Latest Member: joni75
| | |-+  TIKIMADness getting ready to go fast in 2015
Pages: 1 ... 10 11 [12] 13 14 ... 23 Print
Author Topic: TIKIMADness getting ready to go fast in 2015  (Read 406791 times)
tikimadness
« Reply #330 on: June 05, 2009, 20:48:02 pm »
Narrowed a trallingarm tonight.It's almost 100% it's just rubbing a little.
Now I'll do the other side next wek and then I can fab me some driveshafts.
Michael
NIDGAFWYT
Fasterbrit
« Reply #331 on: June 05, 2009, 21:27:32 pm »
This car looks so bad!  Cool Cool Cool  Getting cooler and cooler Michael Cool
www.air-kraft.com
www.marcomansiperformance.com
tikimadness
« Reply #332 on: June 05, 2009, 21:52:33 pm »
Thanks Matt a comment like that from you means a lot to me Wink
Michael
NIDGAFWYT
tikimadness
« Reply #333 on: June 09, 2009, 21:12:49 pm »
Narrowed the traillling arm a bit more and now it is spot on.
The inside
The inside will get some metal to strenghten it.
There is space between the tire and fender.
I also fitted the offset irs bolts from Marco and they are a great way to adjust the wheels.
Michael
« Last Edit: June 09, 2009, 21:19:34 pm by tikimadness » Logged
NIDGAFWYT
jamiep_jamiep
« Reply #334 on: June 11, 2009, 10:03:55 am »
 Shocked Cool
Looks really good, love the Weld wheels.
m.m.p
« Reply #335 on: June 11, 2009, 13:52:20 pm »
great car, love the un1 box, just make sure you put one original irs washer in first before you place the trailing arm on the car.
good luck,
 marco mansi.........
Marco Mansi
Marcomansiperformance.com
0044(0)7947 660 924
tikimadness
« Reply #336 on: June 11, 2009, 16:20:45 pm »
Okay thanks Marco
Michael
NIDGAFWYT
fahrvergnugen
« Reply #337 on: June 11, 2009, 19:44:10 pm »
good luck,
Hi Marco,
Wich washer should we use? the one with the big hole or with the small hole?
BR, Paul.
m.m.p
« Reply #338 on: June 12, 2009, 20:17:02 pm »
the one with the big hole, you put it on the car ,place it around the threaded part, before the irs arm with my adjuster in it.
marco mansi.
Marco Mansi
0044(0)7947 660 924
tikimadness
« Reply #339 on: June 13, 2009, 12:39:11 pm »
After the mock up earlier this week it was time to finish the welding to the irs arm.
I also notche the arm to prevent it from touching the cage .
And finaly I mounted marcos Irs bolts Wink
I started working on the ali panneling again,
Michael
NIDGAFWYT
fahrvergnugen
« Reply #340 on: June 14, 2009, 15:13:46 pm »
marco mansi.
Hi Marco,
This is the washer that fits over the MM special bolt, to tighten up the rubbers?
Sorry to go of topic Michael. Embarrassed
Paul.
« Reply #341 on: June 14, 2009, 17:19:00 pm »
Mike, are you rolling the bead in the aluminum panels yourself ?
tikimadness
« Reply #342 on: June 14, 2009, 17:20:52 pm »
Yep  ;)You know I do everything by myself Grin Grin
Michael
NIDGAFWYT
Pas
« Reply #343 on: June 14, 2009, 22:27:31 pm »
Michael
I knew you would do a good job Michael  Grin
m.m.p
« Reply #344 on: June 15, 2009, 18:19:45 pm »
here explains how to fit them.
http://www.shoptalkforums.com/viewtopic.php?t=110629&postdays=0&postorder=asc&start=0
good luck.
marco mansi....
Marco Mansi
0044(0)7947 660 924
tikimadness
« Reply #345 on: June 24, 2009, 18:12:56 pm »
Doing all kind of small things like fitting switches and mounting the steeringcolum.
Fitted the cut off switch,
Michael
NIDGAFWYT
Fasterbrit
« Reply #346 on: June 24, 2009, 22:58:41 pm »
I take it you are going turbo Michael?  Wink
www.air-kraft.com
tikimadness
« Reply #347 on: June 25, 2009, 21:03:57 pm »
Yes but I have a smaller turbo then you have Grin
But my engine is bigger  Cheesy Wink(2866 cc type 4 )
Michael
NIDGAFWYT
tikimadness
« Reply #348 on: July 09, 2009, 17:30:03 pm »
Went to the garage after a great weekend at EBI .
Bought a set of new porsche carrera 2 rear calipers.
They need a 7mm shim to center them around the discs.The shims are ready tommorow so I can bolt up the righthand side of the suspension with new 12.9 bolts.
Michael
NIDGAFWYT
Black Sheep
less is more
« Reply #349 on: July 09, 2009, 17:41:52 pm »
Nice auto jumble find Michael , saw your work van as I went in on friday  , maybe next time with your car  Cool
13.03 @ 98mph
tikimadness
« Reply #350 on: July 10, 2009, 16:22:06 pm »
Yeah that would be nice I saw you race looked good Smiley
Michael
NIDGAFWYT
Black Sheep
less is more
« Reply #351 on: July 10, 2009, 17:56:28 pm »
Cheer's Micheal ,
 I may have look good but i was having major traction problems .
Think Ive got it sorted now  Smiley
When are you looking at running first time out ?
13.03 @ 98mph
tikimadness
« Reply #352 on: July 10, 2009, 18:19:31 pm »
My goal was Ebi then it was das drag day 7 but now that I am more relaxed I would say first meeting next Year. Cry
It turns out to be too much work all in one year especially as I have a bussines to run as well Wink
Michael
NIDGAFWYT
tikimadness
« Reply #353 on: July 22, 2009, 13:48:48 pm »
Got a parcel from the Uk today.I was very pleased to see the rearvalance karl from autocraft made for me.
It looks really good.
Except for a engine lid I have all the body panels complete.
Michael
NIDGAFWYT
Black Sheep
less is more
« Reply #354 on: August 12, 2009, 17:39:31 pm »
It needs four little holes drilling in the bottom of it  Wink
Hows it progressing Michael ?
13.03 @ 98mph
tikimadness
« Reply #355 on: August 13, 2009, 07:28:14 am »
Hey 49 Rag it is been really quiet around the car Sad
I got some problems with my back again for the second time this year.And There is less work so the money going in to the car is reduced to allmost zero at the moment.Hopefully I have enough work from next week till the end of the year so I can start buyng some stuff I need to put in the car.
Michael
NIDGAFWYT
« Reply #356 on: August 18, 2009, 16:18:27 pm »
Same overhere, take it easy Mike ! (priorities first).
tikimadness
« Reply #357 on: August 30, 2009, 15:23:34 pm »
Well since work is kinda slow I had the time to work on the car again.
Got to work on the alluminium panels again.
Also fitted the last rear fender,
And the rearvalance
And just for fun I put the decklid from my first car on the back
Michael
« Last Edit: August 30, 2009, 19:12:28 pm by tikimadness » Logged
NIDGAFWYT
tikimadness
« Reply #358 on: October 10, 2009, 20:15:33 pm »
At last its busy around here so I have to make time to work on the car but I am happy with that Wink.
Ordered some headstuds from ARP through my friend Mycha who is in the States right now.Also ordered a holley blacktop(compatible with E85)
Cleaning and prepping the case for mock-up.
Received the chuterelease lever which is really cool looking.Wil post a picture later this week.
Michael
NIDGAFWYT
jamiep_jamiep
« Reply #359 on: October 13, 2009, 10:12:45 am »
Hey Michael... I'm sure I recognise that decklid... your old car featured in Volksworld?
