DeathBySnuSnu
« on: July 01, 2021, 03:11:50 am » |
Well.....the vw powered murdercycle has been fun.
Now for the next vw project. A little car this time. A Vokaro.
DeathBySnuSnu
« Reply #1 on: July 01, 2021, 03:13:47 am » |
DeathBySnuSnu
« Reply #2 on: July 01, 2021, 03:14:39 am » |
DeathBySnuSnu
« Reply #3 on: July 01, 2021, 03:15:30 am » |
DeathBySnuSnu
« Reply #4 on: July 01, 2021, 03:16:34 am » |
DeathBySnuSnu
« Reply #5 on: July 01, 2021, 03:17:28 am » |
« Reply #6 on: July 01, 2021, 06:45:40 am » |
You can't just put pictures up like that with no explanation! It might not be cal look, but it certainly is interesting!
DeathBySnuSnu
« Reply #7 on: July 01, 2021, 18:25:00 pm » |
So.....whatcha wanna know?
It is a VW Vokaro. I have put a lot of tubing on it....scared of getting run over....it is so small/short.
It has a little 2.5L V6. Double over, 4 per. A screamer....not high HP.
Box is a 901 5 speed.
Rear suspension is IRS
Front suspension is ball joint beam.
DeathBySnuSnu
« Reply #8 on: July 04, 2021, 13:51:58 pm » |
Working on the front end now.
As I have drop spindles, adjusters, a pie cut, and a body drop (moved Napoleon hat)....…even with 23 inch diameter tires it was a lot of cutting to make the car fit.
DeathBySnuSnu
« Reply #9 on: July 04, 2021, 13:53:44 pm » |
DeathBySnuSnu
« Reply #10 on: July 04, 2021, 13:58:04 pm » |
Trying to make a wide body look. Of course they will be glassed in and smoothed out.....not screwed to the body.
DeathBySnuSnu
« Reply #11 on: July 04, 2021, 13:59:11 pm » |
DeathBySnuSnu
« Reply #12 on: July 04, 2021, 14:05:37 pm » |
Trying to make a splitter idea work out.
DeathBySnuSnu
« Reply #13 on: July 04, 2021, 14:07:39 pm » |
DaveN
« Reply #14 on: July 04, 2021, 19:04:43 pm » |
Not very cal look is it?
« Last Edit: July 04, 2021, 19:12:55 pm by DaveN »
DeathBySnuSnu
« Reply #15 on: July 05, 2021, 02:09:18 am » |
Well..... If you don't count.....Riverside, Sonoma, Laguna Seca.....then no it is not much like cars in California.
DeathBySnuSnu
« Reply #16 on: May 05, 2022, 04:29:19 am » |
Airspeed
« Reply #17 on: May 16, 2022, 14:11:17 pm » |
Interesting engine and even more so the intake manifolds. From which VW car came this 2,5 ltr V6 engine?
"...these cars were preferred by the racers because the strut front suspension results in far superior handling than the regular torsion bar front end..." - Keith Seume. 11.06 @ 125 mph
Lingwendil
« Reply #18 on: May 18, 2022, 15:55:30 pm » |
Mazda.
DeathBySnuSnu
« Reply #19 on: May 22, 2022, 19:46:56 pm » |
Somebody has seen a KL before.
The internet lore has Porsche as the engineer for hire that designed the original. This one in the pics is a later model engine used in Mazda's MX series cars (as opposed to the RX rotary series).
So the engine is Mazda The trans is Porsche The chassis is mostly mid engine dune buggy kit (unwelded) The suspension is VW And the body is a Vokaro made in California.
