October 12, 2026, 21:36:34 pm
| | |-+  Diederick's new monster.... tell us more dude
Pages: 1 ... 3 4 [5] Print
Author Topic: Diederick's new monster.... tell us more dude  (Read 75736 times)
« Reply #120 on: July 27, 2008, 11:40:19 am »
i know that there's a lot of people that run their hot vw engines with ida's using the stock fuel lines and stock fuel pump. i'd like to do the same, so perhaps i need to change plans?
« Reply #121 on: July 27, 2008, 11:49:20 am »
ask phillip from the flatline lowrider i know he have a stock fuel pump with 48 ida
here's is profile with hte e mail adress
http://cal-look.no/lounge/index.php?action=profile;u=88
« Last Edit: July 27, 2008, 11:53:00 am by speedwell » Logged
Bewitched666
Bewitched
« Reply #122 on: July 27, 2008, 13:39:15 pm »
Stock fuel pump will work and i have seen them run stockfuel lines too and it all worked.
Before you buy Died checkout some more info on it,it can well suite your needs. Cool
Fast vw beetle's rule
« Reply #123 on: July 27, 2008, 15:43:29 pm »
Love that picture, Fabian... very proper looking engine compartment.
« Reply #124 on: February 23, 2009, 15:08:12 pm »
just a quickie, how far should this fitting go in?
i've got it half way in, aligned in the right direction, but it will need lots and lots of strength to go in further.
181
« Reply #125 on: February 23, 2009, 15:18:44 pm »
This is also my concern as I´m not familiar with US tapered threads. I ended up with sealing the thread with Loctite sealer and tightening it only with small strength. I don´t want to crack my mag case  Shocked
« Reply #126 on: February 23, 2009, 17:13:21 pm »
Best to be careful here. Those are tapered pipe threads. If you run it in too far (i.e. use excessive force) you'll crack the case.
I personally use a teflon pipe thread sealant, and get it just where it snugs up and the hose would be @ 8:00
I don't like using Loctite on pipe thread fittings.
« Reply #127 on: February 23, 2009, 17:41:07 pm »
that's where mine is right now (@ 8:00)
but now some of the thread is still exposed, but that's ok, i guess?
so, i'll get it out, get some teflon pipe thread sealant and stick it back in? where do i get that sealant, any DIY store?
« Reply #128 on: February 23, 2009, 17:57:25 pm »
Any hardware store. Just be carefull since the slippery tape/ sealant will make you lose
some of the "feel" when tightening.
« Reply #129 on: February 23, 2009, 18:30:51 pm »
They Also make Teflon sealant in a tube it works much better then teflon tape because you dont get the stringy stuff coming loose inside and you dont get the feeling  of not being tight enough
« Reply #130 on: February 23, 2009, 18:33:33 pm »
i think you're referring to this tube:
« Reply #131 on: February 23, 2009, 19:33:51 pm »
yep thats the one
« Reply #132 on: February 23, 2009, 21:16:49 pm »
That's a conical thread, that's why it becomes harder to tighten  Wink
« Reply #133 on: February 23, 2009, 23:25:38 pm »
but it is the right fitting, right?
ian c
« Reply #134 on: February 24, 2009, 05:00:06 am »
tip : dont paste the first 1-2 threads .
(o\ ! /o)
ian c
« Reply #135 on: February 24, 2009, 05:09:04 am »
strange that you're watching a 1915 40x35.5 engle130 thread ...  Huh Shocked Cool Grin
 Grin
(o\ ! /o)
« Reply #136 on: February 25, 2009, 18:55:19 pm »
just been out to a DIY store, a wholesale parts store, and a car parts store for several things.
but none had tubed teflon sealant, one offered me a bottle of loctite 542 or i found teflon tape for pipe fittings...
harry, do you use the tape or did you find teflon tube sealant somewhere?
Hotrodvw
« Reply #137 on: February 25, 2009, 19:07:11 pm »
I don't prefer tape, as it ads to the O.D. of the fitting, making it easier to crack the port.  I prefer the liquid teflon sealant as well, or you can use the Loctite Hydraulic Thread Sealant...........made to seal threads.  LOCTITE # 54550 .............Europe may use a different part number.   Roll Eyes
Hose & Fittings
'67 Sunroof
www.ultimateaircooled.com
« Reply #138 on: February 25, 2009, 20:19:53 pm »
mmh, i think that was the loctite 542 i had in my hands today. loctite thread sealer for hydraulics and pneumatics. 30 EUR for a way too large bottle. i just need a few drops  Grin
