September 22, 2026, 09:51:45 am
| | |-+  Diederick's new monster.... tell us more dude
Pages: 1 2 [3] 4 5 Print
Author Topic: Diederick's new monster.... tell us more dude  (Read 74711 times)
« Reply #60 on: February 10, 2008, 18:15:30 pm »
mmh, i have been thinking about a treuhaft 010 or mallory YL-541 dual point.
do you know anything about those, zach?
« Reply #61 on: February 10, 2008, 18:21:49 pm »
I had a dual point once, sold it on ebay. Ive heard they arent really neccessary, more complexity for zero benifit. Slinger has the Treuhaft 010 on his single cab, with a Mallory ignition conversion. It works great, but it would be much less hassle to get a brand new distributor and put an old badge on it. No one will ever know your secret, and Ill take it to the grave with me Wink
« Reply #62 on: February 10, 2008, 18:24:10 pm »
Stop wining around and build the motherfucker. Who cares about the decal on the distributor.
« Reply #63 on: February 10, 2008, 18:24:30 pm »
alright Smiley
well, i'd have to see who can lock out my 009. then i'll run a bosch red coil. and get an MSD 6A(L) at a later stage.
but i need to lock out my 009 because of the revs going over 6,000 right?
thanks for the input harry, didn't know that's what you think about it  Wink
« Reply #64 on: February 10, 2008, 22:15:41 pm »
wow, good job! Grin
« Reply #65 on: February 10, 2008, 22:29:40 pm »
jim, PM sent.
Bewitched666
Bewitched
« Reply #66 on: February 11, 2008, 08:10:02 am »
Oh ok Died forgot you wanna go for that old skool callook am i right?
Like they said the 009 or 010 is great Grin
Fast vw beetle's rule
« Reply #67 on: March 22, 2008, 12:52:49 pm »
Hey Died , how s it going with your engine dude?
isnt it finished yet ?
 Tongue
« Reply #68 on: March 22, 2008, 12:54:07 pm »
haha, haven't started yet.
i'm waiting for the parts, then I'll get cracking Smiley
« Reply #69 on: March 22, 2008, 13:52:53 pm »
And don`t forget the BIG advantage of the LOOK with a 010/019 Grin
But be carefull if you go with an 019 and one spring when you set the ignition. As you see the 019 begins to advance before 1000 U/min. So a static ignition set would be best. And even check the totall advance when engine is running on higher rpm`s allways a point that is often missed.
On my second car, I really enjoyed my .019. And you're right about the static ignition set. The only way I ever set mine.
« Reply #70 on: March 22, 2008, 17:36:04 pm »
Plus on a '67 you can use the reverse lights!  Wink
« Reply #71 on: May 10, 2008, 19:50:24 pm »
USPS Track and Confirm:
We attempted to deliver your item in NETHERLANDS at 10:38 AM on May 12, 2008.
Too funny, it's only the 10th where I live  Cheesy
« Reply #72 on: May 10, 2008, 23:14:00 pm »
Diederick, I will be emailing progress on your heads.
Jim
Bewitched666
Bewitched
« Reply #73 on: May 12, 2008, 09:05:51 am »
UPS is funny Died Grin
« Reply #74 on: May 17, 2008, 21:33:51 pm »
well, got all those few parts a few days ago.
sent out my pulley, crank, flywheel and kennedy plate to get it all balanced (and flywheel lightened to about 11.5 to 12lbs)
and i had a good chat about my parts etc.
what are the opinions on a 30mm oil pump? i was told that it'll be too much, the relief on the pump cover will be openend at all times and the oil cooler in the shroud won't get any oil because all the oil will be pumped out (full flow). this is with 15w40 oil which i'm planning to use. and the oil pressure will exceed 5 bar (80psi) meaning i'll have to get a new guage too.
anyway, what are the opinions? apparently i would've been better off with a 26mm...
« Reply #75 on: May 17, 2008, 22:16:41 pm »
You know my opinion dude a 30mm is perfect - but mines still BIGGER  Wink Cheesy Smiley
oh yeah I've also moved up to 20/50 valvoline  Smiley
« Last Edit: May 17, 2008, 22:30:33 pm by monkiboy » Logged
« Reply #76 on: May 17, 2008, 22:26:46 pm »
Diederick the 30mm pump will work
I have run a 30mm pump in every engine over 1600cc since 1990
I don't use bypass covers.
I wouldn't have set your engine up as a unit with a 30mm if it would not have worked.
(that case ran a 30 for 17 years, why change something that worked?)
email me
« Reply #77 on: May 17, 2008, 23:55:53 pm »
i did Smiley
awaiting your response, mr ratto Wink
Bewitched666
Bewitched
« Reply #78 on: May 18, 2008, 15:28:53 pm »
Died,where do you get your stuff balanced?
Btw nice to have seen you at the KCD Cool
« Reply #79 on: May 18, 2008, 15:29:59 pm »
abc tuning in hazerswoude
http://www.abctuning.nl/
Bewitched666
Bewitched
« Reply #80 on: May 18, 2008, 15:43:54 pm »
Oh ok Died,nearby me then,will check them out.Thnx dude Cool
« Reply #81 on: May 23, 2008, 01:37:36 am »
my ida's have been rebuilt by martijn!
well chuffed Grin
« Reply #82 on: May 23, 2008, 02:27:23 am »
Bellissimo! Grin
« Reply #83 on: May 24, 2008, 16:19:42 pm »
Looking good dude  Grin
« Reply #84 on: May 26, 2008, 19:48:27 pm »
yeah! thanks guys Grin
awesome job by martijn!!
« Reply #85 on: May 27, 2008, 15:51:44 pm »
3 queries popped up today.
- what's the general opinion on aftermarket 36hp shrouds?
i prefer the look, and i'd need to mod my VW doghouse to a 181 to use it. i know bugpack sell 36hp shrouds? but those don't have provision for heater flaps etc, right?
- what kind of spark plugs should i use with my 043 heads? there's short and long reach and W7 and W8...
- does the use of an MSD 6AL make a pertronix kit for my 009 redundant?
Bewitched666
Bewitched
« Reply #86 on: May 27, 2008, 20:15:21 pm »
heard the aftermarket stuff sucks,look for original Died Cool
« Reply #87 on: May 27, 2008, 20:17:02 pm »
i heard SOME don't, and a sh*tload of people use them
just looking for some answers here dude Wink
Felix/DFL
« Reply #88 on: May 27, 2008, 20:25:18 pm »
Hi Diederick,
043s orig. came with short spark plugs.I even have 043s (sadly with stock valves Wink and have good experience with the Bosch W7AC Sparks. So one point colder than the orig W8AC sparks. I once tryed similar NGK but had problems with them...
Greetz !
lowfastbus
WUNDERWAFFE
« Reply #89 on: May 27, 2008, 21:05:04 pm »
Hi Diederick,
A few years ago I swapped my stock doghouse cooler to an aftermaket 36hp one...
It was on a 1835 that performed great, sadly after installing the aftermarket cooler it became to warm on the highway and toasted the engine  Angry
Jelle
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
