October 12, 2026, 21:36:13 pm
| | |-+  Diederick's new monster.... tell us more dude
Pages: 1 2 3 [4] 5 Print
Author Topic: Diederick's new monster.... tell us more dude  (Read 75735 times)
« Reply #90 on: May 27, 2008, 21:24:09 pm »
you mean after installing the aftermarket fanshroud?
lowfastbus
WUNDERWAFFE
« Reply #91 on: May 27, 2008, 21:27:19 pm »
yep
http://dragvws.skynetblogs.be
WUNDERWAFFE
The Knuckle Buster
« Reply #92 on: May 27, 2008, 22:06:25 pm »
Hey Dieds your heads use long reach 3/4" plugs I suggest NGK B7ES copper core
you can use the Petronix with MSD. MSD makes spark hotter, the Petronix is just a "timing device" it does nothing to increase spark output. Basically eliminates point maintenance....that's it.
The MSD increases voltage to coil primary and in turn cranks up secondary output.
gap the plugs @ .035"
Type1/DVK
« Reply #93 on: May 28, 2008, 10:25:12 am »
Died, forgot this topic  Shocked  You're carbs are being sent today! they came out nicely! all progression hole line up perfect. Good luck with the monster
« Reply #94 on: May 31, 2008, 22:42:27 pm »
Thanks for responses!
I'm still interested in an aftermarket 36hp fanshroud. I see many DKP guys run them and other people with HIPO engines. So, they cannot be that bad, right?
« Reply #95 on: May 31, 2008, 22:49:35 pm »
as long as you are not using Berg Fan Shroud Mounted Linkage the aftermarkets are alright but not great in the fitting department there is no mounting hole for the coil or berg linkage plus the aftermarket shrouds have an offset gen/alternator hole if you use berg linkage you will have to slot all the holes in the linkage to make it fit.
JS
« Reply #96 on: May 31, 2008, 22:52:49 pm »
No big deal IMHO, You have to slot the hole in the middle, and make mounts for the coil. Works just fine for me.
Signature.
« Reply #97 on: May 31, 2008, 22:58:23 pm »
yeah, i found out about the holes on the shroud i used on my (failed) kadron 1600 last summer. but i'm using they tayco/bugpack IDA linkage and i'm planning on mounting coil on the firewall.
about the fitting, there are these spacer to go in between the house and the cylinder tins. might as well get those then.
still, do they not have inferior cooling performances?
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #98 on: June 02, 2008, 15:18:06 pm »
 I run an aftermarket 36 shroud on my car.  drilled a hole and welded a nut before powder coat for berg linkage. I have no cooling issues with mine. As far as original I don't think you'll find an original 36 Doghouse shroud. They don't exsist.
« Reply #99 on: June 30, 2008, 10:53:06 am »
getting somewhere:
pulley, crank (gears and bearings installed), flywheel (about 11.5lbs), and pressure plate all balanced.
airstuff
« Reply #100 on: June 30, 2008, 16:27:46 pm »
now only take time and assemble it  Smiley
« Last Edit: June 30, 2008, 16:33:19 pm by cal-look » Logged
JeePee/DVK
« Reply #101 on: June 30, 2008, 16:55:15 pm »
Diederick is a student,so he got lots of time. Shocked
airstuff
« Reply #102 on: June 30, 2008, 17:03:53 pm »
me too a student,I also wonder how long my build will take once I start
Wish you luck Diederick!
« Reply #103 on: July 24, 2008, 18:29:31 pm »
after some bad news about already acquired parts that turned out useless, and lots of other costs that i have to incur, i have slowed down the pace of building this engine.
lately, i bought a cagero oil cooler, got a 36hp fanshroud and some small parts.
i still need a few small parts;
i'm looking for an electric fuel pump. i'm using IDAs and stock fuel lines. which one is recommendable?
also, i have not yet decided whether to run teflon clips or not.
are copper exhaust gaskets any good? i'm thinking of getting those.
« Reply #104 on: July 24, 2008, 18:35:57 pm »
I hope none of "my" old parts have been deemed "useless." I know about the rods. Any other issues?
The tru arc clips or spirol lox work fine, but spirol lox can be a real bitch to get out.
I use high temp silicone on my header instead of gaskets.
« Last Edit: July 24, 2008, 18:37:53 pm by Jim Ratto » Logged
« Reply #105 on: July 24, 2008, 18:44:12 pm »
the rods were shot, and i need a new merged header.
no, your parts are great and in good hands  Wink
Jeroen
« Reply #106 on: July 24, 2008, 18:51:43 pm »
hurry up with that engine. I need some competion in the club.
always the fastest is boring Wink
« Reply #107 on: July 24, 2008, 19:29:24 pm »
Stock Fuel line with electric pump to feed IDA's,  are you nuts ?
Cagero, that must have cost a small fortune.
Teflon Buttons, no p.
I use thick paper gaskets with high temp silicone.
« Reply #108 on: July 24, 2008, 19:32:13 pm »
I'm working on it outside the club... Just need some skulls for the engine. Hopefully DDD6.
« Reply #109 on: July 24, 2008, 19:34:35 pm »
some people with well-known cars run stock fuel lines and a stock fuel pump to feed their IDAs Wink
cagero coolers aren't that expensive, they cost more than the average 72 plate cooler but do come with a nifty louvered mount!
high temp silicone, will loctite 574 do?
does nobody run these copper gaskets? they don't cost that much more...
« Reply #110 on: July 24, 2008, 19:46:41 pm »
Died, do yourself a favour and run at least -6 fuel lines. It's all gas volume! And you will not lean your engine out that quick.
HT Silicone, as long as it is orange or red.
I did run coppers, but got tired of annealing them every time, plus after the second use they are completeley flat and don't seal that good anymore.
H.
« Reply #111 on: July 24, 2008, 19:54:07 pm »
H.
ditto. Why risk holeing your 94's and blowing heads off by leaning your engine out? At least go to 7mm VW hose or as Harry said, AN6. You can create an expensive problem by trying to cheap out on hoses?
The copper gaskets NEVER worked on my car. I use Peramtex High temp copper on header flange and bolt to heads....never any leak.
« Reply #112 on: July 24, 2008, 23:00:32 pm »
I think you are worrying a little too much dude  Wink Smiley just get some 8mm braided fuel line from ANY vw parts place (ie PATS etc) and run that the WHOLE length of the car - its what me Gav and Rob have all done and it works PERFECTLY  Smiley
You really are not gonna hole a piston just by having a standard type fuel line - I might be wrong but I think that has alittle more to do with jets, tunning, timing etc etc etc  Wink Smiley
Just look at what they "Used" to run with Smiley
« Reply #113 on: July 24, 2008, 23:19:46 pm »
yes 8mm VW hose or BMW hose will work fine. No need for expensive AN6 braided hoses. Just get matching banjos for your IDAs and a tee.
But stock 5mm hose will restrict your engine at load and create lean/heat problem. Been there, had the problem, fixed the problem.... a long time ago.  Cool
Tony M
« Reply #114 on: July 24, 2008, 23:39:03 pm »
Just did the plumbing on my engine - used Weatherhead hose - marine approved - double wall - 3/8 hose = 6an - easy to get push on fittings and very durable - very easy to use.
« Reply #115 on: July 24, 2008, 23:39:44 pm »
easy like you
Tony M
« Reply #116 on: July 25, 2008, 00:42:35 am »
Only easy if your lucky  Cheesy
« Reply #117 on: July 25, 2008, 11:57:08 am »
i have a fuelpump (electric one) and i might consider swapping back to a original one, but i have a fuel injection case and no hole to put a pump, but it has less problems regarding too much pressure. i think Jim kurlinski runs a stock pump on his 2.2l engine. so it can work. but i read somewhere here on the lounge or in a magazine an article about setting the pump up so it will run as efficient as possible. and i got hoses from Gates, they are good quality and fit tight. don't really care for braided ones as they look messy with regular clamps and get dirty real fast. and they are not better then the rubber ones.
still need those teflon buttons? i wee them in all the catalogs were you can buy parts.
Jesse/DVK
'64 2176cc
« Reply #118 on: July 25, 2008, 18:28:12 pm »
Eey Died, do you allready have electricity in the garage? I just orderd my first parts for my 1915 so we can have a race Cheesy
vulgaris
« Reply #119 on: July 25, 2008, 19:15:55 pm »
what's my price on hoses for my dellortos i want 8mm parker hose
