July 01, 2026, 17:51:13 pm
Latest Member: bigsiembowski
| | |-+  New engine
Pages: 1 ... 5 6 [7] 8 9 ... 21 Print
Author Topic: New engine  (Read 727440 times)
« Reply #180 on: April 18, 2012, 21:00:49 pm »
Hi Udo
Thanks for your advise
I have no sump on now
Do you always use sump on type4 engine or only when 32mm pump is used ?
John
Never use a 32 pump on any engine. Type4 max 26mm Gene Berg. You must have a sump on an engine like yours , otherwise you do not have any oil in the bottom of the case.
Torben - i think you never had an engine that makes 8000 or more rpm ?
Elnef
« Reply #181 on: April 19, 2012, 11:06:54 am »
Hi Udo
John
Thanks Udo
Do you have a sump I can buy ?
John
Patte
« Reply #182 on: April 19, 2012, 15:56:53 pm »
Hi John.
Lack of oilpressure really sucks.
I have had  problems with low oilpressure (0,1bar) at idle when hot after a run for years.
I have been trying all types of cures for the problem and i think i have found whats causing it, i believe
its the original oil filterholder with the built in pressurerelief that fucks it up.
After plugging it and making a type1 style remote oilfiltersystem the probs are solved  Smiley
It now idles at 2,5bar when hot and 3-3,5bar when cold  Grin
I use a Melling 32mm and Scat deepsump  Wink
Patte.
« Reply #183 on: April 19, 2012, 18:22:23 pm »
Hi Udo
John
Thanks Udo
John
John,let me know if you cant get a sump,I have some parts coming from usa end of next week and can get a scat type 4 sump added in there for you if you need it
« Reply #184 on: April 19, 2012, 21:31:34 pm »
Hi Udo
John
No , scat is the only one that makes them . order it at richie, sounds good
Thanks Udo
John
« Reply #185 on: April 19, 2012, 21:34:22 pm »
I have no in stock . sounds good what richie says . order it , scat is the only one that makes type4 sumps. And use a 26 pump
or 30mm schadek if you want
Elnef
« Reply #186 on: April 21, 2012, 06:40:25 am »
Thanks for input everybody
My engine is apart nothing to see hmm
Got some parts from Rolf and Bang yesterday Thanks
Richie I will pm you later this weekend
I have solved the problems with the valve Patte talk about with a 6mm screw you can see it on the photo
Elnef
« Reply #187 on: April 30, 2012, 15:15:02 pm »
Did you get a 300 flow on the intake ? Who did the flow testing ?
i still wonder if they flow good .
Hi Udo better late than never here you go my number at 28" with Carburator on
                CFM
   Lift       No. 1      No. 2
    1.00       23.7       37.4
    2.00       44.4       60.0
    3.00       65.5       80.9
    4.00       87.0      104.2
    5.00      105.8      129.0
    6.00      122.5      153.6
    7.00      136.2      174.5
    8.00      150.0      195.5
    9.00      162.9      217.5
   10.00      174.2      238.4
   11.00      184.0      257.0
   12.00      195.0      271.5
   13.00      201.8      280.9
   14.00      208.7      291.2
   15.00      213.2      298.3
   16.00      217.4      304.3
   17.00      221.2      307.5
   18.00      225.1      308.3
   19.00      227.6      310.3
   20.00      232.6      313.5
   21.00      231.9      315.0
   22.00                 320.2
« Last Edit: April 30, 2012, 15:16:44 pm by Elnef » Logged
« Reply #188 on: April 30, 2012, 17:48:34 pm »
Nice!
Thanks for sharing.
Elnef
« Reply #189 on: April 30, 2012, 18:07:41 pm »
No problem I got them flowed a few days ago  Wink
Bangs block was not okay so I got one another from a longtime good friend Frank Andersen the local type4 guro  Smiley
Griebel checked my crank and its okay and he also got my block and will measure it
John
Elnef
« Reply #190 on: May 30, 2012, 17:12:03 pm »
Well after Griebel had measured some/serval blocks for me we finally got one from another long time friend Dalsgaard that was spot on
Griebel made some machine work on it and its almost ready  Wink
Also got a new cam  and more parts is on there way home to me Wink
« Reply #191 on: May 30, 2012, 22:37:59 pm »
Cool,
I didn t know JPM made cams for Type 4, now I know  Wink
Is this one custom made, or does he have a few(profiles) on stock.
I kinda like one.
Good luck with the engine, hope this one will stay alive.
Griebel
« Reply #192 on: May 31, 2012, 11:05:11 am »
Answering for John:
The JPM Raptor cam is custom made for this particual engines new specs.
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
« Reply #193 on: May 31, 2012, 13:06:05 pm »
Answering for John:
Ok that is good to know, it is desinged for the engine.
Is this a complete set with lifters, valvesprings and pushrods?
or just the cam?
I think it is time to contact JPM, my plan is to travel by his place on the way to SCC, this year.
thanks griebel
« Last Edit: May 31, 2012, 17:42:25 pm by Eddie » Logged
Elnef
« Reply #194 on: May 31, 2012, 14:31:43 pm »
Only cam and lifters in the box
But if you want he also have the other parts  Wink
John
Elnef
« Reply #195 on: June 02, 2012, 18:12:01 pm »
Some progres  Wink
GetBackOnTrack
« Reply #196 on: June 04, 2012, 23:43:19 pm »
Looks like those rods can reach the cookies in the kitchen  Cool
Check: gbot.dk
Elnef
« Reply #197 on: June 14, 2012, 19:48:57 pm »
While waiting for the last parts for my heads I put in a new belt  Wink
« Reply #198 on: June 16, 2012, 06:33:18 am »
New belt looks good. That gives us hope you will race this year  Smiley
Elnef
« Reply #199 on: June 16, 2012, 07:21:24 am »
Yep spot on Udo  Wink
I had a plan/dream about malmų or bitburg first in july but time is flying so later this year
Elnef
« Reply #200 on: June 18, 2012, 17:03:24 pm »
The last parts for now  Grin
Now to the machine shop with parts and heads  Wink
Bad bug
« Reply #201 on: June 19, 2012, 14:15:07 pm »
Elnef which case through bolts do you use.
Elnef
« Reply #202 on: June 19, 2012, 21:38:53 pm »
10mm 12.9
John
Bad bug
« Reply #203 on: June 20, 2012, 03:50:23 am »
Did you use any of these on the case bolts.
http://www.bughaus.com/case_isolation_damper_-_021101107.htm
RMS Boxer Service
« Reply #204 on: June 20, 2012, 08:19:16 am »
I am selling the through bolt set john is using.
/Rolf
Rolf@boxerservice.dk
Elnef
« Reply #205 on: June 20, 2012, 11:08:20 am »
No
Rolf you cant sell my bolts  Grin
« Last Edit: June 20, 2012, 11:12:13 am by Elnef » Logged
RMS Boxer Service
« Reply #206 on: June 20, 2012, 14:18:42 pm »
allright, John you got me there  Grin
I sell bolt sets like the bolts John is using Wink
/Rolf
Bad bug
« Reply #207 on: June 20, 2012, 22:26:59 pm »
/Rolf
O.k. what's the price on them and did you use any of these with the bolts. Oh! by the way are they grade 12.9 i think elnef wrote 10mm 12.9. I am just making sure i have everything correct.
GetBackOnTrack
« Reply #208 on: June 21, 2012, 17:02:49 pm »
New special made guides for John“s pauter heads.
Check: gbot.dk
Elnef
« Reply #209 on: July 01, 2012, 17:53:37 pm »
Heads on  Smiley
