November 02, 2026, 14:38:23 pm
The weight saving thread
10
11
12
13
34
Topic: The weight saving thread (Read 1831960 times)
benssp
www.callookvw.com
Re: The weight saving thread
Reply #300 on:
November 05, 2009, 12:52:09 pm »
A tiny one this time, brake hose clips genuine 7.8g, stainless 5.5g saving 13.8g per car, not including the rust on old ones
and they're shiny
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
Chris W
Reply #301 on:
November 05, 2009, 18:56:10 pm »
Where do you get stainless ones?
benssp
www.callookvw.com
Reply #302 on:
November 05, 2009, 20:01:58 pm »
Quote from: Chris W on November 05, 2009, 18:56:10 pm
www.vwheritage.com
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
The Ideaman
Reply #303 on:
November 05, 2009, 20:23:43 pm »
Quote from: Bruce on September 24, 2009, 03:00:39 am
Quote from: Zach Gomulka on September 20, 2009, 22:13:51 pm
200mm KEP 1700# pressure plate vs aluminium version of the same. Savings of 1,528.7 grams or just under 3lbs 6oz
I sent a message to KEP, and they don't make a Type 1 clutch where the stamped part is Aluminium. What is that clutch you weighed for?
KEP said their aluminium Type 1 clutch is a "Stage I with aluminum face".
How does this work? Anyone ever used a clutch with an aluminium shoe?
Scott Sebastian runs my old one in his class 11 car.
It is the soldier,
Who salutes the flag,
Who serves beneath the flag,
andy M.
Reply #304 on:
November 08, 2009, 19:59:09 pm »
Does anyone know what the weight difference is between a super diff and a quaife lsd? I keep hearing that they are heavy but how heavy is heavy?
andy
L.B.C.R.
Martin
Cash Converter....
Reply #305 on:
November 08, 2009, 21:29:12 pm »
Ask Peter,
Its quite a lot.
Martin
www.taylormachine.co.uk
OFF/500
Steve D.
Reply #306 on:
November 08, 2009, 21:49:18 pm »
Can't help you with the weight of a quaife, but off the top of my head my old T1 IRS ZF weighed in at 16.5lbs if I remember correctly, and my 091 Peloquin TBD is roughly a fokken tank.
Über Alles
10.77 avg. on pump fuel.
238I
andy M.
Reply #307 on:
November 09, 2009, 08:43:37 am »
I shall give Mr E a call later,
andy
L.B.C.R.
FIDDE
Reply #308 on:
November 09, 2009, 12:54:23 pm »
How many kg is it in a single skin body,if i remove all the the inner panels?.The bulkhead and the rear sheet metal
is already gone,and its going to be replaced with 0.7 alu panels,is it worth the job?what do you think?
58vw
Reply #309 on:
November 10, 2009, 08:41:28 am »
has anyone had sucess with an aluminum beam in a full bodied car? do they hold up? pros? cons?
www.4inbore.com
Angleflows...order them now
andy M.
Reply #310 on:
November 10, 2009, 10:54:39 am »
I've got one in my '66, it's stood up to a years worth of wheelies and street driving with no real problems,
it's a jamar one with the billet shock towers. If you get one be sure to check the alignment of the top and bottom adjusters, the one i got was out by about 1.5 mm and caused a bit of head scratching when it came down to sorting the camber!
Saved around 15 kg over the original b/j beam
And they look good too, my mot tester was v. impressed
andy
Last Edit: November 10, 2009, 11:03:05 am by andy M.
L.B.C.R.
Reply #311 on:
November 10, 2009, 10:59:09 am »
Quote from: 58vw on November 10, 2009, 08:41:28 am
Pete Shattock and Andy Marriot from the Outlaws both run aluminium beams, Andy only swapped over recently but Pete has been running one for several years, having driven all over europe with it. Both run stock stroke motors in all steel cars (Pete has a 1776 '61, Andy has a 1914 '66) running 11.9's and 12.0's!
I'm sure either of them would chime in with more help!
58vw
Reply #312 on:
November 10, 2009, 17:41:40 pm »
thanks for the input guys
www.4inbore.com
Peter Shattock
Reply #313 on:
November 10, 2009, 22:42:06 pm »
As Andy and Neil have already said there is no problem in principal with and ali beam with a street car but I would suggest you keep an eye on two things. The bushes in the beams don't necessarily fit to well and I've ended up making new ones (speak to Paul Woodhead on here about suitable material) and now the bushes fit the beam and the arms very nicely so there is no play. The other issue is if you use a standard steering box you need to be carefull that when you bolt it up to the beam that the you do not over tighten the clamp as the beam goes out of round and pinches the arm in the beam and you loose free suspension travel on that side of the car with some nasty handling consequences. I ended up locating the steering box and torquing it to the recommended VW spec 22-25ft-lbs (I think) and reaming the bush in position in the beam, to ensure you still have free travel.
There is one other thing the look good with the wheels up off the startline!
Hope this helps
58vw
Reply #314 on:
November 11, 2009, 01:30:39 am »
thanks peter
www.4inbore.com
PPRMicke
Reply #315 on:
November 12, 2009, 21:51:45 pm »
Door hinges in aluminum
Reply #316 on:
November 13, 2009, 04:16:25 am »
Quote from: PPRMicke on November 12, 2009, 21:51:45 pm
Dibbs!
Did ya make more than 1 set?
PPRMicke
Reply #317 on:
November 13, 2009, 13:58:21 pm »
Quote from: Bruce on November 13, 2009, 04:16:25 am
Dibbs!
Mail me
You might want a door skin of carbon fiber 500g
Pas
Reply #318 on:
November 14, 2009, 01:12:38 am »
Dibbs!
If you are making more than one set of these,I am sure there will be a few people on here who are interested (me included).
C.O.R.
Reply #319 on:
November 14, 2009, 07:54:47 am »
We're interested as well...not to be rude, but do you have a price in mind?
Aloha, Frank
Castagnetti Ohana Racing
Honolulu and Hilo
Gino and Frank
Honolulu and Hilo
Griebel
Reply #320 on:
November 14, 2009, 19:17:25 pm »
A bit of d.i.y...0,6 mm. polycarbonat lenses...app.40 gram...made over a casting(and not over the glass !),so they will fit inside the chrome rim like the original lenses
Cheers from Griebel
Last Edit: November 15, 2009, 18:01:52 pm by Griebel
Instagram: c.griebel
"BEYOND 4 INCHES"
MIB,DENMARK
Reply #321 on:
November 15, 2009, 08:30:27 am »
Quote from: Griebel on November 14, 2009, 19:17:25 pm
A bit of d.i.y. -0,6 mm. polycarbonat lenses...app.40 gram...made over a casting(and not over the glass !),so they will fit inside the chrome rim like the original lenses
Planning on making more?
I'm liking what Stephan did to his coil bracket:
Last Edit: November 15, 2009, 19:58:25 pm by Bruce
Griebel
Reply #322 on:
November 15, 2009, 09:21:51 am »
Quote from: Bruce on November 15, 2009, 08:30:27 am
This was my very first "pull", but yes,-I'm planning to make more....Casting a model of the old symetric lenses too.....
"BEYOND 4 INCHES"
MIB,DENMARK
Pas
Reply #323 on:
November 16, 2009, 21:35:48 pm »
Quote from: Griebel on November 15, 2009, 09:21:51 am
Keep us posted
Last Edit: November 16, 2009, 21:37:35 pm by Pas
Straight Time
Reply #324 on:
November 21, 2009, 14:06:17 pm »
Some great ideas for weight saving here but what about safety issues ?
Are there certain things that shouldnt be lightened or certain nuts and bolts that need strength rather than lightness ?
Any ideas as i'm now stripping my 67 for a full rebuild though it will be road biased with some strip action.
Anyway, dont we need a bit of weight at the front end . . . . . .
No retreat, No surrender !
Reply #325 on:
November 21, 2009, 19:39:05 pm »
Quote from: Straight Time on November 21, 2009, 14:06:17 pm
When you're looking at the fasteners for the steering or suspension, leave the original steel bolts in there. To hold the wings on, aluminium is plenty strong enough. How much does a wing weigh?
Last Edit: November 21, 2009, 22:11:32 pm by Bruce
Pas
Reply #326 on:
November 21, 2009, 19:53:37 pm »
Quote from: Bruce on November 21, 2009, 19:39:05 pm
When you're looking at the fasteners for the steering or suspension, leave the original steel bolts in there. To hold the wings on, aluminum is plenty strong enough. How much does a wing weigh?
Or if your budget allows replace steel bolts for titanium.
Phil West
Reply #327 on:
November 22, 2009, 08:44:45 am »
Steel rear wing = 8lbs
Steel front wing = 12lbs
Day Mouldings rear wing = 4lbs
Day Mouldings front wing = 6lbs
(Race weight wings)
Total weight saving = 20lbs
Rocket Ron
It's old school for a reason
Reply #328 on:
December 09, 2009, 19:33:59 pm »
http://www.thesamba.com/vw/classifieds/detail.php?id=745441
13.12 @ 101.84
Grooving out on life
181
Reply #329 on:
December 10, 2009, 16:50:34 pm »
can you say
light:-)
10
11
12
13
34
