October 11, 2026, 12:53:12 pm
Pages: 1 ... 32 33 [34] Print
Author Topic: The weight saving thread  (Read 1804450 times)
« Reply #990 on: July 16, 2023, 07:41:50 am »
 Grin  yes that is a carbon shifter handle[about half the weight] and alternator pulley [1/3rd the weight]  Shocked
« Reply #991 on: July 23, 2023, 12:17:41 pm »
 Smiley  Doors fitted to car with new hinges and handles, all works good
« Reply #992 on: July 29, 2023, 17:33:52 pm »
More stupidity  Grin  Fuel tank clamps in carbon, steel 24g, carbon just over 7g each, 4 is 29g!!!
ibg
« Reply #993 on: July 30, 2023, 03:48:38 am »
you just need to sell them with titanium or aluminium bolts, though aluminium might be a bit weak in a crash situation  Shocked
« Reply #994 on: July 30, 2023, 17:06:43 pm »
I will try not to crash then Grin   Did fit a pulley today to one of my cars and seems to work ok, will give it some milage and high rpm tests now and see if it falls apart Shocked Cheesy
https://www.youtube.com/watch?v=MxwOAIo1W0w
« Last Edit: July 30, 2023, 18:42:51 pm by richie » Logged
« Reply #995 on: December 25, 2023, 11:17:44 am »
 Grin
« Reply #996 on: March 23, 2024, 01:10:12 am »
Still the best thread on the entire internet  Cool
BFB
« Reply #997 on: March 24, 2024, 15:41:14 pm »
Those valve covers are definitely cool, id bet you could sell those especially if you made a set thatd clear ratio / high lift rockers.
Only argument i might see against them would be heat transfer. How much heat is normally dissipated thought an aluminum cover though?
« Reply #998 on: March 26, 2024, 09:03:56 am »
How much lift clearance do you need? these clear 650thou lift already, probably more but not built anything for a while with vw style covers that lifts more than that Smiley and I don't run aluminium covers anyway Wink
PPRMicke
« Reply #999 on: March 26, 2024, 09:35:52 am »
Can't figure out how to lighten a Vw front
You can put lead in the front if you have to drive fast
Because having the front wheels 1m up in the air does not give good times
/// M
« Reply #1000 on: March 26, 2024, 19:48:16 pm »
/// M
While i mostly agree, if we do more work on the front end aero to try create more downforce then we can safely run a lighter car  Cool
mymedusa
« Reply #1001 on: April 02, 2024, 10:13:24 am »
Bugwelder in Germany has 2 new Alternativ(Drehstrom!), old Style 90mm and 105mm
45Ah 12v
90mm =   2,5kg
105mm = 3,1kg
Catbox
Slave to internal combustion.
« Reply #1002 on: April 23, 2024, 21:23:48 pm »
This thread has always been fun to read to see the innovations that come out.
Those carbon parts are awesome Richie.
« Reply #1003 on: July 23, 2024, 18:14:42 pm »
Been a while since i made anything new that i can show Wink , had people ask for these in past but it was low down on my list, got to them now, weights are showing factory headlight ring and factory glass lense against carbon headlight ring and my plastic headlight lense, every little helps   Grin
« Reply #1004 on: August 24, 2025, 09:30:08 am »
I was talking to Eric Ballard last week and asked him about his lightweight car he ran in the late 80s.
He said he removed all the double skinning from the inside, such that you couldn't tell from outside that the car had been gutted.
In his gearbox, he lightened many of the parts.  He core drilled the mainshaft (but not past 2nd gear)  He said he removed over 1.1 kg from the ring gear alone.  The gears were narrowed and drilled.  I think he said the axles were drilled too.
The end result was that he had a drag car that weighed under 450kg without driver.  And that included a roll cage and wheelie bars.  And all steel body panels.
Hi Bruce
I now own this car, and it may have been that light but its definitely not all steel Wink
Nikke
« Reply #1005 on: September 04, 2025, 14:33:53 pm »
I would need 8 pcs of 12x45mm hexhead bolts with 1,5mm pitch made of titanium. Any suggestions?
« Reply #1006 on: September 06, 2025, 14:41:35 pm »
Hi Bruce
Pictures or it didn't happen.
« Reply #1007 on: September 06, 2025, 14:43:54 pm »
There are a lot of China sellers on ebay that sell low volume quantities of Ti bolts. Most of the M12 bolts are 1.75mm thread pitch.
ibg
« Reply #1008 on: September 09, 2025, 23:31:48 pm »
Nikke, King VW has a good selection of Ti bolts, these are 12mm x 1.5 but a bit short, but worth an email.
https://www.kingvw61.com/shop/p/spring-plate-bolts-titanium
« Reply #1009 on: August 25, 2026, 08:27:37 am »
 Grin
« Reply #1010 on: August 26, 2026, 06:32:09 am »
Richie why? Cheesy
Do you pop rivet that in or glue it in?
« Reply #1011 on: August 26, 2026, 07:15:16 am »
I will make it removable for easy access to gearbox/starter etc below Smiley But other wise I would bond/glue it in like they do on modern cars
PPRMicke
« Reply #1012 on: August 26, 2026, 20:22:00 pm »
Looks great
But we can't use carbon fiber for the fire rating which is steel or aluminum here in the Nordic countries in all car classes
/// Micke
