October 12, 2026, 16:31:11 pm
| | |-+  AssHull's '67 project
Pages: 1 ... 3 4 [5] 6 7 ... 18 Print
Author Topic: AssHull's '67 project  (Read 768514 times)
« Reply #120 on: January 27, 2009, 07:13:16 am »
And after blasting . This was the best work i have ever seen.
« Reply #121 on: January 27, 2009, 19:01:34 pm »
Looks sweet Smiley We've got a little bit more metal work to do, then the body will be getting the same treatment.
I can't wait to start putting clean parts back together!!
« Reply #122 on: January 27, 2009, 20:46:20 pm »
That is the same as i do . Good luck with your car . i bought  mine from California in 1998 , hope i get it finished some time  Sad
Taylor
« Reply #123 on: January 28, 2009, 03:51:41 am »
not to hijack the post Zach but how would you fix the door pilars from doors that have been sprung??? the rain gutters and the metal near is bent over and someone bent it back but the doors work for shit now.  The car is totally striped down right now and I will try to get pix up soon if you think they will help.  thanks
« Reply #124 on: March 07, 2009, 23:10:01 pm »
I'm no body man, I don't know! I might be able to give you my opinion with a picture or two, but it's just that- an opinion!
Finally started working (welding) on the car again, should have pics up soon. Plan is to get it to the bodyshop on Thursday (crossing fingers!!)
« Reply #125 on: March 09, 2009, 01:47:24 am »
Got the trunk section replaced with one from a '64 (6 volt). Found out that piece is one year only like the rest of the damn car!! Can't run the proper '67 fuse box with it, so I welded it up and we'll run a modern style fuse box under the rear seat with plug in style fuses. A lot less wiring heading up to the front of the car this way for a nice, clean look under the bonnet. It's held in by 126 (+/-) spot welds, and a real bitch to replace!! Came out very well though, much better than looking at the magnets of two 6x9's when you look in the trunk!! Also fixed the spring perches for the front hood, the decklid mounts, a couple fender nuts, and it seems like a thousand other little things. NEVER turn a car upside down, you'll find so much more work to do! You've been warned!!!
« Last Edit: March 09, 2009, 01:52:14 am by Zach Gomulka » Logged
« Reply #126 on: March 09, 2009, 02:01:47 am »
I had AssHull pick up a 914 gauge pod so we could mark out the proper placement of the gauges on the dash. When he brought it up I knew immediately that almost all the work we previously did to the dash should be cut out and replaced with the proper piece Roll Eyes So we got on it. I am VERY pleased with the outcome though. The gauges fit perfectly with the little rubber seals in place and everything- just like it came that way. There will be a bit more body work needed on the dash, too much cutting, welding, grinding, and then cutting, welding, grinding some more. Also drilled the dash for a left hand ignition since AssHull is a southpaw Wink
AssHull
« Reply #127 on: March 09, 2009, 02:25:07 am »
thought you were looking for a fuel and temp gauge for a 914?
We are, but apparently they are rarer than hen's teeth. This will suffice for now until we locate the Combi gauge that we really want.
So the fuel gauges are easy to find and the temp gauges are easy to find. Still can't find a combi gauge in the price range that I'm wanting to spend. Well turns out the only difference between a fuel or a temp gauge and the combi gauge is that the combi gauge has both dials. The casing and everything are pretty much the same. Even the dials are the same. So I just found a temp gauge and simply pulled the dial out of it and added it to the fuel gauge that I already had. Presto...Combi gauge!!   Grin
It's not exactly the same. The actual combi gauge has a couple extra warning lights but it serves the purpose that I wanted. It means I have an extra casing now and two extra panels for the back of it but total invested in the gauge is $45 versus the $300+ I found online.
« Last Edit: March 09, 2009, 02:27:33 am by AssHull » Logged
« Reply #128 on: March 11, 2009, 03:56:19 am »
BIRTHDAY SUIT!!! Grin
OgCalLook
Straight outa Riverside!
« Reply #129 on: March 11, 2009, 18:29:16 pm »
Nice work Zach - Love the dash Cool
Tom Hewitson
Bahama Blau Kafer
Zach Gomulka: "California Look is walking softly and carrying a big fucking stick."
Paulus
« Reply #130 on: March 11, 2009, 19:12:57 pm »
Damn looks very nice !...... Cool
Less is More !
« Reply #131 on: March 11, 2009, 20:46:27 pm »
awesome guys!
and yeah you know what i think of the dash  Wink
« Reply #132 on: March 11, 2009, 23:13:59 pm »
THANK YOU!! It really helps keep me going!!
Got the Hooky's panels re-inforced, fitted and tacked in late last night. Copper color is weld thru primer. Plan is to hang the doors tonight and make the neccessary adjustments before welding them completely in. And we decided to perform one more operation on the poor dash! Stay tuned!
« Reply #133 on: March 12, 2009, 03:15:35 am »
Hi Zach Looking Good Whats the hole at the lower left of the Dash For?
« Reply #134 on: March 12, 2009, 04:06:03 am »
Ignition switch. Duh Wink Grin
Wünderwolff
aka Dr. Jeckill
« Reply #135 on: March 12, 2009, 07:39:43 am »
Looking good Zach, are you going to run carpets in the car? If not, do not forget to trim the rails at the bootem of the door opening, real rusttraps and when gone real clean look.
Wünderwaffe are Go!
AssHull
« Reply #136 on: March 12, 2009, 07:59:59 am »
I totally agree. It makes for a real clean look but yes, I'm going to have a full carpet (and headliner) setup. Still don't know what color yet though.  Waiting till the body gets painted before making a final decision.  Huh
« Reply #137 on: March 12, 2009, 18:41:19 pm »
Metal work on the body is finished. Grafted in a dash section from a '72 911 to mount a VDO clock from the same model, filling in the void in the center of the dash. The tach is a loaner until we find the appropriate version, as is the 911 combination gauge until we locate a clock. I'm pretty damn happy with the outcome thus far Smiley
« Reply #138 on: March 12, 2009, 22:16:41 pm »
VERY NICE WORK GUYS Grin
« Reply #139 on: March 12, 2009, 22:33:13 pm »
Thanks Lee!!
Are you still interested in the rear window section/firewall? I've still got it, I just recently got back online after my pc caught a wicked virus- that's why I was missing in action. Let me know.
Etch prime is supposed to happen tomorrow Smiley I still have to drill a couple holes in the dash for the emergency flashers and a power outlet, and weld the heat shield back on to the rear apron... and make it removeable. Other than that, the body is out of my hands and I couldn't be happier Smiley Whilst the body is getting worked over the real fun will start- 1915 IDA motor Grin
wolfswest
« Reply #140 on: March 12, 2009, 22:41:02 pm »
like the ignition key idea, it's real porsche style.
« Reply #141 on: March 12, 2009, 23:15:48 pm »
Thanks Lee!!
Cheers buddy - I crashed my PC the other week Roll Eyes
Here is the sections I need (red and gray areas)
TunedBoost
In it to win it
« Reply #142 on: March 13, 2009, 04:02:43 am »
tight brotha!  lookin real good!
Dennis Mundt
WCB Hitler's Hot Rod
« Reply #143 on: March 13, 2009, 09:00:39 am »
Amazing work. Lookin' good!
« Reply #144 on: April 02, 2009, 22:13:54 pm »
Any New Up Dates Or Pictures On The Progress?
« Reply #145 on: April 02, 2009, 23:48:53 pm »
It's at the body shop... and it hasn't been touched in over a week Angry If I had a place to put it in and get dirty I'd do it myself!!
« Reply #146 on: April 03, 2009, 00:22:34 am »
LOL just like most Body Men and Shops Grin Grin Grin
« Reply #147 on: April 03, 2009, 00:32:15 am »
Why are they all such flakes?? Huffing too much clear coat? I only went with this guy because he is a friend of mine, and his shop is a few doors down from where I work, so I can be there every day to make sure they aren't fucking anything up! Wink
Sam K
« Reply #148 on: April 03, 2009, 02:15:27 am »
I'm all to familiar with body shop limbo. With both my Bug and my Camaro it was took almsot exaclty twice as long as estimated and cost twice as much. Angry  Last week, I had the doors, decklid and rear seat backs from my Thing repainted. The were done in a very timely fashion and the price was right on, but when I went to pick them up, the were the wrong color! They were supposed to have been done (again) yesterday but I havn't heard anyting yet.
« Reply #149 on: April 03, 2009, 02:21:26 am »
It's supposed to be in paint by the end of this month... we'll see...
