August 11, 2026, 16:47:46 pm
Pages: 1 ... 20 21 [22] 23 24 ... 28 Print
Author Topic: My >street/<strip '56  (Read 880753 times)
fahrvergnugen
« Reply #630 on: June 15, 2013, 21:54:42 pm »
Time to start on the fire wall, not my favorite job but it has to be done.
The fire wall will sit 6cm higher as original, so I cut 6cm of the top.
Because of the innerwings I have to make it wider as well
We're getting there.
Paul.
fahrvergnugen
« Reply #631 on: June 19, 2013, 20:25:57 pm »
Weber access.
Paul.
fahrvergnugen
« Reply #632 on: July 06, 2013, 20:43:19 pm »
To follow the rules while building my cage I had to place the seats first.
First I slammed the original seatframe.
After that I mounted the 914 frame on top.
Next step was placing the seat.
Now the 914 and original frame can move foreward to have enough access to the rearseat.
Paul.
fahrvergnugen
« Reply #633 on: July 13, 2013, 20:28:09 pm »
Both seats are in. doesn't look like much. But this has cost me several hours. The original frames are slammed, narrowed, shortened and placed in a differend angle. just for the eye, I closed the side of the frames.
Paul.
fahrvergnugen
« Reply #634 on: July 20, 2013, 21:39:00 pm »
I've bin doing small stuff while I'm waiting for the cage material to come in. Today I have bin modeling the door gab. Due to an accident in the past, the door didn't line up like I want it to do.
Start up the grinder again.
After some hammering.
Paul.
« Last Edit: July 20, 2013, 21:44:54 pm by fahrvergnugen » Logged
fahrvergnugen
« Reply #635 on: August 07, 2013, 16:57:01 pm »
The rollcage is in, only thing left is mounting it Undecided
Shall I transform it in to a delivery van or keep it original ?
Paul.
VWGlassee
« Reply #636 on: August 07, 2013, 21:22:48 pm »
Euh... No  Grin Grin
fahrvergnugen
« Reply #637 on: August 07, 2013, 22:00:57 pm »
Euh... No  Grin Grin
 Grin it's a template I use to build my rollcage.
fahrvergnugen
« Reply #638 on: August 17, 2013, 16:28:19 pm »
Started on the cage today. With these holes I can lower the cage a bid and weld the up side.
Bending the bends in the wright position and keeping it straight is a PITA.
Did you see my special cupper angle measure tool   Grin
Paul.
« Reply #639 on: August 17, 2013, 17:11:51 pm »
Heres how I did my first hoop.
First I located the center of the tube lenght, and then I tacked on a piece of flat stock steel. It was about 200 mm long and would end up sticking out pointing forward in the car, if I left it on.  To this piece I taped a spirit level, so every time I placed the tube in the bender I keept an eye on the spirit level and the hoop came out completely flat Smiley.
Something else that helped a novice like me was that before I made the first bend I punced marks ever 500mm, starting on the center of the tube. Then I could write down the distance from the nearest mark to a given point on the tube bender, and repeat it for the other side. Made it pretty easy.
Good luck!
fahrvergnugen
« Reply #640 on: August 17, 2013, 20:47:24 pm »
That's good thinking Jon.
I am using my digital angle/level tool. Works pretty good.
fahrvergnugen
« Reply #641 on: August 21, 2013, 13:10:14 pm »
De first hoop is in.
I made the connection to the gearbox mount with tape, this way I can measure the angle I need.
Paul.
fahrvergnugen
« Reply #642 on: August 28, 2013, 20:54:45 pm »
Cage fight
Paul.
fahrvergnugen
« Reply #643 on: September 08, 2013, 12:11:44 pm »
DAMN, why didn't I notice this before. After checking the cage measurements, I found out that the gearbox wasn't in line with the middle of the car.
So time to start over again. (attempt nr. 3)
Paul.
fahrvergnugen
« Reply #644 on: September 11, 2013, 20:20:56 pm »
Gearbox is in again. It is further inwards so I had to shorten the cage and framehorns.
Paul.
kev d
« Reply #645 on: September 11, 2013, 23:05:11 pm »
You're getting there! Grin
Bet you can't wait to get all the welding done though Wink
fahrvergnugen
« Reply #646 on: September 12, 2013, 21:04:21 pm »
You got that wright.  Wink
thehanz DVK
« Reply #647 on: September 12, 2013, 21:08:00 pm »
Das drag day next week ?  Grin
fahrvergnugen
« Reply #648 on: September 13, 2013, 20:59:19 pm »
The weather forecast is bad, I think I will leave the oval at home  Grin
fahrvergnugen
« Reply #649 on: October 12, 2013, 21:17:22 pm »
Because of the higher mounted engine and gearbox, the luggage compartment had to be raised as well. This means that is had to be widened. I wanted to use a donor piece from 1954. Now I found out that even this part of '54 sheet metal is different to a '56 piece. But with a little help of a hammer and knee it starting to fit.
Paul.
fahrvergnugen
« Reply #650 on: October 16, 2013, 21:34:14 pm »
8 cm higher, it has become a short firewall
Paul.
henry roberts
« Reply #651 on: October 20, 2013, 09:36:39 am »
wow. what an amazing build.
fahrvergnugen
« Reply #652 on: October 20, 2013, 20:16:50 pm »
fahrvergnugen
« Reply #653 on: October 23, 2013, 20:37:37 pm »
Made the firewall a bit wider.
Wider piece it tacked in.
The difference.
fits pretty well
Paul.
fahrvergnugen
« Reply #654 on: November 06, 2013, 13:43:33 pm »
Firewall starting to take shape. The first weld are made.
Paul.
fahrvergnugen
« Reply #655 on: November 13, 2013, 21:35:37 pm »
Now we're flying.
Time for the final things on the chassis.
fahrvergnugen
« Reply #656 on: November 15, 2013, 21:30:07 pm »
The R&P was only temp tacked in place when the body was on. Back then I had to ditch the sway bar.
Today I welded the R&P brackets in its final place, made new brackets for the sway bar, mounted the sway bar and R&P and made brackets to mount the body to the chassis.
Paul.
fahrvergnugen
« Reply #657 on: November 15, 2013, 22:18:18 pm »
Now the front is done, I started on the rear. The aligning is pretty good.
Paul.
fahrvergnugen
« Reply #658 on: December 04, 2013, 14:08:08 pm »
Not much progress lately. I am supporting son's football matches more than working on the beetle.
Made 2 holes to weld the cage mounting points in.
Dropped the body back on the pan and trial fitted the tubes that go to the gearbox. When these tubes fit properly I can start on the shock mounts.
Paul.
fahrvergnugen
« Reply #659 on: December 18, 2013, 21:49:10 pm »
Very small update.
Made some extra room for the gearbox by inverting the bent. Trying it look original
Paul.
