October 13, 2026, 00:33:47 am
56 strip/street Oval
5
6
7
8
11
Topic: 56 strip/street Oval (Read 240259 times)
jamiep_jamiep
Re: 56 strip/street Oval
Reply #150 on:
December 20, 2010, 09:52:34 am »
Its gonna fly with that motor Pas!
Nice
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
Pas
Reply #151 on:
December 20, 2010, 21:15:26 pm »
Quote from: kaferboy on December 20, 2010, 09:52:34 am
Nice
Hey Jamie
I certainly hope so, I am so pleased I have bagged this motor. There is so much development in it, and from speaking to Ian and Pete still more potential, especially as for my car, it can be less streetable.
I think that this must already be one of the most powerful N/A 1776 motors around and with maybe, close to 200BHP in future
Good luck with getting your car prepped for the drag day and see you there
Last Edit: September 19, 2011, 22:15:36 pm by Pas
Pas
Reply #152 on:
February 17, 2011, 00:41:15 am »
OK a few shots of the work being done on the floorpan at Flatlands engineering.
Alloy fuel line is being run through the tunnel and terminates with bulkhead fittings both ends, It may be a bit of overkill but I wanted the fittings mounted outside of the tunnel to eliminate the risk of fuel escaping inside the tunnel if the fittings develop a leak.
Last Edit: March 03, 2011, 00:00:19 am by Pas
Pas
Reply #153 on:
February 17, 2011, 01:11:13 am »
Mark at Flatlands has made up a neat ali pump mount that incorporates some anti vibration mounts.
kev d
Reply #154 on:
February 17, 2011, 09:53:37 am »
Neat work
Its getting closer to the finish line then..
Happychappy
Reply #155 on:
February 17, 2011, 14:36:31 pm »
Looking good!!
Reply #156 on:
February 17, 2011, 17:27:34 pm »
Very nice and safe, love those brackets. Fantastic Project, respect.
Last Edit: February 17, 2011, 18:03:04 pm by Harry/FDK
benssp
www.callookvw.com
Reply #157 on:
February 17, 2011, 23:59:01 pm »
Mark rang me this morning, amazing what he can do with a sheet of metal, got your answer phone message, I'll call you tomorrow
www.vwheritage.com
My Job
www.bernardnewbury.co.uk
My Team
any work related enquiries to
ben@vwheritage.com
YMCA
thejohn66
Reply #158 on:
February 18, 2011, 00:10:18 am »
Quote from: Pas on February 17, 2011, 01:11:13 am
pleased to see someone else has found a use for mini exhaust mounts. Nice fabrication
Bitburg motor boating club member.
Pas
Reply #159 on:
February 18, 2011, 01:19:01 am »
Thanks for the kind replies guys, I am lucky to have another very talented company working on the car.
Had a few more shots sent through today from Flatlands.
Ali mid mount is now fitted, this is a one off design by Mark.
The tunnel has been relieved of all unnecessary conduit.
Last Edit: March 12, 2011, 00:13:12 am by Pas
Pas
Reply #160 on:
February 18, 2011, 01:30:57 am »
The battery box and cut out switch is in.
The pedals have been drilled and mounted.
Last Edit: March 01, 2011, 01:44:26 am by Pas
Pas
Reply #161 on:
February 18, 2011, 01:41:35 am »
Mark has also been busy with the pillar drill on the solid rear mount and the line lock has been positioned.
Black Sheep
less is more
Reply #162 on:
February 18, 2011, 20:16:44 pm »
I like that , which remind's me i really must get on and get my own mid mount fabed up
13.03 @ 98mph
Pas
Reply #163 on:
February 18, 2011, 20:33:18 pm »
Quote from: Black Sheep on February 18, 2011, 20:16:44 pm
Hey Glenn
Mark had this laser cut by a local company and he saved the pattern, give him a shout if you fancy one.
Black Sheep
less is more
Reply #164 on:
February 19, 2011, 19:54:10 pm »
Quote from: Pas on February 18, 2011, 20:33:18 pm
Hey Glenn
Cheers fella , gonna mount mine on some rubder cotton reels which i can swap for solid Alloy one when the mood take's me
so It'll be a little different from your's .
I've got a template mocked up I just need to get my ass into gear , still playing around with my motor at the Mo
13.03 @ 98mph
Pas
Reply #165 on:
February 23, 2011, 00:25:09 am »
Bit more progress on the pan.
The panels cut out of the tunnel to remove the conduits are now welded back in.
Mark has modified the rear fuel line bracket to an ali bolt in one to make attaching the end fitting easier.
Last Edit: February 23, 2011, 00:29:05 am by Pas
benssp
www.callookvw.com
Reply #166 on:
March 24, 2011, 14:12:13 pm »
Mark@Flatlands will be at the Volksworld show this weekend and will have some of these parts on display, He says he can make anything you want
www.vwheritage.com
My Job
My Team
ben@vwheritage.com
YMCA
Pas
Reply #167 on:
April 08, 2011, 18:47:22 pm »
Had another update today from Flatlands Engineering. The last few mods are now done and the pan will be going in for paint next week.
Mark has made up some stubby front brake line brackets and plumbed in the line lock.
The passenger side bracket incorporates a neat rubber pad/support for the fuel pump.
Last Edit: April 08, 2011, 19:09:03 pm by Pas
fahrvergnugen
Reply #168 on:
April 08, 2011, 19:47:52 pm »
That Laser cut stuff sure looks good, where can we buy a dress-up kit like that
Very nice build, looking forward for the next update.
Paul.
http://fast-air.skynetblogs.be/
Pas
Reply #169 on:
April 08, 2011, 20:14:52 pm »
Quote from: fahrvergnugen on April 08, 2011, 19:47:52 pm
Paul.
Thanks Paul
Rip off Taiwanese kits will be available soon
, alternatively give Flatlands a call/email and they will make you anything you need at very reasonable prices
Your build continues to be very impressive, God know how many hours you have spent measuring, cutting and welding.
Last Edit: April 08, 2011, 20:31:03 pm by Pas
Pas
Reply #170 on:
April 08, 2011, 20:23:23 pm »
Things are progressing on the body prep, the car will soon be all one colour, albeit grey primer.
kev d
Reply #171 on:
April 08, 2011, 20:35:59 pm »
Looking better each visit
Always a big step forward getting a shell into primer & 1 colour
Out this year or next??
Kev
Pas
Reply #172 on:
April 08, 2011, 20:54:19 pm »
Quote from: kev d on April 08, 2011, 20:35:59 pm
Kev
Hey Kev
Next year I am afraid, how about you?
kev d
Reply #173 on:
April 08, 2011, 22:30:15 pm »
Mine should be finished but I've pretty much written off getting it out this year
Its booked in for paint end april / start may but I'm on a different continent so thats a problem
Match race 2012??
Pas
Reply #174 on:
April 08, 2011, 22:41:25 pm »
Deal
Reply #175 on:
April 24, 2011, 06:33:23 am »
Hey Pas--- Thought I'd show you something
http://www.youtube.com/v/GHeSk9P3Ps0
http://selvedgeyard.com/
Pas
Reply #176 on:
April 24, 2011, 11:43:32 am »
Quote from: Fiatdude on April 24, 2011, 06:33:23 am
The beast lives!
Thanks for sharing, how long before you will be terrorising your local drag strip with this beauty?
Reply #177 on:
April 24, 2011, 18:14:25 pm »
It has been fighting me every step of the way LOL -- -- Might be able to get to the dyno in a couple of weeks and then it should be registered to drive -- I'm gonna keep it on the streets for the time being until I can afford to upgrade the transmission so it can take some abuse
Pas
Reply #178 on:
May 06, 2011, 21:51:08 pm »
The floorpan is now painted along with the gearbox, axle tubes, brakes and pedals.
I will be collecting it from Flatlands soon, then the build up can begin, I can't wait
Last Edit: May 06, 2011, 21:58:49 pm by Pas
JSL
Reply #179 on:
May 09, 2011, 13:57:03 pm »
Awesome progress!!
Is it too cheeky to ask to see some more pics of the bike?
J
56 Bug Rat-look
http://www.volkszone.com/VZi/showthread.php?t=583273
54 Bug Cal-look Project
http://cal-look.no/lounge/index.php/topic,9879.0.html
Lil'turbo engine project
Defcon-3
http://www.defcon-3.co.uk
5
6
7
8
11
