October 03, 2026, 14:40:21 pm
| | |-+  Late Looker (type 4)
Pages: 1 [2] 3 4 ... 8 Print
Author Topic: Late Looker (type 4)  (Read 524079 times)
« Reply #30 on: May 27, 2010, 15:51:00 pm »
Hi Ed, any news lately ? (of what i learned sofar is keeping valve clearence stock with aluminum pushrods (expand/shrink) and (almost) zero with chrome-moly). But i'm still learning.
« Last Edit: May 27, 2010, 16:21:57 pm by FDK/Hurry » Logged
Eddie DVK
« Reply #31 on: May 28, 2010, 08:12:39 am »
He Harry (old mate Wink)how are you doing.
how is your car coming along?
any news, well, find some time to work on the car again after a very cold winter in which I didnt do anything.
the engine is almost complete now, needs just some small stuff to finish it.
sparkplugs, which do you use?
some oillines.
Muffler, what system are you using?
here some finished picures
It is ready to go into the car now.
Kind Regards Edgar
« Last Edit: May 28, 2010, 08:23:19 am by Eddie » Logged
Regards Edgar
« Reply #32 on: May 28, 2010, 11:53:23 am »
Looking good ! I just have to do small stuff on the engine and car. I still have to start on the T4 engine for the Ghia.
I'm thinking of losing the DTM and go your way cooling wise. I love the T1 look as well. Muffler on the T1 is a Magnaflow,
but it's loud, maybe i switch to a stainless A1 style muffler.
Arnoud
« Reply #33 on: May 28, 2010, 19:40:28 pm »
@Harry:I'm doing the same at this moment-in steel.I'm picking up the heads next week at Udo's.
@Eddy:nice Grin
Greets,Arnoud
Eddie DVK
« Reply #34 on: May 30, 2010, 10:00:45 am »
Thanks guys for the kind words.
Have done some other stuff.
Got a transistor ingition so the firewall is a liitle bit full on the left site so have to relocate the fuel line because I want to run a Filterking incl presure regulator and gauge.
So this would be the set up.
So need to make a fuel line through the firewall
drill some holes in the firewall
it s in place
Reroute the fuel line
And how it is going to be.
Kind regards Edgar
« Last Edit: May 30, 2010, 10:47:14 am by Eddie » Logged
Regards Edgar
Arnoud
« Reply #35 on: May 30, 2010, 10:43:42 am »
Hi Edgar!
Normally with a Cali-style conversion you would use the higher style manifold(the ones that CSP recommends),I see that you use lower(BAS?) intake manifolds.
They clear the fanhousing but what about the linkage,what system are you going to use?
Greets,Arnoud
Eddie DVK
« Reply #36 on: May 30, 2010, 10:58:03 am »
Hi Arnoud,
I bougt the BAS ones because you could fit the carbs reverse(they got four mounting holes) so that you could adjust the carbs from the inside.
But found out that if I fit them reverse they don t clear the shroud... so have to fit them normal way. Little bit a pitty... But hey...
Have A hexbar as a linkage got them with the carbs they came from a type 4. Have done a little bit of trial fitting, it seems to fit but is bit high for the
trottle cable have to look at this a bit closer...
Kind Regards Edgar
Regards Edgar
« Reply #37 on: May 30, 2010, 15:36:47 pm »
@Eddy:nice Grin
Greets,Arnoud
Cool Cool Cool
Eddie DVK
« Reply #38 on: September 10, 2010, 08:21:36 am »
Hell yeah...
Got the engine runnig for the first time yesterday..
after a lot of mismatch with parts and other stuff...
finaly got to turn on the switch and damn 1 try and it went on directly...
I am very pleased with that.  Smiley Smiley Smiley
Still got a small question I am running a CU transistor ignition, on how many degrees should this be at
idle and at 2500-3000?
some pictures how it is in
Regards Edgar
Regards Edgar
« Reply #39 on: September 10, 2010, 15:18:01 pm »
Looking good Ed !!! Hope she runs well. Were did you locate the oilcooler(s). Do you run the hoses thru the shroud ? Cool
Arnoud
« Reply #40 on: September 10, 2010, 17:50:39 pm »
Well done Ed!
I see that it works with the lower intake manifolds as well-nice!
Regards,Arnoud
ps.is that the economy setup there(only 1cyl.plugged in! Grin?)
Eddie DVK
« Reply #41 on: August 28, 2011, 10:08:16 am »
Ok it is time for an update, after this,
Finally got my engine ready an running, got it trough the APK(Dutch MOT), some fine tuning to do.
Maybe ready to go for the trip to EBI.
Regards Edgar
And this:
Hi Jesse,
I dont no if I am going with the beetle, got a small oil leak I have to find on the front of the engine maybe flywheel seal. Sad
I am going but do not no witn which car.
But if I join you, I will you let you guys know.
Kind Regards Edgar
Ok it was an oil leak on the flywheel seal (an common thing on type 4s) change it with a vitton version and did some tricks after tips how to get a good seal.
got acces to a carlift thanks to my neighbour, a lot easier then only took 3 hours this way.
hm a lot of oil
and engine in again.
Did some carb tuning and did some driving to work(a few hunderd km s) I must say engine pulls ok I am very happy with torque in low rpms  Smiley
and finaly installed new rims
Still some km s to do than off to the dyno for some fine tuning.
But firts holiday time for me.
Kind Regards Edgar
« Last Edit: August 28, 2011, 10:12:29 am by Eddie » Logged
Regards Edgar
JeePee/DVK
« Reply #42 on: August 28, 2011, 11:42:17 am »
Happy holiday Edgar.
Grtz:JP.
Eddie DVK
« Reply #43 on: August 29, 2011, 22:40:22 pm »
Grtz:JP.
Thanks JP,
I will be back just before DDD, hope to be there with the beetle.
Kind Regards Edgar
Regards Edgar
« Reply #44 on: December 13, 2011, 17:53:01 pm »
Hi Edgar, any news and/or pics ?
Eddie DVK
« Reply #45 on: December 13, 2011, 21:20:18 pm »
He Harry as a mather affect there is.
Only forgot to post it here. Embarrassed
Got it on a dyno in the begining of october and got the carbs sorted out.
Did 6 runs.
And this is it for now:
123HP
180NM torque
Nice flat torque curve.
The HP curve is still climbing even at 6000rpms, so there is more in it, but I was afraid to go higher in rpms.
I can say I am really pleased with it, it drives very good  also in low RPMs. Smiley
Regards Edgar
Regards Edgar
« Reply #46 on: December 13, 2011, 21:24:10 pm »
So it's a constant steady pulling Panzer ! Cool !
Eddie DVK
« Reply #47 on: December 13, 2011, 21:51:37 pm »
Yep, but I was a bit disappointed when I heard the HP (was hoping 130-140) Wink, but the flat torque curve made me very happy,
this is what gets you going on the street and it does it even far above the 100km/h...
Hope is a good inspiration for you to go on Harry, if even I can (almost) finish a car Cheesy.
Regards Edgar
Regards Edgar
« Reply #48 on: December 13, 2011, 22:04:45 pm »
"Hope is a good inspiration for you to go on Harry"
Yess!
Ed, where is that dyno guy located ? Any carburettor expierence ? IDA'S ?
« Last Edit: December 13, 2011, 22:12:11 pm by Harry/FDK » Logged
« Reply #49 on: December 13, 2011, 22:15:37 pm »
@Eddy:nice Grin
Greets,Arnoud
Steel pics or info Arnoud..maybe pm ?
Eddie DVK
« Reply #50 on: December 13, 2011, 22:28:34 pm »
Yess!
Dyno (one of the few that also can do 4wd cars) is located in Den Haag, is the closest to my home/barn where my (and my friensds) car is, only about 15km away.
Called Beek autoracing, they are very well known in the circuit racing cars, they did our ford sierra race car also.
Verry nice people also and they take a lot of time for you.
Don t know if they have expierence with IDA's but they do a lot old racecars with carbs (a lot of old lotus race cars also, owner races one for many years).
They also do a lot of new porsche 911s.
They where verry pleased that I came with my beetle, the owner use to drive one when he was young they even made pictures and placed them on their site.
How cool. Smiley
Have a site, take a look.
www.beekautoracing.nl/
http://www.beekautoracing.nl/gallery.php?id=6  Grin Grin
Regards Edgar
« Last Edit: December 13, 2011, 22:31:22 pm by Eddie » Logged
Regards Edgar
« Reply #51 on: December 13, 2011, 23:09:43 pm »
I would go a little higher with the rpms on the dyno. With the schleicher cam may be 7000 should work for testing, these cams do not need much spring pressure
Eddie DVK
« Reply #52 on: December 13, 2011, 23:26:03 pm »
Thanks for that info Udo, will do that next time, hoping to buy some 45 dellorto s next summer and than back on the dyno again.
Thanks for the work on the heads Udo. Wink Did not see a lot of dyno sheets with a torque curve that flat. Grin.
Regards Edgar
Regards Edgar
Rasser
« Reply #53 on: December 14, 2011, 20:54:11 pm »
Nice results!
Donīt be disappointed with the results, next time give it some more revs :-)
I mean no disrespect, but looking at the torque curve it doesnīt look that flat to me. If you look at it then it ranges from 50- 455. If the range was 50-250, then the curve would not look that flat. It starts at 115? then tops at 177? then goes back to 140?
Get my point? - if you narrow the range down, then the curve is not that flat.
I donīt mean this in no negative way, just trying to clear out a common mistake.
If you wanīt a flat torque curve, then look at this NA subaru conversion in a Volkswagen based Porsche Speedster - amazing!!
Starting at 210, topping at 232, then down to 225?
« Last Edit: December 14, 2011, 20:56:48 pm by Rasser » Logged
1955 type1
1966 type2 13w deluxe
Eddie DVK
« Reply #54 on: December 14, 2011, 23:20:40 pm »
Nice results!
No problem at all Rasser, I am open to all comments, especially to improve my performance  Smiley.
your comment on the torque curves, I have seen a lot of type 1 curves that have a more steep curve then this... starting a lot lower then peaking and dropping fast again.
So that's why I am saying it is ''pretty flat''  Grin
Regards Edgar
Regards Edgar
Eddie DVK
« Reply #55 on: March 06, 2014, 09:39:39 am »
Ok, a little update back at this point again,
leaking flywheel seal.
http://cal-look.no/lounge/index.php/topic,21131.msg291184.html#msg291184
So engine is out again, lots of oil in the trans bellhouse
Very wet pressure plate and clutch
The only positive part is I always wanted a removable rear valance... so I will do this in one go.
Regards Edgar
« Last Edit: March 06, 2014, 09:53:40 am by Eddie » Logged
Regards Edgar
Joe VW
« Reply #56 on: March 07, 2014, 04:00:30 am »
Did you replace all the galley plugs behind the flywheel with tapped threaded plugs? The stock plugs are notorious for leaking. On an assembled running engine I have removed the stock plugs and replaced them with oversized, tapered solid ones I made on a lathe. (EDIT)  I went back and saw your threaded plugs.
 If you have another case and crankshaft install the flywheel  check for run out at the seal surface. Polish the seal surface like a mirror. Make sure there are no cracks in the case especially around the oil plugs.
Also the seal needs to be installed further than flush by about 1/8" with a little oil on the seal or it will burn up.
« Last Edit: March 07, 2014, 04:27:52 am by Joe VW » Logged
Eddie DVK
« Reply #57 on: March 07, 2014, 08:38:27 am »
Hi Joe,
Yes I did al the galley plugs.
The last time I replaced the flywheel seal, I did a little bit of polishing on the flywheel surface, will do this also
on the new ones I have.
The only thing I did was place the seal flush, (as is in the manuals) and you are the second one that says (also spanners on here) to put the seal in further... so I think I am going to do that.
Thanks for your reply.
Regards Edgar
Regards Edgar
Eddie DVK
« Reply #58 on: March 09, 2014, 09:54:10 am »
Ok, there are a lot of holes, but it is not that hard to do.
Finaly got my removable valance.
I going to reuse the valance, because those repo sh.... don t fit at all... fu... Undecided
Regards Edgar
« Last Edit: March 09, 2014, 09:56:06 am by Eddie » Logged
Regards Edgar
Eddie DVK
« Reply #59 on: March 09, 2014, 10:10:08 am »
Oh forgot to show, but also got me some daymoulds
They are realy nice and perfect fit.
Regards Edgar
« Last Edit: March 09, 2014, 10:13:48 am by Eddie » Logged
Regards Edgar
