November 03, 2026, 00:32:26 am
| | |-+  2332 Clutch disc?
Author Topic: 2332 Clutch disc?  (Read 11656 times)
eh
« on: July 16, 2009, 10:20:29 am »
    My 66 weight is about 2100 lbs and I’ve some question.
   CB  Aluminum Case
   CB Super Race crank 84mm. Chevy journals
   94mm. Cima Mahle piston with Jaycee 94mm.long cylinder
   5.7 inch Scat H-beam rod
   Engle FK 10 ,Autocraft 1.4:1 Roller Rocker Arm
   Straight cut cam gears
   8.5 to 9:1 compression ratio
   CB 044 Wedge port cylinder head  44*37.5 mm.
   48 IDAs Skat Trak Manifold
   1 ¾” Merged Header
   12.5 lbs Lightweight Forged Chromoly Flywheel
   Kennedy 2600 lbs Pressure Plate
   Rhino case 3.88 r&p with solid mount
   3.10/2.06/1.58/1.21
   Aluminum side cover
   Sway Away Racing axle
   Which clutch disc to fit with my combo?
   Centerforce dual friction, 4 pucks or solid center clutch disc
   use for weekend drive only,sometime in the drag strip
   Thanks for every comments.
   Eh. Smiley
« Reply #1 on: July 16, 2009, 11:51:50 am »
Kennedy stage 2 and daiken disc . Stage 3 and 4 puck is a gearbox killer ..
« Reply #2 on: July 16, 2009, 13:11:33 pm »
I used a 4 puck and a stage 2 in a 1640lb car and it wasn't a clutch pedal, it was an on/off switch. I wouldn't use one in a street car.
Jonny Grigg
« Reply #3 on: July 16, 2009, 22:33:41 pm »
stage 1 and black magic.
No Compromise. O/FF111
John Rayburn
« Reply #4 on: July 16, 2009, 23:20:06 pm »
Stage two and a Daiken.
I also park at Nick's.
« Reply #5 on: July 17, 2009, 00:52:31 am »
same here. Same p/p and same disc since 1998
Paul Bate
« Reply #6 on: July 17, 2009, 15:35:16 pm »
I agree with Udo! that would be my choice.
Paul
Instagram: flatfourperformance_vw
Real street since 1994 drive to the track race and drive home no bull !
11.49 Natually Aspirated
10.79 Nitrous
1960 lbs with driver!
JIMP
« Reply #7 on: July 17, 2009, 16:06:40 pm »
I'm also with Udo, stage 2 and Daiken
Friendly
Dimitrios
eh
« Reply #8 on: July 17, 2009, 17:25:25 pm »
 Thanks for all answer. Grin
 Can I use daikin disc with stage 3 cause Ihave it already, or I could change the pressure plate to stage 2.
 How about centerforce dual friction use with stage 3 ?
 Eh.
« Reply #9 on: July 17, 2009, 17:35:23 pm »
i dont think you will need the dual friction,
and i would step down to a stage 2,
thats what i use in my 2276
noo slipping!
« Reply #10 on: July 17, 2009, 23:19:26 pm »
Stage 1 and dual friction. Works fine. 2276.
« Reply #11 on: July 18, 2009, 15:42:13 pm »
I would not use a black magic in a gearbox with syncros unless you plan on changing them every winter.
That said, the thin black magic is lighter and might be better.
Best rgs
BB
eh
« Reply #12 on: July 22, 2009, 07:08:01 am »
 Thanks, everyone.. Grin
 Eh
gizago
« Reply #13 on: July 22, 2009, 09:31:13 am »
Has anyone used the ACE copperhead disc??
« Last Edit: July 26, 2009, 13:19:53 pm by gizago » Logged
