April 29, 2026, 21:25:53 pm
352122 Posts in 28887 Topics by 6918 Members
Latest Member: Nallepuff
| | |-+  Reliable N/A 225-230hp type 1 engine?
Pages: 1 2 3 [4] 5 6 Print
Author Topic: Reliable N/A 225-230hp type 1 engine?  (Read 185100 times)
-Alex-
« Reply #90 on: February 25, 2011, 08:14:40 am »
I asked from Berg, they dont make anymore special order cranks, even if its listed.
http://www.geneberg.com/cat.php?name=Special%20Order%20Crankshafts&cPath=88
drgouk
« Reply #91 on: February 26, 2011, 08:13:56 am »
Try Roger Crawford at heads up performance, I got one of his cranks for my 2789cc pauter street motor, Nice piece, makes a scat bilet crank look rather average.
-Alex-
« Reply #92 on: February 26, 2011, 10:34:19 am »
I have contacted him, but i havent got answer yet.  I even did 3D cad modell  Grin
max2919
« Reply #93 on: February 26, 2011, 17:36:58 pm »
If I do a engine for my Barndoor it will be,
WBX convert to OXY!
88mm Chevy journal t4 main flanged crank.
5.88" Eagle rods.
Rolercam and lifters. (FK89)
101.6 cylinders.
A/F heads or MS230 heads.
BIG HX40 Turbo.
Halltech.
Cranktrigger.
This is not a N/A engine with only 225-230hp Grin
VW 57 Ghia RLR 2919cc TURBO!
Porsche 356A Coupe replika.
« Reply #94 on: February 26, 2011, 17:47:26 pm »
WBX convert to OXY!
5.88" Eagle rods.
101.6 cylinders.
BIG HX40 Turbo.
Halltech.
Cranktrigger.
Why a roller cam like FK89 ? That cam grind does not need roller lifters ... But if you want one i have a roller cam with FK89 grind for sale :-)
drgouk
« Reply #95 on: February 27, 2011, 09:46:59 am »
Roger can be hard to get a response out of, Maybe try calling. He always comes through, hes just a little slow.
-Alex-
« Reply #96 on: March 01, 2011, 08:46:44 am »
Roger did answer, he can have made it Smiley Still waiting answer from moldex. Always gotta ask from at least two places Grin
-Alex-
« Reply #97 on: March 01, 2011, 09:21:12 am »
Yep, but its not welded crank and it is 86 stroke -  I am not going to argue with nobody about this  Grin   Still it is a lot of money, but i have to think.
« Last Edit: March 01, 2011, 09:25:21 am by -Alex- » Logged
« Reply #98 on: March 01, 2011, 09:24:35 am »
Dam, all that money and time and all you need to do is to convert a WBX case and use a WBX crank for the best combo available. Remember - you`re only after 225 - 230hp. A result that was achieved years ago and with several engines to prove it. You do not even need IDA`s to do it:
<a href="http://www.youtube.com/v/iFk4hdd_tG4" target="_blank">http://www.youtube.com/v/iFk4hdd_tG4</a>
You could copy the receipe I mentioned in the first reply here but be aware, you would end up with more than 230hp. Or for a interesting Oxy boxer thread you can read this on our Norwegian forum:
http://www.vwnorge.no/index.php/topic,19860.0.html
« Last Edit: March 01, 2011, 09:38:22 am by BeetleBug » Logged
-Alex-
« Reply #99 on: March 01, 2011, 09:29:02 am »
Newer know if there is more than 225hp.. Heads MS230, JPM 282@0.050" cam, 1.4 rockers, 2386cc, fuel injection. Also TF-1 case i am thinking. I havent seen personally TF-1 case, but i have heard mostly good about it.
BB, I think it will be similar combo as on your first post. I like this also:
http://cal-look.no/lounge/index.php/topic,12883.msg198712.html#msg198712
« Last Edit: March 01, 2011, 09:47:56 am by -Alex- » Logged
« Reply #100 on: March 01, 2011, 09:57:41 am »
The one in the link is a LOT of money and I have a hard time understanding why you should pay a small fortune for a exotic engine with 253hp when you can achieve 245hp using off the shelf parts. It is NOT the fancy parts that will give you the HP - it is the build.
I rest my case.
-Alex-
« Reply #101 on: March 01, 2011, 10:27:34 am »
Yes, some fancy parts will not give more HP, only tad more reliability maybe  Smiley
Torgeir Schibevaag
« Reply #102 on: March 01, 2011, 11:59:12 am »
Some of the engines linked to in this thread has been driven, and driven hard for years now...  How reliable does it nead to be?
The way i see it you ar more concerned with the name of the parts, than the goal you have set yourself.... wich in all respect it fine, but you may get dissapointed  if you ad cost/use into the equation...
Regards
Torgeir
« Reply #103 on: March 01, 2011, 19:44:15 pm »
Roger's cranks are real nice and look strong....
cassa
« Reply #104 on: March 01, 2011, 21:50:28 pm »
Just read through this thread..
A "easy" solution for the target 225hp would be:
WBX case AND crank. Best crank there is.
good rods
correct camshaft.
101.6 pistons and cyl.
MS230 101,6 heads with WBX stud patern.
No need for a §§§§§§§§ crank when Volkswagen already has made one for you. Smiley use the money on the heads instead.
reg c
-Alex-
« Reply #105 on: March 01, 2011, 22:04:50 pm »
It was surprise that moldex custom made 86 stroke crank is actually a lot cheaper than heads up perfomance (Roger Crawford) one. Well, about 700 dollars cheaper.
I like one piece cranks more than welded cranks. But i have not heard anything really bad about welded cranks. And TF-1 case is not so expensive any more.
-Alex-
« Reply #106 on: March 08, 2011, 11:51:41 am »
When using 101.6mm pistons, then there is no possibility to use doghouse fanshroud. Does doghouse wide fan fit to aftermarket non-doghouse shroud?
karl h
« Reply #107 on: March 09, 2011, 07:53:45 am »
it is possible to use a doghouse cooler on a wbx case (or even a type 4 case) using a type 1 cooling setup. you have to route oil lines through the fanshroud and connect via a sandwich thermostat from the oil filter. sounds more complicated than it is. the cooler can be suspended on the shroud, so you dont need the boss on top of the case
got a drawing somwhere but cant find it
« Last Edit: September 14, 2011, 06:49:18 am by karl h » Logged
-Alex-
« Reply #108 on: March 09, 2011, 12:21:24 pm »
Okay, i have seen that kind of setup, i think Stripped66 had it once.
What do you think, does these 101.6 cylinders have enough fin area?
http://www.aircooled.fi/shop/index.php?productID=1344&picture_id=935
Stupid question, but how much would be power difference between 86x94 and 86x101.6 engine, if same cam and heads etc are used?  Cheesy
Haven't yet heard any problems with 4in bore engines, is there any? Wink
« Last Edit: March 09, 2011, 12:29:57 pm by -Alex- » Logged
Tomi
« Reply #109 on: March 09, 2011, 14:36:10 pm »
Those cylinders are far from round, I've had 2 sets. I have stress plates for honing and can borrow them if needed.
As you know you can't use same heads with 94mm and 101.6mm cylinders. But all other things being equal the heads will flow better with 4" cylinders due to more space between valve and cylinder wall.
-Alex-
« Reply #110 on: March 09, 2011, 14:47:43 pm »
I have heard too same problems. 101.6 nickies would be good choice, but  they are custom made, not much more expensive than normal nickies, but still expensive.  With the 4in bore, everything looks so thin, except cylinder walls.
-Alex-
« Reply #111 on: March 10, 2011, 22:11:49 pm »
Does 101,6 cylinders cool as well as normal 94 cylinders? What is their wall thickness?
« Reply #112 on: March 11, 2011, 01:52:53 am »
I'm sure the fin area is much less, so my guess would be no.
Stripped66
« Reply #113 on: March 14, 2011, 12:27:46 pm »
it is possible to use a doghouse cooler on a wbx case (or even a type 4 case) using a type 1 cooling setup. you have to route oil lines through the fanshroud and connect via a sandwich thermostat from the oil filter. sounds more comüplicated than it is. the cooler can be susoended on the shroud, so you dont need the boss on top of the case
Rocky Jennings made the oil cooler adapter that I used to run in a dog-house shroud (I'm now running a POS Bergmann 911 shroud...). The adapter bolts to the deck of the case on the 3/4 side, which means you need to drill and tap the case to mount the adapter.
If that's not your cup of tea, a block of aluminum and a couple of hours on the mill should turn out a solution.
« Reply #114 on: March 14, 2011, 19:16:02 pm »
What heads do you have ? Or did you relocate the stud holes on the case ?
Stripped66
« Reply #115 on: March 15, 2011, 00:40:55 am »
Eccentric case inserts.
« Reply #116 on: March 15, 2011, 13:02:02 pm »
That's nice , in my opinoin and experience it is the strongest engine combo
-Alex-
« Reply #117 on: March 21, 2011, 11:27:19 am »
What flywheel bolts with WBX style cranks? Are dowellpins needed? I was thinking these bolts:
http://www.ahnendorp.com/product_info.php?language=en&gm_boosted_product=B-A-S--Spezial-Schwungradschrauben-VW-Typ-4&VW-Typ-4---Porsche-914-Motorenteile-und-Bearbeitungen=Schwungraeder&products_id=939&
Uh, also found this video about chinese vs. german t4 flywheel
<a href="http://www.youtube.com/v/MKDiZRTHO6M" target="_blank">http://www.youtube.com/v/MKDiZRTHO6M</a>
« Reply #118 on: March 21, 2011, 15:21:46 pm »
This one is running stock used bolts:
-Alex-
« Reply #119 on: March 21, 2011, 15:31:42 pm »
Yeah, i calculated with using solidworks that type 4 attachment is at least 50% stronger with these bolts than type 1 wuth 8 dowells...but thats just in theory.  Nice car BTW Smiley
