October 12, 2026, 21:34:55 pm
Reliable N/A 225-230hp type 1 engine?
5
6
Topic: Reliable N/A 225-230hp type 1 engine? (Read 209093 times)
-Alex-
Re: Reliable N/A 225-230hp type 1 engine?
Reply #120 on:
March 28, 2011, 11:31:37 am »
Who at europ can do this kind of thrust setup if i decide to buy flanged crank? Case will be TF-1
neil68
Reply #121 on:
April 10, 2011, 02:12:17 am »
Just received the MS230 heads for my 2332 cc and will be running with IDA's, 10.5:1 CR, etc, again.
Any ideas on camshafts? I'm currently using a Web 226 which has 278 degrees at 0.050" and 0.570 lift (with 1.4 rockers).
Also, have a Web 86C on hand. Perhaps I should make the jump to an FK89 (282/0.582") or Web 251 (285/0.588")? Would like to get low 12's or even an 11.99 ET in my heavy Beetle (2000 lb with driver).
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
drgouk
Reply #122 on:
April 10, 2011, 09:56:30 am »
Quote from: neil68 on April 10, 2011, 02:12:17 am
I would look at one of Johanes Raptor cams, Sounds like he has spent alot of time on his cam pro getting the ramps to work with alot less spring pressure.
Reply #123 on:
April 10, 2011, 15:59:39 pm »
Quote from: drgouk on April 10, 2011, 09:56:30 am
YES! Complete the package ... JPM heads & complete valve-train. Makes sense ...
TxT
-Alex-
Reply #124 on:
May 03, 2011, 20:34:19 pm »
Oh sorry, i didnt notice that here is more posts
I plan to use raptor cam, but not yet don't know what. Here is complete(?) list of raptor cams:
251° 10.0mm
258° 9.57mm
263° 9.64mm
274° 10.35mm
280° 10.50mm
282° 10.7mm
287° 11.43mm
293° 11.25mm
Johannes recommended 282 degree @0.050" cam, but i may put 274 or 280 degree cam. I need torque to move steel bodied beetle fast with stock ratios
Finnish racer Jarmo Lummi says that heavy stock bodied beetles need more lift than degrees, i think there is some truth
I have bought some new parts from DRD, bugpack 86 stroke flanged crank and scat 5.7" rods. I am planning to use similar bronze thrust bearing setup as jeff denham is using, just need carefull planning and few junk cases to try first. With cad design i think i could design the bronze shims and drilling jig. I have decided to skip 94mm pistons, so i have sold my wisecos and doghouse cooling stuff (except yet new DH cooler), nickies are still on my long waiting list...and 98+ bore.
Neil, have you thought fuel injection? I have 2x48 tb's for my engine with megasquirt. Newer actually driven with them, but hoping to get better throttle response. Your cam sounds okay, but it is possible to get few hp with similar degree raptor cam, and surely it will work wery well with MS230 heads
-Alex-
Reply #125 on:
September 13, 2011, 19:54:38 pm »
Ok, TF-1 case for 101.6 barrels and 101.6 Nickies are coming slowly...maybe before christmas
What size merged header for 2789cc 250+hp engine? I was thinking 1 7/8" = 47mm, also it should be stainless. Where to get? Turbothomas? Remmele recommends 48mm primary tube header for 250hp engine.
And what cooling system? 36hp style fan housing with latemodel doghouse fan or porsche fan? Obviously doghouse cooler cannot be used..
Yes, i will build this kind of engine..and post pictures...
Last Edit: September 13, 2011, 19:59:43 pm by -Alex-
-Alex-
Reply #126 on:
May 25, 2012, 06:54:02 am »
I got my LN engineering custom cylinders and JE pistons, holy ****! I have never had so light and shiny pistons and cylinders
Pistons are FSR type, even lighter and stronger than normal JE, they are with 27mm compression height.
Cylinders are with 94mm mahle outer dimensions and WBX stud spacing.
Ok, now waiting "the experts" come to say these are totally unnecessary
Reply #127 on:
May 25, 2012, 08:06:35 am »
Quote from: -Alex- on September 13, 2011, 19:54:38 pm
Quote from: -Alex- on May 25, 2012, 06:54:02 am
So did you not go for 101.6 bore? I dont understand what you mean by 94mm mahle outer dimensions and wbx stud pattern,the studs dont look far enough apart for wbx pattern if that is 94mm bore?
-Alex-
Reply #128 on:
May 25, 2012, 10:33:29 am »
Sorry, yes they are 101.6mm, i did design with LN the outer dimensions close 94mm cylinder dimensions. Stud spacing is indeed WBX. I'll take soon picture with 94mm iron cylinder.
Reply #129 on:
May 25, 2012, 10:39:43 am »
That makes more sense
-Alex-
Reply #130 on:
May 28, 2012, 07:30:19 am »
Yeah, the cylinders feel quite solid. Wall thickness looks good on both ends. Fins are only 1,8mm thick and 2,3mm apart
For the TF-1 case and flanged crank, i am goiing to use bronze thrust setup at No 1. main, Todd at precisionalloy recommended this way and he has done some designing about it.
Car will be hardcore germanlook style 1300 beetle with porsche brakes and mendeola a-arm front suspension
Last Edit: May 28, 2012, 13:27:32 pm by -Alex-
-Alex-
Reply #131 on:
June 19, 2013, 16:53:37 pm »
I got the heads from Thorsten Pieper; reason i went with his heads, because they are tried and tested well cooling heads, even i have my own cad 3d model of the heads.
http://cal-look.no/lounge/index.php/topic,21032.0.html
Case is also soon here, with Roger Crawford installed bronze thrust bearing setup and porsche oilsquirters.
-Alex-
Reply #132 on:
August 15, 2013, 20:18:36 pm »
Got some valvetrain parts, JPM Ti retainers, Manley 48x38 117mm valves, Berg locks, 13/12mm guides.
Later JPM dual springs and seats, and then to the headporter.
-Alex-
Reply #133 on:
September 08, 2013, 20:59:27 pm »
TF-1 case arrived with hoses, it looks so nice compared to autolinea cases. I checked the hoselenght to car and it seems there is enough for front oilcooler mount and drysump installation. BMW main bearings and bronze thrustbearing came with case. I did trial assembly with crank, cylinders and heads.
The camshaft, connecting rods and oil pump are still missing. I did order from demontweeks a 360x190 (5.7 liters) drysump tank with Mocal thermostat.
End play is pretty tight, about 0.05mm, i will have to sand a bit bronze bearings on the glass. Due to a TF-1 case through bolts and 4 "bore cylinders i had to take a little bit material from cylinders, and possibly to get smaller diameter washers under througbolts.
There was also problem with TF-1 and LN engineering / ARP headstuds, because TF-1 case has no provision for 3rd cylinder deepstud, and ARP kit has one deep stud like stock or normal performance studs.
Also ARP studs for type 1 nickies arent available any more. Todd Francis does not recommend the make the thread deeper - but no problem, fortunately Raceware has suitable headstud set that is approved by LN Engineering and they also use them now.
I am also thinkin to make cad designed rear mount, because case has bus style rear mount.
Last Edit: September 08, 2013, 21:17:16 pm by -Alex-
-Alex-
Reply #134 on:
September 08, 2013, 21:00:19 pm »
First i was lazy after posting this to finnish VW forum, so i translated this text with google translator:
Lohkokin already arrived with hoses, hienohan it is. Hoses seems perfectly adequate to get away and are really flexible teräspunosteflonletkuiksi. BMW main bearings and bronze päittäisvälyslaakerit block. I heaped a trial basis in the crankshaft, cylinders and lids with.
The camshaft, connecting rods and oil pump are still missing. 360x190 (5.7 liters) in size kuivasumppusäiliö ordered Mocalin with the thermostat.
End play pretty tight, about 0.05mm, will have to grind a bit päätymmäisiä bronze glass. TF-1 block through bolts and 4 "bore cylinders because had to take a dremel stuff and possibly lower sweepings through bolts.
LN Engineering kansipulttien with became a problem, because in three bowl long tiller bolt, Todd Francis does not recommend the thread to do deeper - no emergency, fortunately Racewarelta can be found in ST Engineering's recommended preferably suitable cover bolt kit and that the LN engineering using T1 and T4 engines, I understand that the ARP brought kansipulttien price time briskly
Reply #135 on:
September 08, 2013, 21:15:06 pm »
Wow this looks nice!
NoBars
Reply #136 on:
September 09, 2013, 01:29:34 am »
Roller cam?
-Alex-
Reply #137 on:
September 09, 2013, 06:13:49 am »
At the moment i am just thinking JPM cam, the 282 degree one, JPM recommended that. I have Udo Becker light tool steel lifters. Case has also porsche oilsquirters.
Reply #138 on:
September 09, 2013, 15:09:19 pm »
2 plugs per cylinder...?
Reply #139 on:
September 09, 2013, 19:53:04 pm »
Looks like it, Donny!
Wow! This should really be something else when you get 'er going, Alex! Very Nice!
There are some really impressive builds going on lately ...
TxT
-Alex-
Reply #140 on:
September 10, 2013, 06:34:26 am »
Yes, Thorsten heads have two plugs per cylinder - i dont know what
distributor
he uses, but i will use dual
wasted spark coils from 034 motorsport
Dead Dog
Reply #141 on:
September 10, 2013, 13:06:22 pm »
Quote from: -Alex- on September 08, 2013, 20:59:27 pm
OOOOOOOOOFF
VWDRC PRO 102 - 11.85 @ 107mph
T1 1914 omex 600 t3/4 turbo
WRP Paint & Restoration - VWDRC Sponsor 2012 & 2013
K-Roc
Reply #142 on:
September 10, 2013, 21:09:39 pm »
Quote from: -Alex- on September 10, 2013, 06:34:26 am
distributor
Don't use a distributor, Go crank trigger with coil drivers to your wasted spark coils..... eezy peezy..
-Alex-
Reply #143 on:
September 10, 2013, 21:30:49 pm »
Of course triggerwheel - i am using megasquirt.
NoBars
Reply #144 on:
September 11, 2013, 01:55:07 am »
You got everything else, go roller.
-Alex-
Reply #145 on:
September 11, 2013, 06:19:54 am »
Why roller for street and trackday engine? You need heavy springs etc. JPM cams and light valvetrain works wery well
-Alex-
Reply #146 on:
September 11, 2013, 18:29:14 pm »
I am also thinking to use Scat 5.7 H-beams, should be adequate. I dont know the current Pauter rod price, but Carrillos are at least $1500.
Reply #147 on:
September 11, 2013, 19:24:37 pm »
take the lightweight pauter and you have rods for a longer time than the others
www.Udobeckertuning.de
-Alex-
Reply #148 on:
September 11, 2013, 21:04:38 pm »
Pauters are $898 - considering them. How much lighter is it compared to a Scat etc?
Reply #149 on:
September 12, 2013, 01:56:58 am »
Considering the production process of them all against price point, Pauters are a GREAT deal!
Hell, I think I've just convinced myself to buy a set! LOL
TxT
5
6
