October 12, 2026, 17:00:25 pm
| | |-+  My 65 race car
Pages: 1 ... 19 20 [21] 22 23 ... 32 Print
Author Topic: My 65 race car  (Read 708823 times)
Andy Sykes
« Reply #600 on: August 15, 2013, 16:29:20 pm »
its not supported by the camera system and dash im using
http://www.race-technology.com/video4_2_7539.html
http://www.race-technology.com/dash2_2_31.html
other than that it looks very good
cheers andy
Andy Sykes
« Reply #601 on: August 24, 2013, 18:41:16 pm »
Started on finishing the front end now  I know the trans parts are on there way at last, I need to machine out the boxster hubs  to 55mm to accept the Caymen coilovers
Inset pressed in place for the coil over Smiley
Cheers Andy
Andy Sykes
« Reply #602 on: August 28, 2013, 20:05:33 pm »
Bit more done today realised why bother with boxster hubs when you need Cayman  hubs and they seam a nicer hub and lighter Smiley
Making the hub for the brake rotor
Caymen hub is on the right
Rotors on just need to make the calliper bracket
Cheers Andy
« Last Edit: August 28, 2013, 21:19:33 pm by Andy Sykes » Logged
Andy Sykes
« Reply #603 on: September 02, 2013, 16:54:14 pm »
Bit of a milestone today the front end is assembled and tight and on the floor ready for fingers crossed this week to have all the geometry checked and set. Before we go any further the spacing has worked out just as I hoped
transmission parts sound be here end of the week so I can check nothing too much has to moved the on to body work Smiley
cheers andy
Andy Sykes
« Reply #604 on: September 03, 2013, 19:24:28 pm »
I've got to finish the very front of the car protect the fuel cell, and work a way to hinge the flip front as it needs to go up and over.
Cheers Andy
« Reply #605 on: September 03, 2013, 20:14:02 pm »
I don't think you will need the wheelie bars with all that at the front Shocked Cheesy
I would worry that you will get some electrical interference with all that so close together, the MSD DIS  2& 4 are particularly troublesome with cross talking with other electrical signals
Keep working away on it and we might actually find out if it does or not Grin
Andy Sykes
« Reply #606 on: September 03, 2013, 20:53:32 pm »
I'm trying, I was worried about the output voltage from the ds4 about 300v I've done my best using screened cable but like you say time will tell
Cheers Andy
Andy Sykes
« Reply #607 on: September 04, 2013, 16:39:06 pm »
bit more done today
started on the alternator stand nearly done needs a bit more fettling
cheers andy
dannyboy
« Reply #608 on: September 04, 2013, 18:12:40 pm »
cool  Cool
8.77@156.8mph
O/FF 60
bedjo78
« Reply #609 on: September 05, 2013, 02:58:31 am »
i like the fabrication .....
Andy Sykes
« Reply #610 on: September 05, 2013, 16:52:06 pm »
thanks guys
bit more done fuel tank protection
and the mounts for the vac pump ive got to move the pump round but you get the idea
started on the bracket for the flip front hinge
more tmw or I may just go the santapod
cheers andy
Andy Sykes
« Reply #611 on: September 06, 2013, 17:58:21 pm »
started on the flip front as I want it to come up and over I mocked it up and looks like it may work but we will see lol
couldn't do much more as the polyurethane was still curing
cheers andy
Andy Sykes
« Reply #612 on: September 07, 2013, 14:53:30 pm »
bit more done today
I couldn't get the flip front to up and over there is just too much in the way so im just going to have to remove the air dam to flip the front
started on fitting the window tabs and found this little hole lol
at least the rest of the windows were ok
cheers andy
Andy Sykes
« Reply #613 on: September 09, 2013, 19:06:02 pm »
bit more
and just because lol
cheers andy
Andy Sykes
« Reply #614 on: September 11, 2013, 16:27:49 pm »
bit of transmission porn arrived today  Grin
weddle side plates
very small CroMo spool
a bit
weddle pinion 3.88
hopefully bomb proof case
mediola nose cone with the starter in the orginal place
weddle nose
inside the deco case
cheers andy
« Reply #615 on: September 11, 2013, 16:45:51 pm »
Please educate me Andy because I got lost somewhere around where around your trailer build. You had a Porsche G50, then a Porsche 930 and now a Mendeola?
And no, I`m not a hater!
Andy Sykes
« Reply #616 on: September 11, 2013, 18:04:49 pm »
Hi
It started as a G50 when it was going to be a road car, the 930 turned out be be a no go ratios all wrong so this is the final design lol
Deco case basically a stronger mendeola that is off to Germany soon to be built fully sequential
Cheers Andy
Andy Sykes
« Reply #617 on: September 13, 2013, 16:50:09 pm »
today was d day was the trans case going to fit YES Smiley
just not sure what extra mounts to use ?
started on infilling the doors milled a slot for the release handle
Andy Sykes
« Reply #618 on: September 14, 2013, 17:03:19 pm »
a bit more flip front designing im pretty happy with how the mount works and weighs nothing
started on the front transmission mount
not sure if I need one here as its on a motor plate any suggestions?
I didn't realise how close the fit was
cheers andy
Andy Sykes
« Reply #619 on: September 17, 2013, 16:11:21 pm »
Bit more done induction engine side is 80% there
rubbish picture lol
Cheers andy
« Reply #620 on: September 17, 2013, 17:31:57 pm »
On the intake section between the heads I think you will need something that will allow for the engine expansion, some wiggins clamps or hose similar to what Jyrki did on his build, if it is one piece it will try to pull the manifolds of or similar, welding looks nice though Cool
Andy Sykes
« Reply #621 on: September 18, 2013, 16:17:10 pm »
i have got some wiggins fitting but I changed my mind last minute as the don't have expansion on Scooby engine manifold but im comparing apples to pears , I guess I could add them if it starts to crack
a little bit more done
more window tabs
actually fitted the front air dam I think it will need to come up a bit
bit more welding up on the manifold
injector bosses in
these guys are pretty good at welding lol
cheers andy
Andy Sykes
« Reply #622 on: September 19, 2013, 19:38:33 pm »
All finished and placed back in to check I've got to remodel my alternator bracket oops
Cheers Andy
Andy Sykes
« Reply #623 on: September 22, 2013, 17:17:58 pm »
after I changed hubs to Cayman I gained a few inches in height so I did a bit of tweaking today
I think im getting close to paint Smiley
cheers Andy
Andy Sykes
« Reply #624 on: September 23, 2013, 18:33:11 pm »
not much of an update but finished on door dam thing took ages lol
and welded in the roof fins from behind
I will start the other door tmw and then on with all the little bits of welding I need to finish so the car can at last go to paint
cheers andy
Andy Sykes
« Reply #625 on: September 25, 2013, 20:01:20 pm »
Welding underneath is complete Smiley
Bit by bit lol
Cheers Andy
Andy Sykes
« Reply #626 on: October 01, 2013, 21:39:07 pm »
I've been trying to think of how finish the inside were I'm fitting the flip front did this today but I'm not sure about it
My dogs decided to remodel the office chair as we'll today  Roll Eyes
I think I need to start a to do list now to get this car to paint
Cheers Andy
Andy Sykes
« Reply #627 on: October 03, 2013, 21:21:53 pm »
Started on the drivers side now as I seam to be getting through all the little jobs I've been putting off
Where I had made the rear removable it's now 100% not coming off
Cheers Andy
Andy Sykes
« Reply #628 on: October 04, 2013, 16:34:44 pm »
tiny bit more done but took hours it seamed lol
I think I have the passenger door to do and few other things left then to paint
cheers andy
johandryselius
« Reply #629 on: October 04, 2013, 16:53:25 pm »
Very nice!!!
Smiley
Johan
1600cc Challenge Porsche 356:
9,4386@242,48km/h; 6,1229@193,15 km/h 1,50 60 foot @ Kjula Dragway 2022
1600cc Challenge Buggy:
9,5112@225,42 km/h; 6,0624@185,85 km/h 1,38 60 foot @ Kjula Dragway 2020
Europes quickest ProStock VW:
9,8538@218,80 km/h; 6,2569@176,24 km/h 1,35 60 foot @ BRC Tierp Arena 2014
