November 02, 2026, 22:57:52 pm
| | |-+  How to make my cal Look engine 'period correct'
Pages: 1 [2] 3 Print
Author Topic: How to make my cal Look engine 'period correct'  (Read 53895 times)
glenn
« Reply #30 on: July 24, 2014, 20:44:59 pm »
engine looks more period correct , change the alternator to a dynamo , the breather , and for me , would go for non shiny paint for the tins i prefer the "original" color , as an original engine ,  for me john plow(cornpanzers) had a nice period correct enfine  may be richard roth have some photos  Wink
A better picture of JP's 2110.
Glenn
www.DasVolks.com
Long Island's Aircooled Club
smurf67
« Reply #31 on: July 24, 2014, 21:36:08 pm »
Now there is a great looking engine, is the fanshroud painted in a textured paint or is it just semi gloss?? Also what are people's thoughts on painted cases was this done in the day? Or were they left factory mag?? Cheers Alex
glenn
« Reply #32 on: July 24, 2014, 21:57:10 pm »
Paint is a crinkly finish.
My only issue are the blue Allen bolts holding the generator stand. That's a Art Thraen trick. I replaced the blue with stainless bolts.
It allows the generator/alternator to be removed without pulling the shroud.
Glenn
www.DasVolks.com
« Reply #33 on: July 24, 2014, 22:09:37 pm »
Plow's motor and Glenn's... Know what makes these stand out and look "right"? They look as if Volkswagen had intended the engine to run Webers, etc. Nothing that DOESN'T have to be done away with has been. Factory shroud (that works better than the aftermarket ones do) stayed. No flash, all businsess.
The problem with this hobby is the un-dying concern for what something looks like and not so much with the end result as far as function. These engines look "right" becasue they are. Look at Sarge's motor from 1972-ish. I don't think DKP of the era were entirely wrapped up about adhering to some model their engines had to look like. The Top 10 List was all about winning drag races.
the old motor in Wade's black '67 wheelstander... same thing. Nothing flash, just the stuff that made the car haul ass.
glenn
« Reply #34 on: July 24, 2014, 22:17:49 pm »
The funny thing about the factory... they were pretty smart. I'm using every piece of factory tin including the Hoover Bit and Type 126 (industrial) shields to close off the hole by removing the heater boxes.
2180, stock offset oil cooler, 1.5qt sump and remote filter... it runs as cool as stock.
Glenn
www.DasVolks.com
« Reply #35 on: July 26, 2014, 11:43:18 am »
A few "Pre-Cal" ideas......
« Reply #36 on: July 26, 2014, 17:24:03 pm »
356/912 engines used this trick. The rear fasteners (closest to pulley) are bolts, the front uses studs/nuts with slots in the stand. Just remove the hardware and the stand slides out allowing easy removal of the generator assembly. I adapted this trick to AssHull's 1915 (one of countless Porsche influences I gave the car), but the extra bulk of the alternator makes it difficult. Needs a generator to work properly.
The Cal Look is based on performance, but it is a look. It is a careful balance between function and form, and is slightly different for everyone. I prefer the function of a factory doghouse shroud, but I really like the "less is more" form of a 36hp shroud (which is why I built one out of two German shrouds for AssHull's car). It also makes working in the engine bay easier.
« Last Edit: July 26, 2014, 18:13:18 pm by Zach Gomulka » Logged
Brian Rogers
« Reply #37 on: July 26, 2014, 20:26:45 pm »
Zach, do you have pics of that 36hp shroud you could post up? I've a Scat that dosen't fit well and I don't want to mod to fit. Like the genny stand trick and have the incerts to do it. May use the Scat just to get it on the road.
« Reply #38 on: July 26, 2014, 21:35:11 pm »
I have no idea where the fab pictures are. Looks like a bog standard early 40hp shroud. It was a TON of work. I also added a type 4 cooler and FI venturi ring. Not sure if I would bother doing it again.
http://cal-look.no/lounge/index.php?action=dlattach;topic=5626.0;attach=43162
« Reply #39 on: July 27, 2014, 07:57:53 am »
Couple of pics for ideas, both from Dave Rhoads Smiley
RhoadsVW
« Reply #40 on: July 27, 2014, 08:37:23 am »
picture is from about 1976 after painting green.  Early Berg linkage with the down strap, Deano pulley and 010 dist. on both motors
This is from I believe 1970 before the car was painted green.   It's my 69 X 88 with IDA's.  All cylinders covers and shroud is Deano purple
Thanks Richie
Der Renwagen Fuhrers
« Reply #41 on: July 27, 2014, 11:40:18 am »
zach ,here's AssHull tread
 Wink
« Last Edit: July 27, 2014, 11:50:20 am by speedwell » Logged
Mabbo
« Reply #42 on: July 27, 2014, 22:36:37 pm »
Thanks for all the replies everyone  Grin
For now I'm going to replace the CSP breather box and replace the fanshroud with the 181 style shroud I'm making. I'm also on the look out for a good condition OG top pulley.
Over the winter I will remove the engine and change a few more things - I'd like a DDS power pulley, remove the paint from the case, maybe replace the alternator with dynamo.
Thanks again, some great pictures and info - really appreciate it  Cool
« Reply #43 on: July 27, 2014, 22:42:21 pm »
Thanks Fabs. It's hard to copy the pictures from my phone Wink
RichardinNZ
« Reply #44 on: July 28, 2014, 00:27:53 am »
When did alternators become popular?  I remember buying Colin Burnham's book and looking again and again at that photo of Dumper's engine, which to me is still one of the simplest and best looking Cal Look engines out there.  The book must have been published in the mid 1980s?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
Brian Rogers
« Reply #45 on: July 28, 2014, 04:47:45 am »
Read the whole A$$hull thread. The shroud build wasn't in there. But nice build anyway. For period builds I'd be looking in the Fisher book or one of Mr. Seume's books. Zach if you run across those pics please lost 'em up.
« Reply #46 on: July 28, 2014, 06:53:33 am »
Richard
By the early 80s some of us were making the switch to alternators.
My '67 will be sympathetic to the era I originally built it ('78-83) and I'm planning on running an alternator.
« Reply #47 on: July 28, 2014, 06:59:59 am »
I'm not the best with taking pictures while I work Wink I do remember that I used the lower 2 backing plate holes (to correctly align the backing plate) along with the back and guts from the doghouse shroud. Most of the face and surround were from the early shroud. I had never built one before, I just reverse engineered it and tried to make it as factory appearing as possible. Not difficult, just time consuming.
« Reply #48 on: July 28, 2014, 16:04:12 pm »
you're welcome zach  Wink
here's another cal look engine Scott Baken /Aronson replica when the car was a streetable car before she became racer
Brian Rogers
« Reply #49 on: July 28, 2014, 16:30:16 pm »
Wow. The firewall looks like Rhino lineing. I thought they used trunk paint in there?
« Reply #50 on: July 28, 2014, 21:17:36 pm »
 Wink
Nice engine. Looks like it's easy to service and functional. Nice finish on shroud too.  Cool
« Reply #51 on: July 29, 2014, 00:04:16 am »
Thanks, Jim. I had it painted to match the wheels, and I was going for a 356SC sorta look there. Only thing I would have changed on that engine is the alternator in favor of a generator, but AssHull had it in stock and it worked.
christophe
« Reply #52 on: August 07, 2014, 23:46:46 pm »
Hello Zach!
How did you fit the 356/912 oil filler?
Thanks.
« Reply #53 on: August 08, 2014, 01:16:06 am »
Hello Zach!
Thanks.
Fabricated an aluminium adapter.
Mabbo
« Reply #54 on: September 08, 2014, 18:44:42 pm »
Its getting there Smiley
How it looks now:
I will re detail it all over the winter to be less black, more factory.
alex d
« Reply #55 on: January 16, 2018, 16:18:15 pm »
Looks like John P is selling his engine!  Shocked Shocked Shocked Shocked
https://www.thesamba.com/vw/classifieds/detail.php?id=2131570
Martin S.
« Reply #56 on: January 16, 2018, 21:04:08 pm »
That's a good deal! When I had my engine built, after all the pain and suffering was over I asked what he would charge if someone at a show saw it and wanted exactly the same thing built again. He said, "I wouldn't do it". So I persisted, and said, "Aw c'mon, if some guy pulled up in a Jag wearing his penny loafers and insisted you build another engine, just like my 2332". He then said, "$60,000".
I let out a guffaw, and then he walked away, not laughing.  Shocked
bilboa2
« Reply #57 on: January 19, 2018, 01:41:15 am »
Here is a couple of pics from when I first bought the car. [ Attachment: You are not allowed to view attachments ]
Frenchy Dehoux
« Reply #58 on: January 19, 2018, 05:07:05 am »
   Here a picture of the engine bay of my 1954 Looker.
  Frenchy
Doctor Detail ( Retired )
bilboa2
« Reply #59 on: January 19, 2018, 06:14:35 am »
Nailed it..
