August 11, 2026, 23:44:58 pm
Pages: 1 ... 22 23 [24] 25 26 ... 34 Print
Author Topic: The weight saving thread  (Read 1731203 times)
« Reply #690 on: April 01, 2014, 11:51:58 am »
You are right Jon.
I compensated with lighter pistons  Grin
delroyb
« Reply #691 on: April 01, 2014, 15:54:06 pm »
Old stocker (a few grams of crap as you can see)......
New and shiny.......
Old retainers/collets.......
New and shiny......
Where did you get those Beehive springs and what size are they if you don't mind me asking. Trying to figure out a setup for mine without going to a longer valve.
Old total weight.......
Mmmmm, shiny!  Grin
delroyb
« Reply #692 on: April 01, 2014, 15:56:54 pm »
If you don't mind me asking, where did you get those Beehive springs and what size/pressure are they? Trying to work out a package for mine but trying to avoid going to a longer valve. Ta.
« Reply #693 on: April 01, 2014, 20:53:30 pm »
Hey Gday!
The complete valvetrain setup is off a Mitsubishi Evo8/9.  Cheesy  It probably isn't what you're after, I'm looking in a different direction, these valves are only 35mm inlet and 31.5mm exhaust.
However, member here (and elsewhere) "VINCE", used some common beehive parts for his valvetrain setup, Comp springs and CB longer SS valves. Worth a look, best write-up I've seen, just brilliant. Originally I was going to use standard length 8mm VW SI valves, and Comp beehive springs #26113 (lighter than what Vince used), one of those parts might be what you want perhaps?
http://www.summitracing.com/int/parts/cca-26113-1/overview/
http://www.summitracing.com/int/parts/cca-1787-16/overview/
http://www.summitracing.com/int/parts/cca-623-16/overview/
« Last Edit: April 01, 2014, 21:01:30 pm by modnrod » Logged
delroyb
« Reply #694 on: April 02, 2014, 10:15:37 am »
I thought they looked small! Cheers for the info anyways
Ian Brown
« Reply #695 on: April 20, 2014, 14:05:33 pm »
The minimum weight 'including driver' for my class (Historic Touring Car 1300cc class) is 720kg (1584lb) which the Mini Coopers manage with ease but i've just corner weighted my 1970 Beetle and i'm 74.5kg (164lb) overweight!!...Without driver my car is 695.5kg (1533.5lb) I'm not fat....just BIG Roll Eyes
I already have no interior, cut down doors and lexan windows all round. The rules say the body must remain untouched but I can use fibreglass doors, bonnet and engine lid...even so the 30 odd pounds i'll save with those doesn't make much of a dent in the 164 pounds needed......I'm gonna be on here a lot!!
15.08@87.5mph (140.8kph)
1285cc/44 webers 126bhp@7800rpm
778kg (1715lb) including driver
Ian Brown
« Reply #696 on: April 27, 2014, 18:22:34 pm »
There are a lot of aircraft manufacturers using Type 1 and Type 4 motors that produce some useful bits...How about knocking 10 pounds off the weight of your engine with a set of aluminium 92 or 94mm barrels (http://www.hummelengines.com/gallery.htm)
Ready....$1300 a set!
« Reply #697 on: May 02, 2014, 02:05:06 am »
Here's a simple part to form out of Al rod:
The part surrounding it will be a bit more complicated.
Iryanu
« Reply #698 on: May 02, 2014, 09:20:18 am »
What is that?  Huh
Edit that, just saw the file name.
Very good!  Grin
Ian Brown
« Reply #699 on: May 07, 2014, 21:33:30 pm »
Looked at getting a Lexan windscreen for my flat screen 1970 bug as it saves around 9lbs.
Basic screen for drag and sprint cars £450!....Or the deluxe option (as used by the BTCC Touring Cars) which is scratch resistant on the outside (so you can use your wipers) and fog free on the inside (so you can see where you are going) so the best option for my circuit racer £990!!!
Hmmm....on reflection I think i'll skip breakfast instead Roll Eyes
« Reply #700 on: May 07, 2014, 21:37:56 pm »
Paul Woodhead at direct plastics can help you out with the correct material at a much better cost and then just cut it yourself, 9lbs is 9lbs after all Wink
Ian Brown
« Reply #701 on: May 08, 2014, 01:47:23 am »
Ivan McCutchen also mentioned Paul today....I just need to look at the MSA regulations to check the requirements, just in case the scrutes throw a wobbly.
Thanks Richie
« Reply #702 on: June 12, 2014, 04:03:42 am »
Pulled apart a mid '75 gearbox recently and found this alteration to third gear that VW made.
« Reply #703 on: June 13, 2014, 03:42:34 am »
Back on page 18 of this topic I posted this pic of a stamped sheet Al valve cover.
At a recent swap meet I scored a pair of them.  Used and beat up, they conform to our lightweight standards.  A pair of them are almost 400g lighter than stock steel ones!
Pas
« Reply #704 on: June 20, 2014, 10:05:23 am »
Found this pic on another forum.  This guy is attempting to recreate Muffler Mike's experiment of watching how much oil stays in the left head at rpms.  I noticed the valve cover he sacrificed is stamped from sheet Al.  Can you imagine what that weighs?
Hey Bruce I think I have an answer for you!
I found a pair of these at a local VW swap meet Yesterday. They are a little beaten up but will straighten up OK.
For comparison here is a picture of one I have fitted with an Al -8 breather fitting against a stock cover fitted with a steel fitting.
Total saving 452g  Smiley
Nice score Bruce.
Not sure if you saw this from page 22 of this thread.
« Last Edit: June 20, 2014, 10:08:22 am by Pas » Logged
« Reply #705 on: August 01, 2014, 00:06:22 am »
-31%
« Reply #706 on: August 01, 2014, 00:55:51 am »
-31%
With all of these holes the trans is going to take an extra liter of oil Cheesy
Good work.
LGK
« Reply #707 on: August 01, 2014, 13:53:15 pm »
crankgear zach Roll Eyes
« Reply #708 on: August 01, 2014, 14:30:25 pm »
Oops, you're right! I guess I got used to Bruce posting light gearbox parts Roll Eyes
What is the weight compared to a straight cut gear?
« Reply #709 on: August 02, 2014, 00:56:50 am »
Someone will have to post the weight of a straight cut gear.
Phil West
« Reply #710 on: August 02, 2014, 19:42:16 pm »
Just weighed mine 278gm cheers
« Reply #711 on: August 03, 2014, 01:39:13 am »
With all the holes you drilled in it?
The one pictured above is 184g
« Reply #712 on: August 03, 2014, 05:41:22 am »
I just noticed it only has one oil groove. I've seen many with two, gotta be a few grams left there Wink
Phil West
« Reply #713 on: August 03, 2014, 11:34:50 am »
Mine's unmodified - looks like that's nearly a 100gm saving on the drilled one then
Andy Sykes
« Reply #714 on: August 03, 2014, 12:40:19 pm »
Handbrake
It's slightly heavier now it's welded
Ti bolt v steel
Cheers Andy
« Reply #715 on: August 04, 2014, 01:57:24 am »
The pic Mark V posted is what got me go cut up this gear, and initially I wanted to do two grooves like he did.  But when I did the groove, I forgot to do two.  Too late now.
Can you post more pics of your handbrake handle, Andy?
« Reply #716 on: August 14, 2014, 23:50:09 pm »
What does the gear on the cam weigh?
I was just thinking about the lightened gear I posted about.  If anyone has access to a good engineering shop, how about getting one cut from Ti?  It would weigh just over 100g.
Put that together with a Mg cam gear like the one Mark V posted, you'd have a total cam drive of less than 300g!
brian e
« Reply #717 on: August 15, 2014, 17:57:22 pm »
Send me the Ti material, and the sample gear you want duplicated, and I will cut one out for you with a wire EDM machine.  I have 3 machines here I run all day.
What if you cut the gear thickness in half and then made a small light spacer?  Do the same to the cam gear?  Cut the crank gear out of 3/8" plate, and turn the front and back faces of the cam gear to match the width?  Way lighter, and probably way cheaper material!!  Huge spring pressures might be an issue for the durability I suppose.  Only one way to find out!!
Brian
« Reply #718 on: August 30, 2014, 00:34:21 am »
Can your machine cut a helical gear?
If you can only do a straight cut gear, a Ti gear set can't compete with a stock Mg cam gear.
brian e
« Reply #719 on: September 03, 2014, 00:49:48 am »
Yes, the machines are capable of a helical cut, but I'll be damned if I can make them do it.  I tried a couple years ago messing around and couldn't get the code to jive.  We don't have much use for the taper cut in everyday work so I never pursued it.
So yes, straight cut is all I can do at this time.
