November 02, 2026, 12:02:37 pm
My kitchen built 2276 dynoed at 165 PS. Engine tuning experts needed.
10
11
12
Topic: My kitchen built 2276 dynoed at 165 PS. Engine tuning experts needed. (Read 329791 times)
181
Re: Weapon of choice (with cal-look spirit too)
Reply #300 on:
May 14, 2012, 21:45:30 pm »
let´s go back to my kitchen built 2276 for now.
I plan to upgrade my current engine to gain some extra performance out of it..
my combo is:
2276, 82x94, forged crank with H-beams and VW journals, lightened flywheel, berg heavy pulley, Steve Tims 42x37 stage 2 heads with CB big beef manifolds, 48 DRLAS with 40 vents, FK 8 cam, 1.4:1 CB rockers, AC.NET HD ALU pushrods, CB lightweight lifters.. Ignited by 010 with Pertronix and blue coil. 9.5:1 comp. Exhaust is 1 5/8 sidewinder.
I´m very happy with this engine so far, cooling is very well with Type 1 doghouse system and extra alu oil cooler. Engine is really smooth, able of daily use and I have a limiter set at 6500 for a piece of mind.
Now I consider to keep my crank assembly, switch the cam for Web 86C with Udo´s lifters, bump compression close to 11.1, switch heads for Steve Tims Stage 2 Plus welded heads (44x37) and use 42 vents in my DRLAs along with some rejetting. 1 3/4 CSP Python header will go in place of 1 5/8 Sidewinder. Otherwise I´ll keep all other components from my current combo and ditch the limiter for sure :-)
Is it worth it, what will I gain with these changes? I want to keep my engine naturally aspirated..
Feel free to contribute with your opinions and/or recommandations of what would you do with this engine.
Jan
Reply #301 on:
May 16, 2012, 13:30:37 pm »
anybody?:-)
Reply #302 on:
May 16, 2012, 13:52:37 pm »
Definitely worth it. It's a good combo now, but you're taking it to the next level for sure. Should make 200+.
rick m
Reply #303 on:
May 16, 2012, 23:28:56 pm »
What is the diameter of your aluminum push rods (and the wall thickness)? Are you running dual springs? If so, what is the pressure on the seat and also on the nose of the cam at full lift?
Rick Mortensen
Rick Mortensen
Driving Hot VWs since 1970
181
Reply #304 on:
May 17, 2012, 07:42:13 am »
pushrods are 3/8" 2024 T-3 heat treated .095 wall thicness. I´ll have t check for pressure numbers, engine is in the stage of planning..
Reply #305 on:
July 11, 2012, 21:28:34 pm »
New Borla stacks fitted to my 48DRLAs- some tweaking on the mounting holes needed, some porting of the carb cover needed to achieve smooth transition between stacks and carb.
Reply #306 on:
July 31, 2012, 21:30:31 pm »
Steve Tims Stage2+with 44x37 valves
Reply #307 on:
August 22, 2012, 15:25:39 pm »
My Thing as a cool delivery wagen on my friend´s wedding day.
2276, 11:1, 86C cam in the back and cool bride on passenger seat can you ask for more?:-)
Reply #308 on:
August 22, 2012, 18:45:55 pm »
Did you ran away with the bride?
Would have been hard to catch you!
181
Reply #309 on:
October 15, 2012, 11:09:31 am »
Reply #310 on:
January 29, 2013, 20:49:39 pm »
I want to ask experienced, does this wear pattern on my lifters look normal?
I had CB lifters with my FK8 cam and dual springs for approximately 5000 miles. I switched the cam for 86c with a new set of lifters but I really don´t know if it is OK to offer these for sale with the cam. That´s why I ask.
Thank you.
Last Edit: January 29, 2013, 20:52:43 pm by 181
Reply #311 on:
April 03, 2013, 20:37:05 pm »
woke her up from winter sleep yesterday...
http://www.youtube.com/v/DyACsLYzN6M
Reply #312 on:
April 08, 2013, 19:53:05 pm »
synced today and firs short drive in 2013 season
http://www.youtube.com/v/dSOtXRSZJpE
Last Edit: April 08, 2013, 22:08:56 pm by 181
Re: My kitchen built 2276 dynoed at 165 PS. Engine tuning experts needed.
Reply #313 on:
May 14, 2013, 20:10:05 pm »
Hi guys,
we put my car on chassis dyno today and this is the result with belt, muffler and everything:
max power is 164.5PS at 6200rpm
max torque is 234Nm at 4000rpm
at 6200rpm my rev limiter kicked in
quick specs:
82x94 2276cc
Steve Tims Stage 2 Plus welded heads 44x37 valves
CB 1.4 rockers with Web 86C
1 3/4 Python exhaust
CR set at 11:1 with 1.2mm deck
48 DRLAs with 40 vents/200 airs/170 mains/65 idles/3.0 needle valves and Borla stacks without air cleaners
Ignition provided by 010 Bosch with pertronix module, blue coil and NGK D6EA plugs, bosch wires. Currently set with stroboscope at 28°BTDC
What does it tell you? Seems OK or some major troubles? Thanks!
Last Edit: May 14, 2013, 20:18:12 pm by 181
Reply #314 on:
May 14, 2013, 20:31:07 pm »
Rev it higher
Reply #315 on:
May 14, 2013, 22:49:52 pm »
At the crank or wheels?
I have the same heads but 42mm inlet valves and cam. Here is my dyno
http://keversite.nl/motoren/motor.php?id=68
fish
Reply #316 on:
May 15, 2013, 04:25:07 am »
If that's at the wheels it's actually very good for 6200rpm and an indication of a healthy engine, with that head, cam, c/r combo you can expect peak HP around 7200-7500. What lifters did I you end up using on the 86c and most importantly how does the car drive.......seat of the pants compared to the old combo, I bet it comes on hard after 4500.
Good work anyway mate, enjoy your thing.........
Speed-demon
Reply #317 on:
May 15, 2013, 07:34:32 am »
Good numbers. If you want more: try bigger venturies, play with ignition timing, make sure the jetting is spot on. Might be that one day of dyno time can give you 10-20 more. And move the rpm limiter to 7500!!!
DWL_Puavo
Reply #318 on:
May 15, 2013, 08:29:13 am »
I agree with a bit more advance, I ran and raced with quite an similar engine with 86c and MSD, max advance was 32deg without problems. CR was 10.4:1. Also similar hp/torque curve with the cam kicking in 3500rpm.
I also agree with more rpm's, my engine was revved up to 6500 but with smaller carbs (45 dells with 37 venturis) without the hp curve yet going down. Also if you've got enough dyno time, try if a stinger (...on a python exhaust?) or a different muffler would straighen that drop on 5000-5500. Maybe some kind of resonance / acoustic thing going on.
Reply #319 on:
May 15, 2013, 13:07:35 pm »
Thanks guys. I ended up using a new set of CB lightweight lifters with loctited internal snap rings along with 86C. The car lost its bottom a bit and the power moved up so it´s less pleasant to drive in stop and go traffic but it hauls ass when needed.
My concern is the shape of the curves. Is this normal to have such falls between 3400-5000? If I understand correctly, 86C wake up at 3200. According to my LM2 I´m a bit lean at the top, so can this be the reason for the situation after 5000rpm?
Be patient with me this was my first dyno time ever.
Thanks again .-)
Reply #320 on:
May 16, 2013, 06:26:55 am »
Quote from: 181 on May 15, 2013, 13:07:35 pm
I have to say that your curve is interesting. The dip you see in the transition area is often seen on NA engines but your engine picks up only to dip again 3 times. Between: 3600 - 3800 and again at 4000 - 4200 rpms but you also have a big dip at where it should peak: 5100 - 5600 rpms. Have you checked your igniton and made sure your engine get enough fuel?
-BB-
181
Reply #321 on:
May 16, 2013, 09:29:15 am »
Good ideas!
I run a CB rotary pump, through stock fuel line, no regulator, stock DRLA banjos with stock internal screens, and 3.0 needle valves. Specs of the pump are 3 1/2 lbs. of uninterrupted fuel pressure at up to 30 gallons per hour. I suppose I´ll remove the screens and drill the banjos to make sure they flow.
I´m looking at this regulator with gauge:
http://www.dellorto.co.uk/merchandise/products_details.asp?PartNo=FK85/G&CategoryID=8&PartsectionID=18
, it would be useful to see if there are any pressure drops during the dyno run.
For ignition I have a 010 with pertronix and simple rev-limiting rotor. For next dyno run I can switch to other, bone stock and low mileage 010 distributor.
Can these drops be caused by some cross firing or interference on spark plug wires or valve float? I have CB 650 springs kit, thinwall mantons and CB lightweight lifters.
Jan
Reply #322 on:
May 16, 2013, 09:43:45 am »
Your AF will tell you if your engine have enough fuel. If enough fuel, then I would focus on the ignition. Sort the dip at peak and increase the RPMS a bit. I do not think your engine should should dyno a lot more because 165 HP at the wheels is a good result, 180 - 190 HP at the flywheel.
-BB-
benlawrence
Reply #323 on:
May 16, 2013, 20:13:51 pm »
Is the reading from the flywheel or at the wheels, i have a very similar spec combo, 82x94, 44x37 wedgeports,ida's 86c jpm springs 10.2-1 comp. I dyno'd it belt on through the muffler 37mm vents with unported manifolds (just matched on the ends) it made 160 flywheel at just 5500 on dynamics roller.
I have since welded and ported the manifolds right up and installed 42mm vents, downlow and midrange has obviously suffered but the top end 4k onwards has come alive bigtime, im yet to get back to the rollers. my graph on f7's 160 main 200 airs had the usual ida dip around 3-3.5kk (rich afr's) but at the top end was good. Yours is making 170+ ft torque, thats stout.
Last Edit: May 16, 2013, 20:16:40 pm by benlawrence
Reply #324 on:
May 16, 2013, 22:07:43 pm »
these numbers should be flywheel HP. The car was on the rollers but they recalculate it back to flywheel HP using some coeficients I think..
I ordered fuel pressure gauge and I´ll play with my LM2 wideband to find out more about posiible reasons.
Last Edit: May 16, 2013, 22:13:23 pm by 181
Reply #325 on:
May 17, 2013, 13:19:41 pm »
1-- Set the timing for 32*
2-- Fuel Pressure to carbs -- get rid of every possible restriction, (screens, narrow lines, sharp bends in the line) and check the screen in the tank -- -- if you are going to get a regulator (another restriction) get a new fuel pump that is, at least, getting 25-40 psi to the regulator and then have a short fuel line run to the carbs
http://selvedgeyard.com/
Reply #326 on:
May 19, 2013, 09:53:06 am »
Hello
1. I have never had an engine with a set of those heads on the dyno. But assuming we are in the range of a Wedge port, the engine should peak somewhere in the 6300 - 6500 range. So set the limiter to minimum 6800 real life.
2. That header kills upper end performance a little bit. And is also a tad large for the combo. But it looks and fits nice.
3. The peak power should (ought to be) be about 185 hp with belt and muffler. Your peak torque is also low. ( I have built 2275´s with stage 2 heads and the 86C that pulls an easy 170 hp and 260 Nm. Awesome daily driver combo by the way)
4. Those stacks in that combo kills performance, as the intake length gets way too long. You should be about 14 - max 15" from valve to mouth.
5. What Fiat dude said, generally. You do not need quite as much to feed 200 hp. But better safe than sorry.
6. As for the zig zag power curve, that can be anything from tire slip to too large port volume to premature detonation. But I´d say that something annoys the combo. Hard to say exactly what without getting my fingers dirty.
PS. There is a good chance that there are another 5-10 hp in it when you get the rev limiter up to about 7000 rpm. If that happens youre not too far off.
Last Edit: May 19, 2013, 12:07:28 pm by Torben Alstrup
neil68
Reply #327 on:
May 19, 2013, 20:59:24 pm »
My 2332 cc, 86C, 1.4 Scat rockers, 44 x 37 044 Ultra Mag Plus K-Roc porting, 1.75" Bugpack header, IDA's with 42 mm vents, stock fuel pump & fuel lines, and IIRC around 10.6:1 CR made180 HP to the wheels with the best reading at 34 degrees advance at 6200 rpm. Good for 12.8's in 1/4-mile at 104 MPH in a 2,025 lb (with driver) stock Beetle. Used large jets of 180 main and 210 air.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
181
Reply #328 on:
February 05, 2018, 16:32:35 pm »
Holy Moley, a long time passed since I updated this thread! No actual news,. Car is sitting in a dry dark room and is awaiting its resurrection. I drove it 4 years ago for the last time :-o Decided to pull a trigger on a nice close ratio transmission, and with a lot of new performance products on the market I think an engine upgrade wil follow
Reply #329 on:
May 21, 2018, 10:24:55 am »
So yesterday I put some air into tires, some fresh gas, new battery, and she woke up after 4 years of rest:
https://www.youtube.com/watch?v=49q2SCqwCSY
Now brake check is on order, and waiting for my Berg 5!
10
11
12
