September 24, 2026, 22:51:25 pm
Recipe for a mean sounding VW ?
Topic: Recipe for a mean sounding VW ? (Read 72287 times)
benlawrence
Re: Recipe for a mean sounding VW ?
Reply #60 on:
April 12, 2013, 12:38:12 pm »
Quote from: Jim Ratto on March 05, 2009, 21:44:30 pm
Quote from: lawrence on March 05, 2009, 19:46:22 pm
To me, induction and exhaust are what make a motor sound killer. IDAs and nice, quiet maganaflow are my choice
Did any people use straight cut cam gears in the 70s and 80s. It seems like a recent trend. Just to change it up the next engine that I build will not have straight cuts. Does anyone know of a hot engine that does not use straight cuts? I bet it sounds better.
Really? To me the timing gears give the audio qualities of a hot VW it's "edge", especially at idle. BTW, Pete Statt's car had straight cuts in '86-87
I hate straight cuts, nothing beats the sound of a quite and smooth valvetrain, the resonance of s/c gears just gets in the way of what most times could be a beautiful sounding motor.
Jesse/DVK
'64 2176cc
Reply #61 on:
April 12, 2013, 12:40:56 pm »
What do you guys think?
http://www.youtube.com/v/2yUrsgSlX4o
Reply #62 on:
April 12, 2013, 12:57:01 pm »
Quote from: benlawrence on April 12, 2013, 12:38:12 pm
X2
Chris bugster
Reply #63 on:
April 12, 2013, 18:49:05 pm »
http://www.youtube.com/v/O2wGWxVQorw
My car with the previous smaller engine
11.2@124mph
hotrodsurplus
Reply #64 on:
April 13, 2013, 08:30:58 am »
Quote from: BeetleBug on April 12, 2013, 12:57:01 pm
X2
I don't exactly hate straight cuts but I always thought they were gimmicks, a means to make an engine sound nastier than it is, a means to impress people who really don't understand what real power sounds like. That's not to say that there aren't any really powerful engines that run straights (there are) or that there's no need for them (there is) but 99 percent of engines that run straights don't benefit from them for any other reason than the noise they make.
Someone pondered earlier what makes some louder than others. In most cases it's usually material. Gear sets with an aluminum gear like that Magnum a few posts back can be downright quiet. All-steel gear sets are usually obnoxious.
You want a good sounding flat four? Try one of the Autocraft or Scat engines built for USAC midgets in the '70s. Two liters, 320 degrees duration, close lobe centers, 16:1 CR, methanol, Hilborn injection, magnetos, and a coupler instead of a flywheel. They idle at 2,000rpm and tach to 8,000 before you get the pedal halfway down.
holmsen
Reply #65 on:
April 13, 2013, 12:13:11 pm »
The sound of an anchor
http://www.youtube.com/v/NmUGAr-8iBY
Worm
Whose stupid idea was that?
Reply #66 on:
April 13, 2013, 16:09:16 pm »
Now, WHICH straight cuts? The Scat ones? Do tell....
"Pretending to know everything closes the door on whats really there"
holmsen
Reply #67 on:
April 13, 2013, 16:47:19 pm »
The CB performance ones
Reply #68 on:
April 13, 2013, 20:03:53 pm »
Cb performance straight cuts can be heard in my earlier post. I used them because I wantrd to take away axial forces on cam thrudt bearing. It is noisy, but I have other car when I eant to travel in silence..
KrylonMonster
Reply #69 on:
April 13, 2013, 23:07:33 pm »
As was said before, it is definitely cylinder pressure and cam that attribute a lot to how nasty a VW motor sounds. Compile that with a good amount of compression and a tight deck height and you get some pop in a NA motor. Plenty of guys do not measure it our correctly or take stuff out of the box and put it inside a motor and call themselves an engine builder....with a .130 deck height!! That is just an assembler.
Once the final product is together, it also needs to be tuned properly. As we know, the IDA can sometimes be a finicky piece and may take some time to get right. But when you do, they are a very well working piece to many high performance motors. Another element that you need I believe. is a good ignition system. No sence in making good power if you can't light it off.
Below is my dads 2332 with superflows that made 226 horsepower to the wheels on a dyno.
http://www.youtube.com/v/SfySmUGt0h4
I am not sure if the video will show, but here my 2332, CB Strip Dominator heads, 14:1 compression being broken in on carbs before the FI
https://www.facebook.com/photo.php?v=10151504186746210
neil68
Reply #70 on:
April 14, 2013, 06:06:37 am »
Agreed: my street strip Beetle runs IDA's and A1 Magnaflow muffler which produces a nice growl, but also keeps it "street legal" for cruising around the city
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
fish
Reply #71 on:
April 14, 2013, 13:56:38 pm »
Quote from: besserwisser on March 04, 2009, 21:38:12 pm
http://www.youtube.com/v/vK-mIWHjypY
My 1915 with superlight flywheel engle 120 early cb044 dual dellorto 40
thats a snappy sounding rat......love it.
AirCooledCurtis
Reply #72 on:
April 14, 2013, 21:11:41 pm »
From what I've heard from the older folks, Solex 40 p11s make a beautiful sound when at full throttle, but those are all extinct from the vw scene today
Does anyone have video proof?
TheNick80
Reply #73 on:
April 14, 2013, 21:21:31 pm »
Still a fav, and one of the meanest sounding, on video anyway!
http://www.youtube.com/v/v4b84MICGZc
"There is a Fine line between stupid and Clever"
Peter Shattock
Reply #74 on:
April 14, 2013, 22:06:01 pm »
Can't believe this thread has got to 3 pages without someone referring to this engine.
http://www.youtube.com/watch?feature=player_embedded&v=VPVqYRrQBA0
Short stroke, light reciprocating parts and good cylinder pressure. Pump gas and through a muffler too.
Better still you can buy it as its currently for sale on here, to be honest I can't believe it didn't sell the moment it appeared. 11 second 1603cc motors do not come up every day!
Certainly does it for me.
You can hear it on the quarter here too.
http://www.youtube.com/watch?feature=player_embedded&v=v15y0b480GY
As the original thread said crank up the volume and enjoy!
Reply #75 on:
April 14, 2013, 22:35:51 pm »
Quote from: AirCooledCurtis on April 14, 2013, 21:11:41 pm
They do sound fantastic, but I'll never do another pair. Extremely expensive, complicated, heavy, and phisically much too large for a beetle's engine compartment.
Reply #76 on:
April 15, 2013, 15:03:04 pm »
An engine to me is an instrument, and how it reacts to the right foot creates the music. In other word, throttle response, I prefer when there is NO hesitation... nice but lethal.
If you aim for throttle response, you will create music... or is that too blunt?
wolfswest
Reply #77 on:
April 15, 2013, 15:41:35 pm »
Quote from: Jon on April 15, 2013, 15:03:04 pm
I can dig that!
Reply #78 on:
April 15, 2013, 17:21:14 pm »
Reply #79 on:
April 15, 2013, 18:42:20 pm »
Makes perfect sense. This is what I explained to Henry Oelkers when I was doing the tune on his engine. His car definitely has a distinct note to it.
dannyboy
Reply #80 on:
April 15, 2013, 19:00:44 pm »
<iframe src="
http://www.facebook.com/video/embed?video_id=10151059036420666
" width="720" height="480" frameborder="0"></iframe>
8.77@156.8mph
O/FF 60
dannyboy
Reply #81 on:
April 15, 2013, 19:02:45 pm »
dunno how to embed the link sry
8.77@156.8mph
O/FF 60
Red Rooster
Reply #82 on:
April 19, 2013, 17:28:46 pm »
Here is a video of my old car. it was a mega snappy engine and loved rpm.
http://m.youtube.com/watch?v=pmLMSVE3zSo#
spec was 2165cc
42x37.5 street elimimator heads
web cam 226
12.5 compression
IDA's
1 3/4 header and red lined at 8500 rpm
Made me smile every time I drove it!
Doktor
Reply #83 on:
April 22, 2013, 09:47:00 am »
Here you go:
http://www.youtube.com/v/XYum3Qohexw
2017ccm, Solex 40PII, CSP Super Competition exhaust
dr.aircooled
Bendik
Reply #84 on:
April 22, 2013, 13:23:42 pm »
Nice car!
Reply #85 on:
April 22, 2013, 13:32:41 pm »
What impact will the shape of the stacks have on the sound?
hotrodsurplus
Reply #86 on:
April 22, 2013, 17:25:08 pm »
Quote from: Jon on April 22, 2013, 13:32:41 pm
Think of the manifold, carburetor body, and velocity stack as an organ pipe. Increasing its length and/or the diameter of the assembly reduces its resonant frequency.
It explains why IDAs make
basso profundo
. The manifold passages are usually larger to accommodate the flow potential and the carburetor bodies are a lot taller than the other carburetors. The velocity stack further increases the length.
If the PII carburetors sound any different I am at a loss to explain why. They have the same basic dimensions as a 40mm IDF/DRLA with 32mm venturis. If they do in fact sound any different it may be because of the manifold design. The PII manifolds that I have do not seem to look any different than most IDF/DRLA manifolds but I have never made a direct comparison.
The engine combinations may explain why engines with PII carburetors sound different. Most engines running PII carburetors were built long ago. Older camshaft profiles usually have slower ramps which can increase seat timing. Increased seat timing can increase the overlap and/or the intake-valve closing event. Both of those influence reversion. Reversion plays a significant role in induction honk, AKA Alfa Song if you spent any time around Italian cars.
Reply #87 on:
April 22, 2013, 18:01:43 pm »
I loved the sound of my P11's. Very similar to an IDA, in my opinion. IDF's and Dellorto's have that annoying chirp...
hotrodsurplus
Reply #88 on:
April 22, 2013, 18:52:43 pm »
Quote from: Zach Gomulka on April 22, 2013, 18:01:43 pm
IDFs chirp?
DRLAs chirp because of that slot machined in the throttle-bore base. Fill that with silicone (or use the special base gaskets) and the chirp magically disappears. Never once have I heard an IDF chirp.
Reply #89 on:
April 22, 2013, 18:53:01 pm »
Quote from: hotrodsurplus on April 22, 2013, 17:25:08 pm
A lot of time. That's my problem.
