October 13, 2026, 03:53:00 am
| | |-+  Cal Look Engine Combos and HP
Pages: [1] 2 3 Print
Author Topic: Cal Look Engine Combos and HP  (Read 91729 times)
fish
« on: April 14, 2009, 00:51:01 am »
There seems to be a lot of scattered engine info around, so I thought we should have a Sticky about what engine combination and HP you guys are running?
CC and HP           1776 - 102HP                                  1679 - hoping for 120HP+
Crank                    69mm German balanced                    69mm German balanced
Rods                     stock  German balanced                     H beams stock length
P/B                       90.5 Mahle                                      88 Empi Biral
Cam                      W120 w/1.25:1                                FK45 w/1.4:1
Heads                   40x35 ported non welded                  42x37.5 ported welded pictured
C/R                       8.5:1                                              10:1
Ignition                 009/Accufire                                    MSD
Carbs                    48IDF                                             45Dells
Exhaust                 1-5/8 merged Fat boy                       1-7/8 stinger
Flywheel                200mm 12lb                                   200mm 10lb
Clutch                   Kennedy Stage  2                            4 puck                 3.88 box superdiff, HD side, welded 3+4, 1.12
« Last Edit: April 15, 2009, 06:35:25 am by fish » Logged
« Reply #1 on: April 14, 2009, 01:10:04 am »
Great idea for the thread. But I'll just sit on the sidelines and watch. Just running a single port 1600cc with dual Weber 34ICT carbs, .009, and an A-1 sidewinder exhaust/dynaflow muffler.
Hopefully, the new engine will resemble something like this:
CC and HP 1915cc/don't care how much h.p. it's never gonna be raced.
Crank 69mm forged German counter-weighted.
Rods Rimco Super Rods.
Chrome-Moly pushrods.
P/B Jelly?
Cam Don't know, yet. Probably an Engle 130
Heads .044 smoothed out and mildly opened up.
C/R Don't know... just want to run pump gas and race fuel blend.
Ignition Bosch blue coil, Bosch plug wires, and Bosch .010 distributor.
Carbs Weber 44mm IDF
Exhaust 1 5/8" A-1 sidewinder merged header, Dynoflow muffler, 1 5/8" flanged fresh air heater boxes.
Flywheel 8 doweled and slightly lightened... not too much.
Clutch Kennedy 1,700lb diaphram
Transmission will have the tallest fourth gear that I can find, welded synchros, h.d. side plates, and a Super-Diff. Nothing too fancy. Just a little more stout than stock.
« Last Edit: April 14, 2009, 05:39:32 am by DKK_Fred » Logged
fish
« Reply #2 on: April 14, 2009, 01:35:54 am »
Hey Fred, how does the 1600 SP run with the 34ICTs, was thinking of using them with these heads
« Reply #3 on: April 14, 2009, 01:55:49 am »
I was skeptical, at first. Because I've always been a firm believer in Kadrons for single throat carbs. But after much frustration from trying to find single port Kadron manifolds, I gave up. Hard to believe that we used to throw those things in the trash in the '80s. Now, people want big bucks for 'em. HAHA!! So my friend, Chris, found out that I wanted some small carbs. He sold me this brand new set for $200. I was STOKED! They were jetted for a Type 3 s.p. engine, so I left that alone. Painted the manifolds gloss gray, painted everything else flat black, had my friend, John, adjust 'em for me. (it was way too many years away from air-cooled engines, last year) I'm very happy with the 34 ICT carbs. Mileage same as stock, long as my foot's not in it. Great performance for a stock engine, too. I can easily peg the speedometer and they stay in tune nicely, as well.
I never thought I'd ever get a set of these. I highly recommend them for small or stock engines.
« Last Edit: April 14, 2009, 01:59:15 am by DKK_Fred » Logged
lawrence
« Reply #4 on: April 14, 2009, 04:47:09 am »
Cool idea for a thread.
1914, 140 flywheel hp @ 7k: counterweighted german crank, 12lb chromoly flywheel, kennedy stage 1, kushlock disc, scat i-beam rods with arp bolts, 94mm mahle pistons, Webcam 86b with webcam lifters. 044 heads 40x35.5 valves D intake ports no welding, 48 IDAs with tall manifolds, CB Performance 1.4 rockers, chromoly pushrods, 8.3:1 compression ratio, mallory ignition system, 1 5/8s sidewinder header and magnaflow. Runs hard!
« Last Edit: April 15, 2009, 19:30:44 pm by lawrence » Logged
"Happiness is a Hot VW!"
fish
« Reply #5 on: April 14, 2009, 08:16:57 am »
I bet, with 140 ponies to help....... Grin
« Reply #6 on: April 14, 2009, 17:47:53 pm »
current engines, either in my car, on the stand and in the parts cabinet
mine:
94mm x 78mm
Rimco VW rods
Pauter R6E8 cam w/ Scat 1.25 rockers (272' @ .050 x .528" @ valve), adv 4 deg
CB 044 castings intially ported by yours truly in 2003-04 as copies of Berg 871 heads 44 x 37, finished by Clyde Berg
44 x 37mm
9.7:1
Weber 48's on Scat talls, 40mm vents, 91 octane
MSD locked dist, Bosch X5DC's
1.75" header
no idea on HP but it's reliable and fast enough to be scary
on the stand:
88mm x 74mm, Crown 6lb flywheel
VW rods
2238 cam w/ Scat 1.4 (274' x .511")
VW 1600 single port, lightly contoured, chambers opened to bore diam, stock valves
8.4:1
stock Solex 30PICT
Bosch 010, blue 6V coil
4-into-1 header w/ glasspack
94mm x 84mm Bugpack 912 journal
5.600 Bugpack "1991" rods, narrowed
Clay Smith steel billet cam "320" Scat 1.4's
CB 044 ultra wedge port
11.0:1
Weber 48's, 44mm vents
Mallory mag, locked
1.75" stainless sidewinder
my heads:
« Last Edit: April 14, 2009, 17:59:28 pm by Jim Ratto » Logged
« Reply #7 on: April 14, 2009, 19:58:45 pm »
P/B Jelly?
Hey mark you might re think the PB and Jelly... I heard it makes those KEP's chatter.
Bewitched666
Bewitched
« Reply #8 on: April 14, 2009, 21:22:12 pm »
1904cc engine
74mm cw crank
5.4 h-beams
engle k8 cam
straight cuts
cb heads ported and polished 42x37mm mini wedge ports
45 dells or 48 idas (cant decide yet)
1.4 rockers
90.5 pistons
1 3/4 headers
9.5 cr
msd 6 AL and msd coil
No idea on the HP out put as i'm still building, Grin
Fast vw beetle's rule
« Reply #9 on: April 15, 2009, 01:47:19 am »
Great! I typed "jelly" because I had no idea what P/B stands for. Now, you're confusing even further. What the heck are KEPs?
 Huh
[Homer's voice]Ohh, there's SO much I don't know.[/Homer's voice]
« Reply #10 on: April 15, 2009, 02:30:44 am »
KEP= Kennedy Engineered Products (or something to that effect), aka your clutch Wink
« Reply #11 on: April 15, 2009, 03:29:54 am »
CC and HP    2165cc 78 x 94, hp I'm hoping for 175+hp or enough to scare me  Grin
Crank            Bugpack forged, nitrided 78mm VW journal, 8 doweled
Rods             CB 5.500" H beams ARP 2000 5/16 bolts
P/B               Mahle 94 "B" CB tool steel wrist pins. Teflon buttons
Cam              Engle FK-45 (263*@.050 x .566" valve lift, dialed in straight up, Berg/Magnum straight cuts, Weizmann coated lifters
Rockers        CB 1.4:1, Berg 90,000 pushrods 10.810" long
Heads           CB 044s by Heads Up Performance, 42 x 37.5, stainless valves, Bugpack 4046 dual springs set up .080" to bind, Ti retainers
C/R               94 bore x 57cc chambers x .043 deck height = 9.4:1 static or 7.00:1 dynamic
Ignition         Bosch 010 w/Pertronix, MSD 6AL box, MSD Blaster 2 coil, Taylor .409 wires, NGK D6EA plugs
Carbs           48 IDAs, 40mm vents, tall Scat Traks, Berg linkage
Exhaust        Berg 1 3/4" heater box exhaust w/ A1 polished stainless 2 1/2" Renn Kafer muffler
Flywheel       Bugpack 13lbs, 8 doweled, Bugpack 36mm gland nut
Clutch           Kennedy Stage 2, Daikin disc.
Oil System    Berg 30mm plugged pump, Berg std. cover, Berg 4 qt. sump, Napa Gold 1515 filter, Valvoline VR1 10w 30 oil
My heads (Ratto's old head)
« Last Edit: April 15, 2009, 05:46:02 am by stealth67vw » Logged
« Reply #12 on: April 15, 2009, 03:30:55 am »
 Huh
P/B = pistons and barrels.
« Reply #13 on: April 15, 2009, 04:06:22 am »
Oh WOW! Can't believe I didn't get either of those... thanks, guys. I feel a little more slightly stoopeed than usual.
 Grin
Please carry on. This will, hopefully, shape up to become a pretty cool thread.
Jason Foster
7.69 87mph 12.35 106 mph
« Reply #14 on: April 15, 2009, 05:14:14 am »
CC and HP  2386cc 174rwhp and 160ftlb through a beat up old stock '67 trans on the chassis dyno once.
                 I figure it's gotta be good for a couple ticks over 200hp at the flywheel.
Crank         Demello 86mm german welded
Rods          Demello 5.4 H beams (eagle)
P/B            Mahle 94's Mahle wrist pins teflon buttons
Cam           Engle FK10 stroker clearanced and picked up from engle on 6/6/06
Heads        CB wedgeports reworked by Clyde Berg  53cc chambers
Rockers      Scat 1.4   chromolly push rods  AJ sims lifters
C/R           11.0 to 1    (Mark it sucks having to mix fuel)
Ignition      MSD 6Al, Blaster 2 coil, Dsit. and wires     NGK D6EA plugs
Carbs         Italian 48 IDA's 42 vents CB talls match ported by Clyde. Berg linkage
Exhaust     Bugpack 1 3/4 slip joints welded J tubes flanged ceramic coated Flowmaster single chamber muffler ( aka soup can)
Flywheel    Demello 12.5 lb
Clutch       Kennedy stage 1 daiken disc
Oil pump   Berg 26mm  Berg pump cover
Sump       Berg 3 1/2 QT.
Pulleys      Saco
fish
« Reply #15 on: April 15, 2009, 06:12:44 am »
Sump       Berg 3 1/2 QT.
Pulleys      Saco
Must be Hell of a cam Grin Jason.
fish
« Reply #16 on: April 16, 2009, 09:19:32 am »
Where's the rest of ya fellas?  Grin
jamiep_jamiep
« Reply #17 on: April 16, 2009, 09:49:35 am »
CC and HP     2276 82 x 94, Dyno'd (on a chassis dyno) at 136bhp at the wheels, figuring on a 15% transmission loss (is that about right?) 156 at the flywheel.
Crank            CB 82mm forged VW journal, 8 doweled
Rods             CB 5.6" H beams
P/B               Mahle 94 "B"  Teflon buttons
Cam              Webcam 86B/Magnum straight cuts
Rockers        CB 1.4:1,
Heads           CB 044s round ports, 42 x 37.5, stainless valves
C/R               9.5:1
Ignition         Treuhaft/Mallory 010 w/Pertronix, Mallory VI AL box,
Carbs           45 dells, unkown setup
Exhaust        Speedshop 3/4" exhaust w/ Speedshop polished stainless turbo muffler
Oil System    Berg 30mm plugged pump, Berg pressure relief. cover, CB deep sump sump, Fram HP1 filter, Valvoline 15 40 Oil
Its currently being rebuilt and has 86C, IDA's and the heads have been redone by Kraftwerk VW, same valve sizes but ported, and the CR is now 10.8:1.
glennc
« Reply #18 on: April 16, 2009, 19:30:24 pm »
 berg 86mm crank
carillo 5.7 rods
fk 89
berg straight cut cam gear
berg followers
jayee barrels
wiseco pistons
comp eliminators
italian 52 ida's
pauter rockers 1.4
10.1 cr
al7 msd
berg 4 puarts deep sump
other bits are mainly berg
O/FF 88
12.66 @ 98mph at Garys picnic 31/5/10
« Reply #19 on: April 16, 2009, 23:44:18 pm »
Motor for my 58 RagTop
CC and HP  2332cc  237hp at the flywheel. @6800
Crank         Scat 84mm  Chevy Rod
Rods          CB 5.7 H beams
P/B            Wiseco 94's  with Jaycee Long Barrels and Pins
Cam           Engle FK-46 on a 110 lobe center stroker clearanced and Steel Magnum Straight Cuts
Heads        CB CNC wedgeports 44x37 reworked by Steve Tims
Rockers      EMPI 1.4   chromolly push rods  German VW lifters
C/R           11.5 to 1
Ignition      Locked Joe Hunt Magneto with Jaycee Mag Clamp
Carbs         Italian 48 IDA's 44 vents CB tall manifolds match ported by Steve Tims, Empi linkage
Exhaust     Berg 1 3/4 Merge with A1 Muffler
Flywheel    Wedgemated 12 lb
Clutch       Kennedy stage 2  4 Puck disc
Sump       Berg 4 QT.
Pulleys      Berg BRM Pulley Set
Trans       Old School Non Freeway LOL   ( 4:37 R/P H/D mainshaft,1:58 3rd, 1:32 4 th)
« Last Edit: April 20, 2009, 15:59:44 pm by Shubee2 (DSK) » Logged
« Reply #20 on: April 17, 2009, 00:46:18 am »
125k mile original 1600 dual port Smiley. They were rated at 60hp, but a fresh stocker dyno's at a true 48hp or so. I've got a Zenith 32NDIX with 25mm vents, Bosch 010 w/Pertronix, header with S&S glasspack, and 30mm oil pump. It's tuned within an inch of it's life, with as much advance and the leanest jets it will take. I figure it's making 55-60 honest horsepower Cheesy
Sam K
« Reply #21 on: April 17, 2009, 04:48:48 am »
Here are the specs for the engine in my '67
2332cc's, never had it on a Dyno. The compression was 10.5 to 1 but I grew tired of running race fuel so I just lowered it to 9.5.
Crank - Demello 84mm chevy journal crank wdgemated to a 12.5 lb flywheel
Rods - Eagle 5.5in forged h-beam rons w/ARP bolts
P&L's - 94mm cima/mahle
Cam and valvetrain  - Webcam .498 lift and 312 degrees duration, magnum straight cut gears stock rockers with solid shafts with swivel feet and chromoly pushrods
Heads - Jeff Denham ported 044s', 44x37mm valves, dual springs, titanium retainers, hardened keepers
Fuel system - 48 IDA's on CB tall manifolds, 37mm venturis, Berg linkage, Holley red pump and regulator, -8 stainless line from tank to regulator, -6 from reglator to carbs
Exhaust - Pheonix 1 3/4 merged system with 2.5 in magnaflow muffler from A-1
Ignition - German 009 with a pertronix ignitor that I bought in 1995 or so, 7800 rpm rev limiting rotor Blue coil, MSD wires, NGK spark plugs
Oiling system - Schadek 30mm oil pump, full flowed with Berg pump cover, Fram HP1 oil fliter, external cooler with thermostatically controlled fan, -8 hose and AN fittings
Clutch - KEP stage 2, stock solid center disc.
Other stuff - Berg breather box, equalizer pulley, Thing fanshroud & all german tin (except for the breastplate) is powdercoated gloss black
« Reply #22 on: April 17, 2009, 07:29:56 am »
Motor in car now...
CC          2303cc
HP          ?
Crank      Demello 83mm
Rods       Eagle 5.5-clearanced and lighten by Berg (Mark V.)
P/L         94mm Mahle's
Cam        Engle 120-clearanced by Berg
Rockers   1.25 modified by Berg
Cam Gear Magnum Straight Cut"s
Oil Pump  26mm Berg
Sump      Berg 3/12 qt.
Pully        Berg Equalizer (stock size)
Heads      Jeff Deham 42X37
Carbs       48 IDA's (Italians) W/CB early tall manifolds
Ignition    Bosch 010
Exhaust    A1 1 3/4 Low Down W/stainless muffler
Motor in process....
CC           2303cc
Crank       DPR 83mm Chevy Jounals, 411 center main, wedgemated to a 14lb. flywheel. Was going to use an 86mm but changed my mind.... (again)
Rods        Berg Jet Rods 5.5 W/Chevy Jounals
Barrels      JC's 94mm Long Barrels
Pistons     Wisco's 94mm W/JC buttons
Cam         WebCam 86c clearanced by Berg
Cam Gear  Magnum Straight Cuts
Rockers     Berg 1.45's
Oil Pump   Berg 26mm
Oil Sump   Berg 3 1/2qt.
Carbs        48 IDA's (Spanish) modified by Berg on Skat Trak manifolds
Exhaust    A1 Low Down 1 3/4 header W/stainless muffler
Ignition     MSD Distributor W/MSD 6AL Box
Heads       STILL IN PROCESS
CR            9.5:1
Can't wait to get this motor in, but looks like later in summer. It's the head thing. (WAITING)
« Last Edit: April 17, 2009, 07:37:37 am by Racecraf » Logged
fish
« Reply #23 on: April 20, 2009, 06:29:26 am »
 really thought there'd be more than this
« Reply #24 on: April 20, 2009, 12:45:49 pm »
Here's my current setup, though it's fixing to change like many of you ...
2276cc never on the dyno, low compression now but plan to raise it up just to see the differences possible...
Crank: Okrasa 82mm, porsche journals, Berg Equalizer
Rods: Carrillo 5.352
Cam: Web 86C with Berg 1.46:1 rockers (prefer my FK87)
Heads: Fumio welded and ported 42X37 with 53cc chambers
Compression: 8.7:1
Carbs: Italian 48IDAs on tall Scat Tracks with 40mm vents
Ignition: Vertex Mag, usually run 32 deg total
Exhaust: 1.75" Berg header into 2.5" magnaflo
Oil: 26mm pump with Berg cover, T4 cooler in Scat 36hp shroud
Trans: Berg 5 speed 3.88 r&p, 4.11, 2.47, 1.65, 1.21, .95
Fun on the street and still can blow down the highway at 75 mph without thinking about heat problems!
Best ever time was 12.77 on DOTs and thru the muffler.
« Last Edit: April 20, 2009, 15:42:11 pm by TexasTom » Logged
« Reply #25 on: April 20, 2009, 15:29:54 pm »
I dont think I have ever built a Cal look engine Huh so cant really help with this Shocked Cheesy  cheers richie
« Reply #26 on: April 20, 2009, 15:39:56 pm »
you're joking, how you never built a fast non-turbo type 1 engine?   Shocked Wink
how come there's only a few sub-2 litre engine posted in this thread?
are the owners a bit shy about their HP numbers? i liked to see a few more just for the sake of comparison...
« Reply #27 on: April 20, 2009, 16:16:47 pm »
Motor for my 67 Sedan
CC and HP 1914CC 168 HP @ Flywheel @ 7000
Crank         Berg 69mm counterweighted
Rods          Berg Reworked VW I beam
P/B            94's Mahle Pistons & Barrel's
Cam           Engle W-140 and Steel Magnum Straight Cuts
Heads        Steve Tims 42X37 Stage 2 with Match Ported Scat DW-2 Short IDA Manifolds
Rockers      1.1 VW,  chromolly push rods  German VW lifters
C/R           10 to 1
Ignition      Bosch 010 Dist. (Reworked advance springs and weights)
Carbs         Italian 48 IDA's 42 vents Deano linkage
Exhaust     Berg 1 5/8 Merge with A1 Muffler
Flywheel    12 lb 11/32  8 Doweled
Clutch       Kennedy stage 1 Daken Ridged Disc
Sump       Berg 1 1/2 Qt
Pulleys      NOS Santana Stock size
« Last Edit: April 20, 2009, 16:23:16 pm by Shubee2 (DSK) » Logged
« Reply #28 on: April 20, 2009, 16:46:14 pm »
Always seem to have chrome on them somewhere Wink
Anyway going on the figures Shubee has posted nothing I could do would ever come close to them Roll Eyes
cheers richie,uk
« Reply #29 on: April 20, 2009, 17:30:07 pm »
[/quote]
Shoob-
Remind me never to go on any roadtrips with you if you're driving this car/trans! Wink
Top highway speed ... 45-50?? Shocked
LOL!!! Grin
