October 13, 2026, 02:29:40 am
Cal Look Engine Combos and HP
Topic: Cal Look Engine Combos and HP (Read 91694 times)
fish
April 14, 2009, 00:51:01 am »
There seems to be a lot of scattered engine info around, so I thought we should have a Sticky about what engine combination and HP you guys are running?
CC and HP 1776 - 102HP 1679 - hoping for 120HP+
Crank 69mm German balanced 69mm German balanced
Rods stock German balanced H beams stock length
P/B 90.5 Mahle 88 Empi Biral
Cam W120 w/1.25:1 FK45 w/1.4:1
Heads 40x35 ported non welded 42x37.5 ported welded pictured
C/R 8.5:1 10:1
Ignition 009/Accufire MSD
Carbs 48IDF 45Dells
Exhaust 1-5/8 merged Fat boy 1-7/8 stinger
Flywheel 200mm 12lb 200mm 10lb
Clutch Kennedy Stage 2 4 puck 3.88 box superdiff, HD side, welded 3+4, 1.12
Last Edit: April 15, 2009, 06:35:25 am by fish
Re: Cal Look Engine Combos and HP
April 14, 2009, 01:10:04 am »
Great idea for the thread. But I'll just sit on the sidelines and watch. Just running a single port 1600cc with dual Weber 34ICT carbs, .009, and an A-1 sidewinder exhaust/dynaflow muffler.
Hopefully, the new engine will resemble something like this:
CC and HP 1915cc/don't care how much h.p. it's never gonna be raced.
Crank 69mm forged German counter-weighted.
Rods Rimco Super Rods.
Chrome-Moly pushrods.
P/B Jelly?
Cam Don't know, yet. Probably an Engle 130
Heads .044 smoothed out and mildly opened up.
C/R Don't know... just want to run pump gas and race fuel blend.
Ignition Bosch blue coil, Bosch plug wires, and Bosch .010 distributor.
Carbs Weber 44mm IDF
Exhaust 1 5/8" A-1 sidewinder merged header, Dynoflow muffler, 1 5/8" flanged fresh air heater boxes.
Flywheel 8 doweled and slightly lightened... not too much.
Clutch Kennedy 1,700lb diaphram
Transmission will have the tallest fourth gear that I can find, welded synchros, h.d. side plates, and a Super-Diff. Nothing too fancy. Just a little more stout than stock.
Last Edit: April 14, 2009, 05:39:32 am by DKK_Fred
fish
April 14, 2009, 01:35:54 am »
Hey Fred, how does the 1600 SP run with the 34ICTs, was thinking of using them with these heads
April 14, 2009, 01:55:49 am »
Quote from: fish on April 14, 2009, 01:35:54 am
I was skeptical, at first. Because I've always been a firm believer in Kadrons for single throat carbs. But after much frustration from trying to find single port Kadron manifolds, I gave up. Hard to believe that we used to throw those things in the trash in the '80s. Now, people want big bucks for 'em. HAHA!! So my friend, Chris, found out that I wanted some small carbs. He sold me this brand new set for $200. I was STOKED! They were jetted for a Type 3 s.p. engine, so I left that alone. Painted the manifolds gloss gray, painted everything else flat black, had my friend, John, adjust 'em for me. (it was way too many years away from air-cooled engines, last year) I'm very happy with the 34 ICT carbs. Mileage same as stock, long as my foot's not in it. Great performance for a stock engine, too. I can easily peg the speedometer and they stay in tune nicely, as well.
I never thought I'd ever get a set of these. I highly recommend them for small or stock engines.
Last Edit: April 14, 2009, 01:59:15 am by DKK_Fred
lawrence
April 14, 2009, 04:47:09 am »
Cool idea for a thread.
1914, 140 flywheel hp @ 7k: counterweighted german crank, 12lb chromoly flywheel, kennedy stage 1, kushlock disc, scat i-beam rods with arp bolts, 94mm mahle pistons, Webcam 86b with webcam lifters. 044 heads 40x35.5 valves D intake ports no welding, 48 IDAs with tall manifolds, CB Performance 1.4 rockers, chromoly pushrods, 8.3:1 compression ratio, mallory ignition system, 1 5/8s sidewinder header and magnaflow. Runs hard!
Last Edit: April 15, 2009, 19:30:44 pm by lawrence
"Happiness is a Hot VW!"
fish
April 14, 2009, 08:16:57 am »
I bet, with 140 ponies to help.......
April 14, 2009, 17:47:53 pm »
current engines, either in my car, on the stand and in the parts cabinet
mine:
94mm x 78mm
Rimco VW rods
Pauter R6E8 cam w/ Scat 1.25 rockers (272' @ .050 x .528" @ valve), adv 4 deg
CB 044 castings intially ported by yours truly in 2003-04 as copies of Berg 871 heads 44 x 37, finished by Clyde Berg
44 x 37mm
9.7:1
Weber 48's on Scat talls, 40mm vents, 91 octane
MSD locked dist, Bosch X5DC's
1.75" header
no idea on HP but it's reliable and fast enough to be scary
on the stand:
88mm x 74mm, Crown 6lb flywheel
VW rods
2238 cam w/ Scat 1.4 (274' x .511")
VW 1600 single port, lightly contoured, chambers opened to bore diam, stock valves
8.4:1
stock Solex 30PICT
Bosch 010, blue 6V coil
4-into-1 header w/ glasspack
94mm x 84mm Bugpack 912 journal
5.600 Bugpack "1991" rods, narrowed
Clay Smith steel billet cam "320" Scat 1.4's
CB 044 ultra wedge port
11.0:1
Weber 48's, 44mm vents
Mallory mag, locked
1.75" stainless sidewinder
my heads:
Last Edit: April 14, 2009, 17:59:28 pm by Jim Ratto
April 14, 2009, 19:58:45 pm »
Quote from: DKK_Fred on April 14, 2009, 01:10:04 am
P/B Jelly?
Hey mark you might re think the PB and Jelly... I heard it makes those KEP's chatter.
Bewitched666
Bewitched
April 14, 2009, 21:22:12 pm »
1904cc engine
74mm cw crank
5.4 h-beams
engle k8 cam
straight cuts
cb heads ported and polished 42x37mm mini wedge ports
45 dells or 48 idas (cant decide yet)
1.4 rockers
90.5 pistons
1 3/4 headers
9.5 cr
msd 6 AL and msd coil
No idea on the HP out put as i'm still building,
Fast vw beetle's rule
April 15, 2009, 01:47:19 am »
Quote from: Jim Ratto on April 14, 2009, 19:58:45 pm
Great! I typed "jelly" because I had no idea what P/B stands for. Now, you're confusing even further. What the heck are KEPs?
[Homer's voice]Ohh, there's SO much I don't know.[/Homer's voice]
April 15, 2009, 02:30:44 am »
KEP= Kennedy Engineered Products (or something to that effect), aka your clutch
April 15, 2009, 03:29:54 am »
CC and HP 2165cc 78 x 94, hp I'm hoping for 175+hp or enough to scare me
Crank Bugpack forged, nitrided 78mm VW journal, 8 doweled
Rods CB 5.500" H beams ARP 2000 5/16 bolts
P/B Mahle 94 "B" CB tool steel wrist pins. Teflon buttons
Cam Engle FK-45 (263*@.050 x .566" valve lift, dialed in straight up, Berg/Magnum straight cuts, Weizmann coated lifters
Rockers CB 1.4:1, Berg 90,000 pushrods 10.810" long
Heads CB 044s by Heads Up Performance, 42 x 37.5, stainless valves, Bugpack 4046 dual springs set up .080" to bind, Ti retainers
C/R 94 bore x 57cc chambers x .043 deck height = 9.4:1 static or 7.00:1 dynamic
Ignition Bosch 010 w/Pertronix, MSD 6AL box, MSD Blaster 2 coil, Taylor .409 wires, NGK D6EA plugs
Carbs 48 IDAs, 40mm vents, tall Scat Traks, Berg linkage
Exhaust Berg 1 3/4" heater box exhaust w/ A1 polished stainless 2 1/2" Renn Kafer muffler
Flywheel Bugpack 13lbs, 8 doweled, Bugpack 36mm gland nut
Clutch Kennedy Stage 2, Daikin disc.
Oil System Berg 30mm plugged pump, Berg std. cover, Berg 4 qt. sump, Napa Gold 1515 filter, Valvoline VR1 10w 30 oil
My heads (Ratto's old head)
Last Edit: April 15, 2009, 05:46:02 am by stealth67vw
April 15, 2009, 03:30:55 am »
Quote from: DKK_Fred on April 15, 2009, 01:47:19 am
P/B = pistons and barrels.
April 15, 2009, 04:06:22 am »
Oh WOW! Can't believe I didn't get either of those... thanks, guys. I feel a little more slightly stoopeed than usual.
Please carry on. This will, hopefully, shape up to become a pretty cool thread.
Jason Foster
7.69 87mph 12.35 106 mph
April 15, 2009, 05:14:14 am »
CC and HP 2386cc 174rwhp and 160ftlb through a beat up old stock '67 trans on the chassis dyno once.
I figure it's gotta be good for a couple ticks over 200hp at the flywheel.
Crank Demello 86mm german welded
Rods Demello 5.4 H beams (eagle)
P/B Mahle 94's Mahle wrist pins teflon buttons
Cam Engle FK10 stroker clearanced and picked up from engle on 6/6/06
Heads CB wedgeports reworked by Clyde Berg 53cc chambers
Rockers Scat 1.4 chromolly push rods AJ sims lifters
C/R 11.0 to 1 (Mark it sucks having to mix fuel)
Ignition MSD 6Al, Blaster 2 coil, Dsit. and wires NGK D6EA plugs
Carbs Italian 48 IDA's 42 vents CB talls match ported by Clyde. Berg linkage
Exhaust Bugpack 1 3/4 slip joints welded J tubes flanged ceramic coated Flowmaster single chamber muffler ( aka soup can)
Flywheel Demello 12.5 lb
Clutch Kennedy stage 1 daiken disc
Oil pump Berg 26mm Berg pump cover
Sump Berg 3 1/2 QT.
Pulleys Saco
fish
April 15, 2009, 06:12:44 am »
Quote from: Jason Foster on April 15, 2009, 05:14:14 am
Sump Berg 3 1/2 QT.
Pulleys Saco
Must be Hell of a cam
Jason.
fish
April 16, 2009, 09:19:32 am »
Where's the rest of ya fellas?
jamiep_jamiep
April 16, 2009, 09:49:35 am »
CC and HP 2276 82 x 94, Dyno'd (on a chassis dyno) at 136bhp at the wheels, figuring on a 15% transmission loss (is that about right?) 156 at the flywheel.
Crank CB 82mm forged VW journal, 8 doweled
Rods CB 5.6" H beams
P/B Mahle 94 "B" Teflon buttons
Cam Webcam 86B/Magnum straight cuts
Rockers CB 1.4:1,
Heads CB 044s round ports, 42 x 37.5, stainless valves
C/R 9.5:1
Ignition Treuhaft/Mallory 010 w/Pertronix, Mallory VI AL box,
Carbs 45 dells, unkown setup
Exhaust Speedshop 3/4" exhaust w/ Speedshop polished stainless turbo muffler
Oil System Berg 30mm plugged pump, Berg pressure relief. cover, CB deep sump sump, Fram HP1 filter, Valvoline 15 40 Oil
Its currently being rebuilt and has 86C, IDA's and the heads have been redone by Kraftwerk VW, same valve sizes but ported, and the CR is now 10.8:1.
Happiness is a Hot VW.
My 1960 Bug
SAS RENN-WAGENS
CAL LOOK DRAG DAY
glennc
April 16, 2009, 19:30:24 pm »
berg 86mm crank
carillo 5.7 rods
fk 89
berg straight cut cam gear
berg followers
jayee barrels
wiseco pistons
comp eliminators
italian 52 ida's
pauter rockers 1.4
10.1 cr
al7 msd
berg 4 puarts deep sump
other bits are mainly berg
O/FF 88
12.66 @ 98mph at Garys picnic 31/5/10
April 16, 2009, 23:44:18 pm »
Motor for my 58 RagTop
CC and HP 2332cc 237hp at the flywheel. @6800
Crank Scat 84mm Chevy Rod
Rods CB 5.7 H beams
P/B Wiseco 94's with Jaycee Long Barrels and Pins
Cam Engle FK-46 on a 110 lobe center stroker clearanced and Steel Magnum Straight Cuts
Heads CB CNC wedgeports 44x37 reworked by Steve Tims
Rockers EMPI 1.4 chromolly push rods German VW lifters
C/R 11.5 to 1
Ignition Locked Joe Hunt Magneto with Jaycee Mag Clamp
Carbs Italian 48 IDA's 44 vents CB tall manifolds match ported by Steve Tims, Empi linkage
Exhaust Berg 1 3/4 Merge with A1 Muffler
Flywheel Wedgemated 12 lb
Clutch Kennedy stage 2 4 Puck disc
Sump Berg 4 QT.
Pulleys Berg BRM Pulley Set
Trans Old School Non Freeway LOL ( 4:37 R/P H/D mainshaft,1:58 3rd, 1:32 4 th)
Last Edit: April 20, 2009, 15:59:44 pm by Shubee2 (DSK)
April 17, 2009, 00:46:18 am »
125k mile original 1600 dual port
. They were rated at 60hp, but a fresh stocker dyno's at a true 48hp or so. I've got a Zenith 32NDIX with 25mm vents, Bosch 010 w/Pertronix, header with S&S glasspack, and 30mm oil pump. It's tuned within an inch of it's life, with as much advance and the leanest jets it will take. I figure it's making 55-60 honest horsepower
Sam K
April 17, 2009, 04:48:48 am »
Here are the specs for the engine in my '67
2332cc's, never had it on a Dyno. The compression was 10.5 to 1 but I grew tired of running race fuel so I just lowered it to 9.5.
Crank - Demello 84mm chevy journal crank wdgemated to a 12.5 lb flywheel
Rods - Eagle 5.5in forged h-beam rons w/ARP bolts
P&L's - 94mm cima/mahle
Cam and valvetrain - Webcam .498 lift and 312 degrees duration, magnum straight cut gears stock rockers with solid shafts with swivel feet and chromoly pushrods
Heads - Jeff Denham ported 044s', 44x37mm valves, dual springs, titanium retainers, hardened keepers
Fuel system - 48 IDA's on CB tall manifolds, 37mm venturis, Berg linkage, Holley red pump and regulator, -8 stainless line from tank to regulator, -6 from reglator to carbs
Exhaust - Pheonix 1 3/4 merged system with 2.5 in magnaflow muffler from A-1
Ignition - German 009 with a pertronix ignitor that I bought in 1995 or so, 7800 rpm rev limiting rotor Blue coil, MSD wires, NGK spark plugs
Oiling system - Schadek 30mm oil pump, full flowed with Berg pump cover, Fram HP1 oil fliter, external cooler with thermostatically controlled fan, -8 hose and AN fittings
Clutch - KEP stage 2, stock solid center disc.
Other stuff - Berg breather box, equalizer pulley, Thing fanshroud & all german tin (except for the breastplate) is powdercoated gloss black
April 17, 2009, 07:29:56 am »
Motor in car now
CC 2303cc
HP ?
Crank Demello 83mm
Rods Eagle 5.5-clearanced and lighten by Berg (Mark V.)
P/L 94mm Mahle's
Cam Engle 120-clearanced by Berg
Rockers 1.25 modified by Berg
Cam Gear Magnum Straight Cut"s
Oil Pump 26mm Berg
Sump Berg 3/12 qt.
Pully Berg Equalizer (stock size)
Heads Jeff Deham 42X37
Carbs 48 IDA's (Italians) W/CB early tall manifolds
Ignition Bosch 010
Exhaust A1 1 3/4 Low Down W/stainless muffler
Motor in process
CC 2303cc
Crank DPR 83mm Chevy Jounals, 411 center main, wedgemated to a 14lb. flywheel. Was going to use an 86mm but changed my mind.... (again)
Rods Berg Jet Rods 5.5 W/Chevy Jounals
Barrels JC's 94mm Long Barrels
Pistons Wisco's 94mm W/JC buttons
Cam WebCam 86c clearanced by Berg
Cam Gear Magnum Straight Cuts
Rockers Berg 1.45's
Oil Pump Berg 26mm
Oil Sump Berg 3 1/2qt.
Carbs 48 IDA's (Spanish) modified by Berg on Skat Trak manifolds
Exhaust A1 Low Down 1 3/4 header W/stainless muffler
Ignition MSD Distributor W/MSD 6AL Box
Heads STILL IN PROCESS
CR 9.5:1
Can't wait to get this motor in, but looks like later in summer. It's the head thing. (WAITING)
Last Edit: April 17, 2009, 07:37:37 am by Racecraf
fish
April 20, 2009, 06:29:26 am »
really thought there'd be more than this
April 20, 2009, 12:45:49 pm »
Here's my current setup, though it's fixing to change like many of you ...
2276cc never on the dyno, low compression now but plan to raise it up just to see the differences possible...
Crank: Okrasa 82mm, porsche journals, Berg Equalizer
Rods: Carrillo 5.352
Cam: Web 86C with Berg 1.46:1 rockers (prefer my FK87)
Heads: Fumio welded and ported 42X37 with 53cc chambers
Compression: 8.7:1
Carbs: Italian 48IDAs on tall Scat Tracks with 40mm vents
Ignition: Vertex Mag, usually run 32 deg total
Exhaust: 1.75" Berg header into 2.5" magnaflo
Oil: 26mm pump with Berg cover, T4 cooler in Scat 36hp shroud
Trans: Berg 5 speed 3.88 r&p, 4.11, 2.47, 1.65, 1.21, .95
Fun on the street and still can blow down the highway at 75 mph without thinking about heat problems!
Best ever time was 12.77 on DOTs and thru the muffler.
Last Edit: April 20, 2009, 15:42:11 pm by TexasTom
April 20, 2009, 15:29:54 pm »
I dont think I have ever built a Cal look engine
so cant really help with this
April 20, 2009, 15:39:56 pm »
you're joking, how you never built a fast non-turbo type 1 engine?
how come there's only a few sub-2 litre engine posted in this thread?
are the owners a bit shy about their HP numbers? i liked to see a few more just for the sake of comparison...
DVK ~
April 20, 2009, 16:16:47 pm »
Motor for my 67 Sedan
CC and HP 1914CC 168 HP @ Flywheel @ 7000
Crank Berg 69mm counterweighted
Rods Berg Reworked VW I beam
P/B 94's Mahle Pistons & Barrel's
Cam Engle W-140 and Steel Magnum Straight Cuts
Heads Steve Tims 42X37 Stage 2 with Match Ported Scat DW-2 Short IDA Manifolds
Rockers 1.1 VW, chromolly push rods German VW lifters
C/R 10 to 1
Ignition Bosch 010 Dist. (Reworked advance springs and weights)
Carbs Italian 48 IDA's 42 vents Deano linkage
Exhaust Berg 1 5/8 Merge with A1 Muffler
Flywheel 12 lb 11/32 8 Doweled
Clutch Kennedy stage 1 Daken Ridged Disc
Sump Berg 1 1/2 Qt
Pulleys NOS Santana Stock size
Last Edit: April 20, 2009, 16:23:16 pm by Shubee2 (DSK)
April 20, 2009, 16:46:14 pm »
Quote from: 67-indeed/DVK on April 20, 2009, 15:39:56 pm
Always seem to have chrome on them somewhere
Anyway going on the figures Shubee has posted nothing I could do would ever come close to them
cheers richie,uk
April 20, 2009, 17:30:07 pm »
[/quote]
Shoob-
Remind me never to go on any roadtrips with you if you're driving this car/trans!
Top highway speed ... 45-50??
LOL!!!
