August 31, 2026, 18:51:03 pm
How much money to run 10s in a street car?now with part2, The evolution to turbo
31
32
33
34
36
Topic: How much money to run 10s in a street car?now with part2, The evolution to turbo (Read 1411102 times)
Chip
Re: How much money to run 10s in a street car?
Reply #930 on:
August 20, 2017, 20:37:34 pm »
Why do you need a cert to run in the 10's? Or are you knocking on the 1/8th mile cut off numbers? I don't know what those are, I don't speak 1/8th mile yet. Nice job either way though. Still waiting for my day to come.
gbaker770
Reply #931 on:
August 20, 2017, 22:20:42 pm »
Gainesville is one of only two tracks that the NHRA owns. The tech guy is the same guy who carts the chassis in our area and he told me there was no way my chassis would cert. I knew that and thats why I had current belts and safety gear. I even brought my arm restraints form when I had the dragster in case they didn't like the ragtop.
It's time to put a legit 8.50 cage in it and run it on. The big track with the boost turned up.
This is till at 14 psi.
Reply #932 on:
August 20, 2017, 23:10:47 pm »
Gavin, when you say chassis do you mean cage? its a pan car still isn't it?
Chip, I am guessing that ragtop is classed same as cabrio and you need a full cage at 13.99 I think it is
gbaker770
Reply #933 on:
August 20, 2017, 23:17:57 pm »
Yes Sir, cage is what I was referring to. It is a pan car. Thanks for the compliments Richie, Its been a long road te get a driveable 10 second street car and I honestly drive this thing 3-4 times a week.
Chip
Reply #934 on:
August 21, 2017, 14:19:04 pm »
Quote from: richie on August 20, 2017, 23:10:47 pm
Good point on the roof, never considered that a ragtop put you into the same category as a cabrio, but i could see a tech guy going that route i suppose.
bugnick
Reply #935 on:
September 06, 2017, 14:13:23 pm »
Richie, Is it possible to keep the competition eliminator heads cool enough on the street at 200-300 mile highway trips at 60-70 mph? I saw that you used type 3 tin under the cilinders. Did you modify anything to the tin or is it just stock? Good luck at dragweek!!
Reply #936 on:
September 09, 2017, 14:45:15 pm »
Quote from: bugnick on September 06, 2017, 14:13:23 pm
Hi Nick,
good to see you on here
They are just about ok for that, depending on gearing you can increase fan speed if needed with a pulley swap to the 912 top pulley which helps, and there are a few other things you can do to increase cooling surface area if needed.
I did a couple of things to the type 3 tin, but just to make them fit better and clear the bigger pushrod tubes
bugnick
Reply #937 on:
September 09, 2017, 15:07:36 pm »
Quote from: richie on September 09, 2017, 14:45:15 pm
Hi Nick,
Thanks a lot Richie! Good to know! Cheers, Nick.
Reply #938 on:
July 03, 2018, 21:43:06 pm »
Little tidy up while engine was out
Reply #939 on:
July 04, 2018, 12:24:41 pm »
Holy Shit Richie... since when did you start to care about the looks? That engine is a looking the business for shure.
Take care!
Best rgs
Kalle
Rocket Ron
It's old school for a reason
Reply #940 on:
July 04, 2018, 18:52:04 pm »
Hi Richie
Engine is looking sweet, are you running short manifolds or is it the throttle bodies that make it look squat
Regards Ron
13.12 @ 101.84
Grooving out on life
Reply #941 on:
July 04, 2018, 18:59:15 pm »
Quote from: BeetleBug on July 04, 2018, 12:24:41 pm
Take care!
Best rgs
Kalle
When I put it together I just used what I had to get it finished and on road but even then intended tidying it up when I got a chance, plan was to do it when it broke but it didn't happen
so never got done, as I had to take it out now after a little on road incident to check for other damage I thought I would treat it
It will probably break now wont it
Reply #942 on:
July 04, 2018, 19:01:00 pm »
Quote from: Ron Elliot on July 04, 2018, 18:52:04 pm
Hi Richie
Regards Ron
Comp elim manifolds are quite short compared to typical vw head manifolds and throttle bodies are shorter than IDAs I think
DaveN
Reply #943 on:
July 05, 2018, 13:59:27 pm »
Are you taking the car out this year?
Reply #944 on:
July 06, 2018, 17:52:33 pm »
Quote from: DaveN on July 05, 2018, 13:59:27 pm
Yep, maybe do the No prep at Rockingham august bank holiday, if not that then just a RWYB I think, want to try a couple of things and see if it will go quicker with what I got in it already
DaveN
Reply #945 on:
July 07, 2018, 09:24:22 am »
It will be good to see how much further it can get into the 10s
Reply #946 on:
July 08, 2018, 19:57:34 pm »
Quote from: DaveN on July 07, 2018, 09:24:22 am
Am sure once it cools down a bit and air is better it will run quicker than the 10.40s it has managed so far with a little tuning etc
BossHogg76
Reply #947 on:
July 17, 2018, 21:12:04 pm »
Richie that looks awesome,...great show car
Black_65
Life's too short, so drop a bomb on it....
Reply #948 on:
July 29, 2018, 18:25:13 pm »
Quote from: richie on July 08, 2018, 19:57:34 pm
Street car is quicker than my race car haha
Very cool richie 👍
'Never Forgotten' O/FF 456 10.49 @ 125.5 MPH
Reply #949 on:
July 29, 2018, 19:17:26 pm »
Quote from: Black_65 on July 29, 2018, 18:25:13 pm
Very cool richie 👍
Richie's street cars are all quicker than a lot of race cars! Quite depressing to think of this as the slowest of his three...
Reply #950 on:
July 29, 2018, 20:53:19 pm »
Quote from: Neil Davies on July 29, 2018, 19:17:26 pm
Very cool richie 👍
Maybe time to take my daily to a rwyb then
Reply #951 on:
August 23, 2020, 20:34:18 pm »
5 years ago already since it ran that 1st 10 on 1st pass with nitrous on, need to get it back out and see how low 10s it will go
https://www.youtube.com/watch?v=0zmlN1Tom2g
Reply #952 on:
August 23, 2020, 23:56:51 pm »
Ooh, this should be good! I do like this car!
MegaRookie
Reply #953 on:
August 24, 2020, 10:35:21 am »
I guess some carbon fiber will help too, and will be a nice contrast with the white it is now.
Reply #954 on:
November 21, 2020, 17:01:01 pm »
Quote from: MegaRookie on August 24, 2020, 10:35:21 am
Been adding some parts as i go along, fitted 1st rear wing up today, covers a 8 1/2 inch slick nicely
Last Edit: November 21, 2020, 17:12:46 pm by richie
brewsy
Reply #955 on:
November 22, 2020, 22:03:21 pm »
Quote from: richie on August 23, 2020, 20:34:18 pm
Hey Richie,
May I ask what torsion bars and shocks you're running there?
Seemed like very little camber change when you hit it. Do you limit travel or is t just stiff as f....??
Ta,
Marc
Reply #956 on:
November 22, 2020, 22:09:35 pm »
Quote from: brewsy on November 22, 2020, 22:03:21 pm
Hey Richie,
Ta,
Marc
its IRS so very little camber change anyway, would need to check but 27mm or 28mm torsion and QA1 shocks
brewsy
Reply #957 on:
November 24, 2020, 09:08:17 am »
Quote from: richie on November 22, 2020, 22:09:35 pm
Ahhh, that'll be why then..
Thought you'd managed some awesome combo of torsion, Z and shocks
Reply #958 on:
September 25, 2021, 19:20:04 pm »
Holy thread revival, Batman!
Just been looking at the photos on Eurodragster from Friday's RWYB attention Pod and saw a certain white 67 with lots of carbon bits with the front wheels so high up in the air! Didn't look to be a naturally aspirated exhaust any more...
Reply #959 on:
September 25, 2021, 23:17:06 pm »
Just seen the pic
31
32
33
34
36
