June 30, 2026, 18:40:32 pm
352210 Posts in 28922 Topics by 6920 Members
Latest Member: chris41
| | |-+  My kitchen built 2276 dynoed at 165 PS. Engine tuning experts needed.
Pages: 1 ... 7 8 [9] 10 11 12 Print
Author Topic: My kitchen built 2276 dynoed at 165 PS. Engine tuning experts needed.  (Read 294126 times)
181
« Reply #240 on: August 04, 2010, 10:30:09 am »
drivers view
volkskris
« Reply #241 on: August 04, 2010, 20:55:33 pm »
can you hear something off that radio while using the power you have? Grin Grin
I really love those seats, I want those too Smiley
« Reply #242 on: August 24, 2010, 13:45:33 pm »
<a href="http://www.youtube.com/v/Ap_kSxwAvMc" target="_blank">http://www.youtube.com/v/Ap_kSxwAvMc</a>
my first 1/4 this weekend :-)
« Reply #243 on: August 24, 2010, 14:20:43 pm »
12 second run? that's quick  Wink Grin
181
« Reply #244 on: May 23, 2011, 22:54:52 pm »
first mod for this year..Pertronix 1844 along with NOS 010..weŽll see what it can do.
« Reply #245 on: May 24, 2011, 00:13:01 am »
What happened to the doors? Didn't look like he was blowing them off in the video Huh
 Grin
« Reply #246 on: May 24, 2011, 01:39:42 am »
Is that a rev limiting rotor? I've never seen one for an 010. I'd be interested in one...
« Reply #247 on: May 24, 2011, 01:50:43 am »
Wonder if you can just run a 009 rotor and cap combination?
Dave Rosique
nobodyouno
« Reply #248 on: May 24, 2011, 04:34:06 am »
Nope. Not on an 010
« Reply #249 on: May 24, 2011, 08:44:31 am »
 Grin
they blew off in previous race :-) Not really. All Things have the doors hooked on quick release hinges and I remove them to save some weight.
And yes this is a rev limiting rotor from late aluminium (009)distributor. CSP has them in few different versions. To make them work on 010, you have to make an adaptor bushing to fit it on a distributor shaft - which is somewhat thinner than on late distributors. IŽm using the 6500 rpm version and I ocasionally meet the limiter on 2nd gear:-)
« Last Edit: May 24, 2011, 09:03:36 am by 181 » Logged
181
« Reply #250 on: May 24, 2011, 09:19:46 am »
from this years first VW event. Me on the passenger seat enjoying my own car.
« Reply #251 on: May 24, 2011, 12:21:49 pm »
 Grin
That's what I figured & good to know! ... never tried it but a good alternative to the original pieces which are harder and harder to find.
181
« Reply #252 on: May 24, 2011, 12:30:34 pm »
here you go...
needs to be really thin+ there is a slot cut into the bushing to accomodate for the rotor locating "teeth". Running second season without hassles.
Dave Rosique
nobodyouno
« Reply #253 on: May 24, 2011, 22:43:15 pm »
        ^^^ I stand corrected ^^^
I should have said... "Normally, the cap / rotor from an 009 will not directly fit an 010, however this is the Lounge and anything is possible"
Cheers Grin
« Reply #254 on: May 25, 2011, 02:50:13 am »
LOL!
I like those rotors, cheap insurance!
181
« Reply #255 on: May 26, 2011, 13:57:24 pm »
BTW IŽve seen a 009 cap modified to 010 - there was a small piece filed out where the breaker contact bolt goes through the distributor body and it worked!
PertronixŽed 010 installed yesterday now purrs like a kitten. I did not have the balls to set up to 30°BTDC as it was 10PM due to angry neighbors :-D
Type1/DVK
« Reply #256 on: May 26, 2011, 23:09:48 pm »
LOL!
Fuel continues don't hang there to long Wink unburnt fuel washes the cilinderwalls clean bad thing Wink
Dave Rosique
nobodyouno
« Reply #257 on: May 27, 2011, 03:59:47 am »
Not to hijack this cool thread on an even cooler car, but I have to ask: How in the world can you time an 010 distributor with an 009 style cap? The distributor cap clips are in different locations thus allowing the plug wires to be in the wrong position in relation to the points & rotor.
Am I missing something here Huh
Thanks in advance
« Reply #258 on: May 27, 2011, 07:44:20 am »
in Eastern block everything was possible. I do not remember the details, but it was  stock 009ish looking orange cap, with round recess filed by hand in in the same place as true 010 cap. This distributor isnť in my posession.
Dave Rosique
nobodyouno
« Reply #259 on: May 27, 2011, 18:12:41 pm »
Thanks for the reply 181..
I really like your car.. Good job!
« Reply #260 on: June 15, 2011, 19:28:05 pm »
Now IŽm looking for few more ponnies. I consider switching from FK8 to 86C and bumping compression from 10:00 to 11:00. Also thinking about experimenting with 42 mm venturies on my 48 DRLAS (now I have 40s) what effect will it have with my 42x37 Steve Tims Stage II heads?
Jan
« Reply #261 on: June 15, 2011, 20:10:40 pm »
How about a set of IDA's? What size is your exhaust? Seems like a lot of work for a small change in the cam.
181
« Reply #262 on: June 15, 2011, 20:48:10 pm »
exhaust is a 1 5/8 sidewinder. IŽ m limited by the shape of the back of the car - regular mufflers hang out a lot! Do you think that IDAs would be a huge progress over 48 DRLAs? I believe I can step up to 42 nn venturis max. I think that 42mm intake valves will be the limiting factor then..I love the driveability of the engine as it is but IŽm short of power on some occasions. The car is very heavy, I think around 1900 lbs with me on board.
« Reply #263 on: June 15, 2011, 23:13:50 pm »
I think you're just getting used to the power Wink
A 1 3/4" will give you more mid range and top end, but will sacrifice a little down low... if you up the cam a 1 3/4" would definitely compliment it.
As for the DRLA's vs Webers....
« Reply #264 on: June 16, 2011, 00:05:32 am »
I don't think moving to 42 vents will do much more than hurt the torque curve you have now.
It will only run well up high, low end will suck as will transistion ... not to mention trying to jet it to be smooth.
Just my opinion.
181
« Reply #265 on: July 20, 2011, 15:40:05 pm »
Well, order done:
Total seal rings  will go in place of stock Mahle rings
CB lightweight wrist pins with tru-arc locks will go in place of stock wrist pins and teflon buttons
Web 86C with a new set of 28mm CB lightweight lifters will go in place of FK-8 with the same brand lifters
compression will be upped to 11:1 (running on 100RON octane gas)
When the engine is out IŽll check for clearances and internals will be rebalanced just in case
will do HVX oiling mods like Bob Hoover recommends
weŽll see what it will do..
« Reply #266 on: July 20, 2011, 15:50:35 pm »
cool stuff. how come you're upgrading to total seal rings? did you have issue with the stock rings?
181
« Reply #267 on: July 20, 2011, 16:30:00 pm »
no issues, but I think with higher compression better sealing will not hurt. No blowby as the engine is fresh.  I made 2800 km round trip to EBI4 and back without any engine problems (my brake lighs died)
I consider stepping up to blueprinted 30 mm Schadek from my blueprinted 26 mm Schadek as HVX mods are very oil-consuming. Also considering corvair pushrod mod to promote valvetrain oiling and cooling.
I also polished my stock axles today, what do you thing, is that enough:
Catbox
Slave to internal combustion.
« Reply #268 on: July 21, 2011, 17:08:56 pm »
Your car looks awesome and the engine build was fun to read.
Thanks for putting it out there.
 Grin
« Reply #269 on: July 26, 2011, 10:27:59 am »
thanks for compliments:-)
Kitchen build engine will be soon coupled to kitchen build transmission:
